Question about Lands Phones
Hansgrohe f-set up 15715000 - Lands Phones
How do a fix a cold water leak coming from the faucet?
Read the Assembly Instruction (Finish Set) found at http://spares.hansgrohe-usa.com/etk/US/product/04465000/8802057498467.seam?fsid=0x0000771100006CC100007701&lang=en_US&wcms=US on the Hansgrohe website.
I chose the Focus S Shower System Combination Set, Article No# 04465000, because it's sort of generic and typical. Part # 88727000 will solve your problem
Nov 02, 2015 | Hansgrohe Home
No pressure in Hansgrohe shower when on hot setting
This is most likely debris in the filter screens on the thermostat cartridge or the thermostat cartridge has worn out. Cleaning the filter screens may resolve the issue. If cleaning the filter screens does not resolve you may need to purchase a new thermostat cartridge. If you need further information feel free to contact me at Hansgrohe. 1-800-334-0455. Press 2 for tech and ask for David Scarborough. I'd be happy to help.
Oct 27, 2012 | Hansgrohe Shower 26101 Pharo Prestige...
Hansgrohe axor faucet jammed
On this model the escutcheons will turn counter clockwise and the whole handle will lift off as one unit. In some cases water deposits can cause the handle to stick and you may need to use CLR to lossen the deposits. In some other cases installers will put the handle on first and then tighten the valve to the deck. This causes the handle to be too tight to the deck and can strip the handle fixation. Try loosening the the valve set below the handle and see if the handle is easier to remove once the valve is loosened. If you need further help feel free to contact me at Hansgrohe Technical Services at 1-800-334-0455. Press 2 for Tech and ask for David Scarborough.
Sep 16, 2012 | Hansgrohe 31063001 Metris S Widespread...
I need a hansgrohe avate guard lav faucet aerator wrench?
The aerator on Hansgrohe Faucets generally do not require a special tools to remove them. They normally unscrew in a counter clockwise direction. Some specific models do require a tool.Feel free to contact me at Hansgrohe. 1-800-334-0455. Press 2 for tech. Ask for David Scarborough.
Jul 04, 2012 | Hansgrohe Plumbing
Trying to buy 2 replacement heads for my hansgrohe toilet brushes in interactiv pattern
Your part is listed on the USA site; authorized on-line retailers are listed here:
http://www.hansgrohe-usa.com/us_en/131332.htm
If you are not in the USA, you may want to check if Hansgrohe has a website in your country:
http://www.hansgrohe-usa.com/us_en/19254.htm
Trust this is helpful.
Dec 29, 2010 | Hansgrohe Replacement White Head Toilet...
Hansgrohe faucet part-no. 92730000 faucet cartrige installation instructions
Please contact me at the below number or email and I can supply you with a copy of the installation instructions.
Regards,
Chris
Christopher Scott
Technical Support Specialist
Hansgrohe Inc.
1492 Bluegrass Lakes Parkway
Alpharetta,Ga 30004
Tel:1-800-334-0455
Fax:678-762-7042
Email:Christopher.Scott@hansgrohe.com
Nov 28, 2010 | Hansgrohe 06649860 Solaris Single Hole...
Hansgrohe 41533 wall mounted soap dish install
I had the same problem with a Hansgrohe set screw on my toilet paper holder. Thought an allen wrench would do to open it but it does not work, I had to use the end of a pointy dinner knife to coax it out, might have also used a flat edge glass repair screwdriver also to get it out. It almost look as if it was "stripped" in the opening. I'm now trying to find a replacement set screw and came across this page. Hope that helps.
Apr 15, 2009 | Hansgrohe 41535000 Axor Uno Toilet Brush &...
Adjusting water temp
Behind the handle there is usually a scald gaurd on the newer faucets. You can adjust it from there. If your not sure, follow this link and download the installation instructions to your faucet. There you will find how to adjust it step by step. http://www.hansgrohe-usa.com/us_en
Mar 05, 2009 | Hansgrohe Thermo II Rough-In Valve Chrome...
Lands Phones Logo
22 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
