Question about Garden
My husqvarna 235r runs without mufler but i put the mufler and it wont start
  • 1,807 Answers
Possibly a carbonised exhaust. probably needs a clean
Posted on Aug 01, 2013
Husqvarna 235r brush cutter starts fine when cold but won't start when hot
If it has spark and fuel then it may be worn, causing low compression and too weak to start. .
Jun 15, 2014 | Husqvarna 323R 24.5cc Straight Shaft Bike...
There is a simple test you should do on this unit. first remove engine cover, then remove spark plug, then take soapy water and spray it around the base of the cylinder where it meets the crank case, if you have compressed air and a air gun, shoot air through spark plug hole and watch for bubbles around base of cylinder. be careful to only shoot very low pressure into unit. if you see bubbles there is an air leak, this is not repairable. new unit.
Jun 15, 2014 | Husqvarna Garden
Husqvarna 235R Manual The fuel lines on my 235R disintegrated. I have cut new ones from the right sort of tubing but cannot figure out where to route them to prevent fouling other parts. Is this shown...
The fuel hose from the tank goes under the carb to the left hand side of the carb and in front of the two feet on the bottom of the air filter housing, it is all a bit tight under there, the right hand pipe goes from the carb to the shorter connection on the primer, a pipe from the longer connection on the primer goes back to the tank
Oct 09, 2013 | Garden
I have a husqvarna 235r it starts without the mufler but when i put the mufler it wont
Possibly a blocked spark arrestor or carbonizes exhaust, probably needs cleaning out as the gasses cant flow through the exhaust properly.
Aug 01, 2013 | Husqvarna Garden
340 husqvarna wont run
Carburetor, compression or fuel problem.
Apr 21, 2012 | Husqvarna Garden
I need an exploded view of a Husqvarna 235r
Send me an e mail address and i will send you a pdf file with the parts list on
Feb 28, 2012 | Garden
How to change mufler on a137 husqvarna
The muffler is in two halfs, start by removing the two 8mm headed bolts, this will allow the front half to come away,along with the baffle, there is then a single 8mm screw holding the inner half of the muffler onto the cylinder, remove this and the the inner half will come away with the gasket.
Mar 07, 2011 | Husqvarna 350 18 Inch Gas Chainsaw 52CC...
Wont pass smog. 1986 e.f.i. new mufler to tip.
check the timing it may be off also clean throtlebody out and put a injector cleaner in the tank.goodluck.
Jan 21, 2011 | 1987 Ford Ranger
I just bought 236r from cebu philippines,the unit
Check the model number all I have been able to come up with is a 235R brush cutter. I will be going by a dealer tomorrow for some parts I will ask him.
Please let me know, thru the comments section.
Good day.
Oct 23, 2009 | Husqvarna Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
