Question about ViewCast OSPREY-700 HD High Definition Streaming Video Capture Card
Linux osprey 700 - ViewCast OSPREY-700 HD High Definition Streaming Video Capture Card
Windows 7 drivers
They should have a windows 7 driver. I suggest that you contact Viewcast Tech support.
David
Apr 11, 2013 | ViewCast Osprey 210 Video Capture
Where can i get a dirver for Osprey 50 for Vista or Windows 7
I am afraid if its' Osprey 500 or 50, I am sorry if i am not right. Anyway try this site, http://www.viewcast.com/support/downloads and download the drivers. Good luck
May 22, 2010 | ViewCast Osprey 50 Video Capture
Hi,i have the problem with Audio device on my Osprey 210, video works grate..but audio don't work.... help'
Here's an easy way to install or update your sound card driver:
Use this driver scanning tool, which scans your computer for the needed drivers. It has an option to automatically retrieve them for you.
You can download this free tool from here or directly from this link
After you have downloaded the above file, double-click on it and follow the simple steps to install it. Then, when it asks if you want to run it, just answer yes. This is easier than manually searching, downloading and installing the drivers.
Hope that helps,
Regards,
Raspal
For Windows XP Driver Files and How-to Resources, visit XP Drivers
Mar 24, 2010 | ViewCast Osprey 210 Video Capture
Osprey 210 audio problem
The breakout cable has the RCA connectors needed. Yellow is Video, Red and White are the 2 audio inputs. Alternate inputs are the 1/8" stereo jack for sound and the S-Video plug. (not to be used all together).
viewcast.com is their website.
Also check the setup for recording, that the audio source is selected properly.
Win 7 not recognizing osprey 50
tbm esou querendo sabr c funciona com windows 7 e com o Windows Media Encoder???
Mar 06, 2010 | ViewCast Osprey 50 Video Capture
Osprey-230 video capture card distorted
you must connect all cameras to solve this problem.if your capture card supports e.g. 4 cameras and you are only 1,2 or 3 connected the image can be poore.your video card has nothing to do with this.
Aug 28, 2008 | ViewCast Osprey-230 (OSPREY230) Video...
The microsoft doesn't identify the osprey 230
since the audio works but not the video, it sounds as though the problem might be in the codec, not the driver. check card provider to see if there is an updated codec pac or new service pac. try: http://www.viewcast.com/driverdownload.asp
Mar 25, 2007 | ViewCast Osprey-230 (OSPREY230) Video...
ViewCast OSPREY-700 HD High Definition Streaming Video Capture Card Logo
20 people viewed this question
Top ViewCast Computers & Internet Experts
David Payne
David Payne
Are you a ViewCast Computer and Internet Expert? Answer questions, earn points and help others
