Question about Michael Kors watch - MK5354 Ladies MK 5354 Ladies
How do you set the date, i have tried pulling out the stem and turning it but nothing happen.
How to set date and day on INVICTA SUBAQUA NOMA III
Pull the stem out 2 clicks sets the time, pull the stem out just 1 click
turn it forward sets the day and turning the stem backwards sets the
date. I hope this helps
Jul 12, 2014 | Invicta Subaqua Noma Iii S
I need to change the date
Changing the date for the FT500WVB watch is easy. Just pull out the stem of the watch to its first stop. Then turn the stem counter clockwise a couple of twists and the displayed date will increment (that is increase) by one day and you will hear a little click. Keep twisting the stem counterclockwise and the date will increase by one each time with a little click. Stop when you reach the correct date and push the stem back in to its fully seated rest position. Note- be careful not to change the date when the watch displays a time between 9pm and 1 am as setting the date in this time range may cause the watch to increment the date at noon rather than midnight.
Note also that if you want to set the time you just pull out the stem to its second stop position and twist the stem to advance the position of the hands of the watch. Then when the time is set, push the stem back in to its lowest rest position. So remember- first stem stop sets the date and second stem stop sets the time. That's it.
Mar 25, 2014 | Casio Forester FT500WV-3BV Wrist Watch
Whittnauer , 10C01 Crown does not double click, so I can't set day and date.
The button is probably for setting the date, that would explain why the stem only comes out one click. Try pushing it in and see what happens. If nothing then pull the crown out and then push the button. One or the other is true. It also may be you set the day by turning the hands around and around until you get the right day and the button is for the date. Let me know. Michael
Oct 06, 2012 | Wittnauer 10C01 Watch
How to set ladies rolex watch?
A standard ladies rolex should have just one stem and crown on the side. Occasionally the crown is a screw down crown. Try to pull the crown out if it does not pull out try to pull and unscrew it at the same time. There are two settings one you pull the stem all the way out and that should set the time, if there is a day or date setting, you push the stem halfway in turn one way for day and other way for date. Please let me know if there are any other buttons on watch thank you!
Aug 27, 2011 | Watches
I can not seem to pull stem out of my analog timex wr 50 watch to set day and date. Only pulls out far enough to set time.This is the second watch that this has happened too. I returned the first one to...
most of the time with watches, there are two "pulls" on the stem to set the date and the time. normally, when you pull it out all the way, that's the setting for the time. so i think you've pulled it all the way out. try pushing it back in, then give the stem a soft pull. you'll feel about halfway, it stops a little bit. that should be the setting for the date.
i hope this helps
Aug 19, 2011 | Watches
Unable to reset brietling colt, even after ajusting stem to 1st and 2nd postions.
mcdevito75 here, Let"s hope your description of the problem with your watch is wrong. Try this sequence, First, wind your watch, the automatic continues to wind your watch when you where it but to get it started, wind it 20--30 times. 2nd, your crown locks down, turn the stem Clockwise to un-lock it (the stem) now pull the stem all the way out then back in 1/2 way to set date. Set DATE to DATE before the real date turn crown counterclockwise. Now pull out crown all the way and turn clockwise to set the DATE and time (real Date) push the crown back in and turn counterclockwise to lock the crown. If this doesn"t work, look for a small watch repair shop in your area for this adjustment.
Jun 28, 2010 | Breitling Aeromarine Colt Ocean A64350...
I have a problem pulling out the stem to set the date on my Roadster. Can you help? I can't seem to grasp the stem securely enough to pull it out. Thank you
mcdevito 75 here, you should be able to get a finger nail just under the stem to lift the stem to set the time, day/date, first be sure the stem isn"t a screwdown type, gasp the stem and turn it to see, if it is a screwdown type, simply un-screw the stem then pull it out to set the time, day/date. If all fails your local or any jeweler can help.
Jun 16, 2010 | Cartier Roadster W62016V3 Wrist Watch
How do I adjust the time and date on my Timex Expedition watch
Hi, the upper of the two watch stems is turned counter clockwise (looking at the stem) until the desired function (i.e., format, date, time, chrono, timer) appears. To set that function, pull the upper stem out and turn CW to advance & CCW to go back. Once hours & minutes are set, the stem can be pushed in upon a mark to start at zero seconds. For the day of the week, turn the upper stem CCW until date appears. Pull out the stem, to detents or positions, and this will allow the day to be adjusted.
Take care
Mar 25, 2010 | Timex Expedition47761 Wristwatch
The winding stem came out when i was trying to set time formula 1
I would advise you to take it to an authorised dealer (see the Tag Heuer web site (www.tagheuer.com) ) and let them sort out why the stem came out. I feel sure that this shouldn't happen and it is likely that a repair is needed.
(It may be that something that restricts the movement of the stem has become detached. If this is so, then something may be moving about inside).
Feb 11, 2010 | Tag Heuer cj1110.ba0576 Wristwatch
Set date on skagen 496sgsc
I used to sell Skagen watches,don't know excatly which watch you have . I even went to their web site and couldn't find it. Most Skagens ( unless they are a chronograph with the three curcles on the dial) works like this: Your watch stem has 3 differant settings #1 all the way in #2 half way out , and #3 all the way out . To set the time you pull the stem all the way out and adjust the time. To set the date,pull the stem all the way out and turn untill the date changes ( this will make sure you have it on am-pm correctly) then put the hands at 6 o'clock. Put the stem all the way back in, then pull the stem half-way out. Start with the stem all the way in and slowly pull it out and you will feel the "click" when it is half-way out. MAKE SURE YOU HANDS ARE NOT BETWEEN 9 O'CLOCK AND 3 O'CLOCK, OR YOU WILL BREAK THE AUTOMATC DATE SETTING GEAR!!!!! Then either turn the stem clock-wise , or counter clock-wise , one of the two ways will set your date.
Oct 27, 2008 | Skagen Watches
Michael Kors watch - MK5354 Ladies MK 5354 Ladies Logo
16 people viewed this question
Top Michael Kors Watches Experts
Ansel Alberto
Ansel Alberto
ray gallant
Are you a Michael Kors Watch Expert? Answer questions, earn points and help others
