Question about Roper Washing Machines
Roper RAS8445JQ0 washer won't drain and spin - Roper Washing Machines
vest6
  • 196 Answers
SOURCE: Roper washer does not drain
Alicia7q : Faulty water pump or restriction in drain line between tub and outlet hose.
arlenekc,: That metal thing is part of the motor. What you have is a leaking water pump.
badwasher,: Check the lid switch. This machine will not spin or drain if the switch is faulty.
Posted on Jan 12, 2008
  • 351 Answers
SOURCE: roper(whirlpool) washer will not spin
check the tub casting under the agitator or it the gearcase
Posted on Mar 20, 2008
  • 126 Answers
SOURCE: Roper washer will not spin or drain-
you may have something stuck in your pump, preventing it from draining. The washer will not spin until it does drain. You'll have to empty the tub (you can do this with gravity by taking the drain hose and putting it down near the floor in a bucket). You will have to take the cabinet off, then take the hoses off the pump. Have some towels ready! Look inside the pump and hoses for an obstruction. If the fins inside the pump are damaged, you will have to replace it. If there is no obstruction here, look down inside the hose drain. Run a coat hanger down if neccessary to see if theres a blockage. The pump could be dead, too.
You could have a dead spot on the timer, but this is doubtful.
Posted on Nov 24, 2009
mc1bean
  • 3053 Answers
SOURCE: Good evening, My Roper
I am thinking if all works good except won't spin, it is your lid switch. Under your washer lid you will notice a peg of some sort that when lidnis closed goes into a slot/hole and that triggers the spin cycle. That is in lamens terms know as a safety idiot switch. It is designed so when the washer is spinning at those high speeds,na child or not to smart adult does not open lid and put hand in while spinning. SO, if switch goes out, of course it won't spin. Switch is cheap , under 20 bucks at any appliance parts store, and they even can tell you at store how to putnin yourself by showing on one of there washers on display. Let me know if I nailed it!! Thanks Mike
Posted on Jun 09, 2011
caroldon
  • 17130 Answers
SOURCE: The washer fills agitate but won't spin & drain
Possible fault with the program controller unit. You need to check the program cycle outputs using a multimeter connected to measure the output voltage. On start the inlet should open and then close as the water level sensors works and then proceed to wash. So this much seems OK. Now in the next step the drain valve must open to drain off, then fill once again with the inlet working and water level being sensed. If there is no output in this section cycle then the prrogram controller has errors within the memory . You can remove the panel and reset all connectors and connections.
Posted on Oct 30, 2011
My roper top load washer model rtw4440vq fills with water but wont wash, spin or drain
see this causes and fix it. God bless you
Motor Coupling If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and
Drive Belt If the washer won't spin or agitate, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin or agitate properly.
Drive Motor If the washer won't spin or agitate the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged, replace it.
Stator Assembly If the washer won't spin or agitate the stator assembly might be burned out. The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Door or Lid Latch Assembly If the washer won't spin or agitate the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't spin or agitate the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin or agitate the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
Sep 30, 2012 | Roper Washing Machines
My roper RAX4232KQO washers but won't drain. What could be causing this?
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 27, 2011 | Roper RAX4232KQ Top Load Washer
Washer won't drain or spin but runs normally otherwise
Check the lid switch. That's most likely your problem
Aug 25, 2011 | Roper RAS6233KQ Top Load Washer
Good evening, My Roper washer RAX4232PQ0 will not spin...it seems to drain OK but won't spin...can you offer any help? Thanks!
Jun 09, 2011 | Roper RAX4233PQ Top Load Washer
I have a Roper ( RAS7133RQ4 ) washer It will not spin. It does everything else. Can you help??
You say it doesn't spin. Does this mean it also doesn't drain? If it doesn't spin or drain, then you probably have a bad lid switch, if it doesn't spin but does drain, then your problem is in your tub drive clutch.
Hope this helps
kcomp1863
Jan 12, 2011 | Roper RAS6233KQ Top Load Washer
Washer does not drain and spin
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 20, 2010 | Roper RAX4232KQ Top Load Washer
Model ras8445jq0 wont spin safty switch is good
how did you check the switch? Does it try to spin? Does it agitate?
Nov 08, 2009 | Maytag Washing Machines
I have a roper washer model#RAS8445JQ0 it washes but won't spin,could it be a relay or timer ?
most likely lid switch try pressing down with pencil if switch not completely broke.. if it works replace switch
Sep 06, 2008 | Roper Washing Machines
Oct 23, 2007 | Roper RAS8445KQ Top Load Washer
Washing Machines Logo
43 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
