Question about Brother IntelliFAX 4100 Laser Fax
No incoming or outgoing fax
Error message says "check cassette 2". reinsatll casette 2. Any ideas?
  • 328 Answers
Do you have a second cassette installed? If not, you have somehow activated the feature. Go into the menu and deactivate or turn off the second cass. feature. Owner's manual has instructions.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Posted on Sep 06, 2007
SOURCE:
Error 321?
This error message indicates the transmission problem, perhaps the incoming or outgoing telephone signal is down or not properly functioning, if possible, try to check the connection and set the speed to lower level. Try sending a fax to another machine and check, if the same problem occurs or not.
Good luck.
thanks for using FixYa.
Jun 25, 2010 | HP OfficeJet 4215 All-In-One InkJet...
HP laserjet 1020 fax incoming fax, machine
hp laserjet is not a fax.It is only a printer.
Dec 09, 2009 | HP LaserJet 1020 Printer
Samsung fax machine SF 560R states 'comms error' messages in memory 65% how do we print these messages out?
When it has no paper then your all incoming fax documents save memory,Insert paper in cassette box and press start key or memory check button.
Dec 08, 2009 | Samsung SF-560 Plain Paper Laser Fax
Incoming faxes always go over to a 2nd page - just a small amount - but it waste that next sheet - how can I make it fit better - or shrink the page 5% to fit better? Dean
Printing a Reduced Incoming Document
Your machine can reduce the size of an incoming fax to fit the size of the paper
in your machine. Select ON to turn on this feature.
After you connect Cassette #2, you can turn on Automatic Reduction for each
cassette. (See Turning on Cassette #2 (Option for FAX-4100 and FAX-4750e), Page
4-1)
1 Press Menu, 2, 1, 5.
2 If you have the optional Cassette #2,
press or to select CASSETTE #1
or CASSETTE #2, and then press Set.
3 Use or to select ON (or OFF), and
then press Set.
4 Press Stop/Exit.
If you send faxes from a computer on the same phone line and your Brother
machine intercepts them, set Easy Receive to OFF.
Cassette #2 can be purchased.
Aug 24, 2009 | Office Equipment & Supplies
Won't print an incoming fax; displays error message 004
I think the error is point to a fuser (temp issue) problem.
You can check out this thread for some more info that might be helpful. - LINK
Nov 11, 2008 | Canon LaserCLASS Fax 710 Printer
Send/Receive Error with Outlook 2002
What are the incoming pop3 & outgoing SMTP settings.they should be pop.sbcglobal.yahoo.com & smtp.sbcglobal.yahoo.com
Please check
Which antivirus are you using?
May 13, 2008 | Microsoft Outlook 2002 for PC
Incoming faxes are not received
1. Make sure you have paper in the feeder tray.2. Make sure that Fax Forwarding is not selected: Use the up/down arrow buttons to scroll through the menuoptions until you see the option required, and press the "check mark" button to select:
Select "Fax" on the device main menu. Select "Fax Setup" from the Fax submenu, Select "Ringing and Answering" from the Fax Setup submenu Now find the "Fax Forward" option. Once you see this option, press the left or right arrow buttons until you see "Off". Now press the "Enter" button to save.
Let me know if this doesn't solve your problem, and include further detail to the problem if available.
Jan 21, 2008 | Lexmark X9350 All-In-One InkJet Printer
Brother IntelliFAX 4100 Laser Fax Logo
279 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
