Question about Samsung Televison & Video
I HAVE A SAMSUNG LN46B530P7F WHICH FLICKERS A BACKLIGHT CONTINUALLY. I KNOW THAT I NEED TO CUT A JUMPER ON THE POWER BOARD.........WHAT IS THE JUMPER NUMBER THAT I NEED TO CUT?
3 Suggested Answers
SOURCE: part number for the samsung le52m87bd backlight inverter
Hey!
I also have a SAMSUNG LE52M87 LCD TV and I have the same
ANOYING BUZZ comming from ( I think ) backlight converter. - I am
almost 100% that its because of the backlight inverter while the sound shifts frequency when backlight is changed ( from 1 - 10 ), but the volume of the buzz stays the same. Only the tone changes. I have this TV for a year now and havent realy noticed until now, so I think it started buzzing recently, because I didnt hear it before ( and I got realy sensitive hearing :) ) ...
ITS DRIVING ME CRAZY ...
PLEASE post what happened when ( if ) you changed the inverter,
or what did you do to solve the problem ...
Many thanks in advance!
Eddie from Slovenia
my email: Ldesign.marketing@gmail.com
Posted on Jan 08, 2010
gopakumarg43
  • 75571 Answers
SOURCE: My Tv is samsung ln46b530p7f has no picture but I heard sound what is problemI don't any picture
Any capacitor on the power regulator board might have bursted out. Check the power regulator board. Replace it as card basis.
Posted on May 10, 2012
Samsung 40 Model# LN40C530F1FXZA
its the backlight inverter and it is getting hot,clean the inside with air
Samsung BN44 00264A Power Supply Backlight Inverter
May 28, 2015 | Samsung Televison & Video
Samsung ln40b550k1f screen flickers on and off
When the screen flickers on and off it usually comes from the power supply or backlight inverter being bad. For your TV, the backlight inverter and power supply unit are combined. As you can see in the picture attached it's the white part on the right side that has gone bad. You will need to replace that board. LN40B550K1F Samsung LCD TV Repair Guide
Mar 11, 2013 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
SCREEN FLICKERING
The power supply module in this tv is part number BN44-00341A,
Samsung's dealer info says to:
For BN44-00341B; cut and remove jumper JP852.
This jumper wire is located just below the part number stamp on the pc board, I've done several of these and it cures the problem.
Jotvguy
Mar 04, 2013 | Samsung LN46C650 TV
Samsung picture flickers
Pull the back off the tv. Look at the power supply. Find jumper designated JP854 on power supply. Take a pair of wire snips and cut that jumper out of the circuit. Put the tv back together. That's it.
Jul 15, 2012 | Samsung LN55C630 TV
Flickering TV Problem
Some of their sets have a issue on the power supply board where it flickers(the picture) on scene changes and gradually gets worse.
problem with those sets is on the power board and some only require a jumper there to be removed.
Call samsung with the model number.
Jun 02, 2012 | Samsung SlimFit TXS3082WH 30 inch TV
May 09, 2012 | Sharp LC22DV24U 22 in. LCD TV/DVD Combo
Lcd flutter ln-46c610
You might want to call Samsung with the model number as I remember seeing a notice for certain models that have this issue---a jumper plug needs in those sets to be removed that is located on the power board.
Apr 30, 2012 | Samsung LN46C610 LCD TV
Backlight going bad?
This is not the backlight its the power supply board. We have a repair guide posted on our web site at: http://www.ccl-la.com/blog/index.php/samsung-204b-lcd-monitor-repair/ The repair consists of replacing 5 capacitors on the power supply board. If you can solder then you can do this repair. If you don't want to do the repair we do offer a repair service, you can get this information here: http://www.ccl-la.com/blog/index.php/service-request-form/
I hope this helps, If so please rate our solution.
CCL_Tech
Corporate Computer
www.ccl-la.com
Apr 28, 2010 | Samsung SyncMaster 216BW Monitor
The screen flickers
The backlight inverter board may be going bad or the power supply problem. Look for bad capacitors.
http://en.wikipedia.org/wiki/Capacitor_plague
Nov 10, 2009 | Polaroid LCD-1700 17 in. Television
Samsung 226bw visible flickers just after it is turned on
You may have a faulty inverter or loose power inverter connection. OR
You may have a defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
Aug 31, 2009 | Samsung 226BW Monitor
Televison & Video Logo
42 people viewed this question
Jerry Greenberg
Jerry Greenberg
