Question about Xerox PHASER 3635MFP 35PPM NETWORK PRINT Multifunction Monochrome
System fault 0: file MscSSM_Job.c, line - Xerox PHASER 3635MFP 35PPM NETWORK PRINT Multifunction Monochrome
2 Suggested Answers
SOURCE: system fault o file osal-psos-c,line1582,task jmts
bad hard drive or firmware call service to reload
Posted on May 28, 2009
Need to reset or eliminate 2nd time
Note: Wrong procedure will affect your computer startup settings so be careful in doing this steps.
Follow this steps:
  1. Click Start menu from your desktop screen
  2. Choose and right click on My Computer
  3. Choose Properties
  4. Go to Advanced tab
  5. Click on Settings button under Startup and Recovery
  6. In Startup and Recovery window click Edit button
The notepad boot.ini file looks like this one
http://lh4.ggpht.com/ciprahkapa/RwYQCqUnrQI/AAAAAAAAAIg/q9E-gZ6W_L8/change%5B3%5D.jpg
Your default operating system is:
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /noexecute=optin /fastdetect
as shown in:
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS
You'll see the second line containing
multi(1)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional"
or other operating system like Windows Vista
You have to delete this second line from multi..... to the end of the line that contain a second boot of your windows
Then click File Menu > Save
Close the notepad file (boot.ini)
Also refer to this information for some explanations to understand more about boot.ini file
http://vlaurie.com/computers2/Articles/bootini.htm
Jan 16, 2010 | Computers & Internet
MadDog MD-16XDVD9 could not perform end of disc-at-once
Have you tried checking your basics ?
Firmware ?
ASPI ?
Disk Defrag ?
IDE location ?
Jumper settings ?
What type of media are you using ?
What programs are you using ?
Exactly where are you and what are you doing when your error occurs.
What are your PC's specs ?
Do you have any Roxio products installed on your PC ?
Please answer ALL of the above - if you don't know, say so, don't make something
Oct 20, 2009 | Computers & Internet
Sir i write a cd i get this error somu 4C85-1000-0805-6481-407K-8KE9-**** Windows XP 6.0 IA32 WinAspi: - NT-SPTI used Nero Version: 7.10.1.0 Internal Version: 7, 10, 1, 0 (Nero Express) Recorder: ...
turn off buffer underrun protect in neros settings. It gives back the wrong info to nero causing it to crash. Contact nero about the issue. there may be a patch on the nero site to fix it.
Aug 30, 2009 | Acer Aspire 4720 Notebook
Sharp Actius AL27 strange DVD burning problem - The drive will burn a DVD+RW at 4x. A cheap (Imation) DVD+R burns OK, but a good 16X DVD+R (Verbatim) tries to burn at 2x and fails a few minutes in. This...
man it's not a condition that if the DVD Bulck writeen on it 16X that ur DVD writer will burn on this speed.
always don't try to burn ur DVD on maximum, always use the previous speed or the last previous one
ok good luck
Jun 17, 2009 | Sharp Actius AL27 Notebook
Burn fail or cd skip
Kind of sounds that way. They are pretty inexpensive now days, and simple to install.
Good luck
Mar 17, 2009 | Gateway M680X PC Notebook
Booting
the following id taken from my own XP media centre laptop.
line 1 [boot loader]
line 2 timeout=30
line 3 default=multi(0)disk(0)rdisk(0)partition(2)\WINDOWS
line 4 [operating systems]
line 5 multi(0)disk(0)rdisk(0)partition(2)\WINDOWS="Windows XP Media Center Edition" /noexecute=optin /fastdetect
ignore the "line 1,2,3 etc" I added them for clarity the formatting in this answer pane messes up the last line.
also before you get to edit the start up file make sure that the default operating system listed is the sae as line 5 starting from the "
hope this helps.
Nov 08, 2008 | Microsoft Windows XP Media Center Edition...
Burn error
You unit is faulty.. replace the unit with a new one. The CD Write Laser has probably "Burnt Out" or perhaps the "Quadrant Detector" has faulted.. either way a new unit is only way solve ya problem ... sry :(
Sep 03, 2007 | HP Media Center m7250n (ED842AA) PC...
YAMAHA CRW8424 gives Track following error..
PROBLEM DEFINITION: Basically, it is a hardware error that occurs when a drive is not capable of following a data track on a CD-R or CDRW or on the other hand, poor power flow may cause the problem SOLUTION: 1. Try use another disc, a disc with a different band. 2. If one doesn't work, you may have to open your system and use a different power connector, making sure no other devices are using the power connector in the same strand. 3. Lastly, if neither the above doesn't work, you may have to send your drive in for servicing as the head may be dirty or misaligned.
Aug 05, 2007 | Yamaha CRW 8424 Burner
Xerox PHASER 3635MFP 35PPM NETWORK PRINT Multifunction Monochrome Logo
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
