Question about Altusen Aten MasterView CS-1732 (CS1732) 2-port KVM Switch
How Can I Turn Off Beep on MasterView CS-1732 KVM Switch?
I have Aten USB KVM Switch, and i lost the user guide. I need to switch between the Pc's, what is that hot key i have to press to switch it. M.J Regards
You can check out here- there's a lot many Aten usb kvm switch, check your model and find out how to resolve your problem http://www.kvmstuff.com/server-management/kvm-switches/usb-kvm-switch.html
Jan 11, 2011 | Altusen Aten CS64U--4 Port USB KVM...
Reboot of linux server hangs
It should not be the cause of problem, kvm switch is an intelligent device. Turn off the device, unplug the wires do not unplug them for a minute or so, plug them in and turn it on. It should work if not call the customer support.
Nov 19, 2010 | Altusen ATEN CS1804--4 Port Sun KVM Switch...
How can you switch over to different computers with the Scorpius -p7 trackball keyboard?
If your keyboard and this KVM Switch are both PS2 (from the picture I see the KVM Switch is PS2 and from the Internet searching for Scorpius -p7 trackball keyboard I see it can be either USB or PS2) the connections are straight forward.
Usually a 2 port KVM switch uses keystrokes to make the switch, they are usually "Scroll Lock" or rarely "Num Lock" -- press the key 2 times with about a second or less between presses. You may hear a BEEP from the switch indicating "it's hearing your request."
Good Luck
Jeff
Mar 02, 2010 | Belkin F1DK102P 2-port KVM Switch
Who to construct a video splitter?
Use NVIDIA Graphic Card for this. You can see 2 different movies at the same time on 2 different monitors.
Feb 01, 2009 | APC Cables - KVM Products, Data Switches,...
Video splitters
I don\'t know about your specific brand, but splitters have losses that are typically 3.5,6, 7.5 and 11 for 2,3,4 and 8 way.
In most cable modem applications, we use a single 2-way so that the cable modem has only a minimum loss, then the TV\'s get put on the other side of the 2-way and split as many times as needed.
Here\'s a link to a typical splitter manufacturer where you can see the printed insertion loss of the various splitters.
Carl
Jan 03, 2009 | APC Cables - KVM Products, Data Switches,...
KVM hotkey
Hold down the Scroll Lock key for several seconds. The switch should beep briefly and blink. Hit either the "1" or "2" key on your keyboard to switch to the corresponding computer connection.
Jun 23, 2008 | LinxCel PS-121D 2 Port PS2 KVM Switch
Aten Master View KVME CS1774 Wavy Screen
This is a fairly common occurrence, typically due to signal loss. The longer the total cable run (monitor to computer connector) the less loss you will have. The longest KVM to computer cable I can use reliably these days is about 12-15? at 1024 x 768 at 32 bit color or 8? for 1280 x 1024 at 32 bit color. Things you can do to reduce loss: -Reduce the length of the total cable run. -Increase the quality of the cables used. I only use low loss cables now and have far fewer issues. -Change the video card, some cards can push a signal a longer distance that others. -Reduce the resolution/colors the video card displays. -Try a different monitor or if possible use a different (low loss) cable to connect the monitor to the KVM. Let us know how it turns out or if you have any other questions.
Jul 04, 2007 | Altusen Aten MasterView CS1764 4-port KVM...
Altusen Aten MasterView CS-1732 (CS1732) 2-port KVM Switch Logo
94 people viewed this question
Top Altusen Computers & Internet Experts
David Payne
David Payne
Are you an Altusen Computer and Internet Expert? Answer questions, earn points and help others
