Question about Fujitsu Siemens 3815 FA-M (White) 15" LCD Monitor
Unlock power button onfujitsu monitor - Fujitsu Siemens 3815 FA-M (White) 15" LCD Monitor
Osd unlock
To unlock the OSD (onscreen display control), turn off the monitor and then press and hold the Menu button on the monitor. Then press the power button to turn the monitor back on. Do not release the Menu button before pressing the power button. This same step (holding the Menu button and then pressing the power button) enables the OSD lock. The menu button is the top button on the right side of the monitor (on the bezel). The power button is the bottom button of the group. AOC has the documentation for the 2036sa here: http://us.aoc.com/monitor_displays/2036sa . See page 20 of the User's Guide for the OSD lock procedure. The picture of the monitor buttons is on page 19. The guide is available as a PDF on the AOC site. Note: you will need Adobe Reader or a similar program to read the file.
I hope this helps.
Nov 01, 2012 | AOC 2036sa 20"TFT LCD Monitor
Aoc e2043 osd locked.How do I unlock? Lt button trick didn't work.
Please try to Turn the monitor off. Hold down the Menu button while the monitor is turned off, then press the Power button again to turn the monitor back on. This should unlock your OSD menu. best regards
Aug 25, 2012 | AOC LM742 17" LCD Monitor
How do I unlock the OSD?
Unlocking the OSD menu
  1. Turn the monitor off.
  2. Press and hold the Menu button.
  3. Press and release the Power button.
  4. Release the Menu button.The OSD is now unlocked.
Apr 26, 2012 | LG Computers & Internet
My computor monitor shows OSD lockedout
Plug in the monitor and power it up. Hold down the Power button until you get a message saying “OSD Unlocked”. If the problem persists after OSD is unlocked then unplug the monitor from the wall, wait 20 seconds and try again
Turn on the monitor and hold down the Menu button for 10-20 seconds. This should unlock the OSD
Turn off the monitor, press down the Menu button and then turn on the monitor. Wait 10-20 seconds. This should unlock the OSD.
The Menu button may be stuck in a pressed in position. To get it “unstuck” you’ll usually need to open up the monitor. This could be tricky unless you know what you’re doing. Unfortunately there are too many models of monitor for me to provide detailed instructions. If you have warranty this is where you want to contact the manufacturer.
Aug 02, 2010 | Computers & Internet
My monitor went into osd lockdown when i was trying to hook up to my tv how do I unlock it
A)Plug in the monitor, and power it up. Hold down the power button until you get a message saying “OSD Unlocked”. If the problem persists after OSD is unlocked, unplug the monitor from the wall, wait 20 seconds, and try again.
B)Turn on the monitor, and hold down the Menu button for 10-20 seconds. This should unlock the OSD.
C)Turn off your monitor. Press the Menu button, and turn on the monitor. Wait 10-20 seconds. This should unlock the OSD.
D)The Menu button could be stuck in a pressed down position. To get it “unstuck,” you’ll usually need to open up the monitor. This could be tricky unless you know what you’re doing. Unfortunately there are too many models of monitor for me to provide detailed instructions. If you have a warranty this is where you want to contact the manufacturer.
Mar 08, 2010 | Computers & Internet
How to unlock OSD lockout in HP L1940T Monitor
How to unlock HP 1940 LCD monitor?? i try with holding menu button and power also..but didnt show me unlock...i hold like 1min even more...and its keep to blink OSD lock...and Main Menu on my screen.Can u tell what i need to do Thank you
Jan 20, 2010 | HP L1940T 19" LCD Monitor
How the unlock osd
OSD Lockout in HP Monitors First restart the Computer. Then hold down the menu button for 30 seconds, the main menu appears, then exist the main menu, then remove power cable of the monitor, then hold down the power on button of the Monitor for 30 seconds, then plug the power cable to the monitor. The OSD Lockout problem set rights.
Nov 12, 2009 | HP vs15 15"LCD Flat Panel Monitor
OSD LOCK
Normally the OSD lock will only be displayed for 5 seconds.
Regardless you should be able to get rid of it by pressing holding the up arrow key for 10 seconds.
If this fails to resolve the issue try this. Disconnect power cord. Now press and hold button 1. Plug the power cord back in. You may have to press the power button while still holding button 1. The OSD lock should clear after that.
Hope this helps.
Oct 02, 2009 | ViewSonic E70f 17" CRT Monitor
OSD locked how do I unlock
OSD Lock Function: To lock the OSD, press and hold the Left button while the monitor is off and then press power button to turn the monitor on. To un-lock the OSD - press and hold the Left button while the monitor is off and then press power button to turn the monitor on.
Sep 11, 2009 | AOC 917Sw 19" LCD Monitor
Princeton VL1715 monitor's pwr button is "locked." Can't turn-off
I have resolved this situation on other brands by holding down one of the advustment buttons while holding the power button in. You will see a message about "unlocking button" and a sliding bar if you find the right buttons.
Monitor Mike
Jan 06, 2009 | Princeton Digital VL17151 17" Flat Panel...
Fujitsu Siemens 3815 FA-M (White) 15" LCD Monitor Logo
27 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
