Question about General Electric WBSR3140GWW Top Load Washer
Ge wbsr3140g1ww washer does not spin or agitate . I tried resetting the motor by lifting the lid. The light blinks once by the motor but the machine still shows no signs for it to agitate or spin. I changed the lid switch an the problem is still there
2 Suggested Answers
  • 1516 Answers
SOURCE: ge wbsr3140g1ww washer does not spin or agitate
If the lid switch wiring was arcing to the metal frame of the washer, you should have had the circuit breaker tripping. Also, you may have damaged the contacts in the timer or the lid switch. Arcing to the frame would be obvious; the bare wires would have black or melted spots, and so would the sheet metal right next to the wire.
Bare terminals (but not bare wires!) are common, but they are shrouded or otherwise isolated from the washer frame. A burned switch most likely has bad contacts; this would stop the washer from running. In that case, replace the switch. An overheated switch could burn off the insulation on the wires. Repair the wires if that is what you have, either by cutting them off and crimping on new terminals (preferred) or by sleeving them with heat-shrink tubing. I prefer using new terminals in this case because the originals are probably heavily oxidized and may not make a good connection on the new switch. This could cause the problem to happen again. If you don't have an ohmmeter, take the switch to an appliance parts dealer and ask if they can check the contacts (a friend in the electrical or electronics business could do this too).
Note: if this is just a case of a burned-out switch, the timer is probably OK. Lid switches don't usually burn out unless people routinely interrupt the wash cycle by opening the lid, so you may want to evaluate laundry practices in your household. If that isn't the issue, you could have a problem causing the motor to draw too much current. Right after you do a load with the new switch, feel the door switch to see if it is running hot. If so, check for excess drag in the mechanism, especially the motor bearings.
Posted on Jan 23, 2011
My GE spacemaker washer is blinking and will not work
I have a he gtup270emww washer used very little. The washer was overloaded and quit working full of heavy wet clothes and water. The washer agitator does not operate. The water does not drain.
The light blinks. I have un plugged the washer to reset the motor and lifted and closed the lid 7 times. I drained the water by hand.
When I try to operate the washer, it adds water for 30 seconds, the water shots off and the green light blinks.
What is the fix?
Mar 24, 2013 | GE Spacemaker Washer and Dryer Electric...
Pump works, will not agitate or spin, checked lid switch , checks ok, can not see any blinking light anywhere
Hello
Try clearing any codes.Unplug machine for a minute .Plug back in ,raise and lower lid 5 times then see if it starts. if not, may have blowninline fuse to motor/inverter.
Aug 25, 2011 | GE Profile WPRE6100G Top Load Washer
I have a Top Load GE Model #WBSR3140G1WW. The
This is an electronic washer. Unplug for 2 minutes, plug back in, open and close lid 7 times slowly. This will reset electronic motor.
Jul 15, 2009 | GE Washing Machines
I have a ge washer mod wjrr4170goww it will only fill and pump out will not spin or wash
Crazy machine. I have been fighting with mine for awhile. GE has a link that I can't find right now. It says to unplug the washer from the wall for a minute. Then plug it back in. Within 10 seconds of plugging it in, lift the lid and close it 6 times.
Seriously!
I have opened the top section of the machine and removed the magnetic senson attached to the lid and the other half of the switch underside of the top cover. I tie-wrapped them together but I still have to fiddle with them sometimes to get the machine 'reset' and work right again. My wife hates it.
The root of the problem is the motor does not drive through a transmission like most washers do. So, to protect the motor, GE designed a sensor system so that anything that happens that suggests there is a problem ends up shutting off the main motor. This motor is what does the agitation cycle, the spin modes in drain, etc.
Do a web search with your model number and 'agitate' and 'spin'. You will find a number of sites that describe an error indicator panel inside the washer and what the quantity of flashing error light codes suggest is wrong with the machine. That will help you diagnose the problem somewhat.
Jul 04, 2009 | GE Washing Machines
G/e wbsr3140g1ww will agitate very slowly
Unplug for two minutes, plug in and open and close lid 7 times. This will reset the electronics.
Jun 11, 2009 | GE WBSR3140DW Top Load Washer
Washer wont spin
Check belt. If belt is ok then unplug machine for 2 minutes. Plug back in and open and close lid 7 times slowly. This will reset the electronic motor.
Jun 11, 2009 | GE Washing Machines
GE washer no main motor run so no agitate or spin
This is the electronic washer. Unplug for two minutes, plugin then open and close lid 7 times. This will reset motor. Also make sure belt is not broken.
Jun 07, 2009 | GE WBSR3140DW Top Load Washer
GE washer won't agitate or spin
un plug the machine , wait 30 sec. plug back in , open and close the lid completly 5 times with in 30 sec. if the problem is just needing to be reset this will do it if not you need to replace the motor
Jan 18, 2009 | GE WBSR3140DW Top Load Washer
GE Profile WPRE6100G will not spin
hi thanks for the question. i think the problem is with the lid switch . lifting the lid 10 times wont help if the switch is faulty check the lid switch thanks the appliance doc
Sep 20, 2008 | GE Profile WPRE6100G Top Load Washer
General Electric WBSR3140GWW Top Load Washer Logo
Top General Electric Washing Machines Experts
Dan Webster
Dan Webster
Paul Bade
Are you a General Electric Washing Machine Expert? Answer questions, earn points and help others
