Question about Yamaha Water Sport
Starter relay problem on 2008 yamaha jet ski fx sho
4 Suggested Answers
finish line
  • 207 Answers
SOURCE: Overheating YAMAHA XLT 1200 jet ski
you may have something clogged in a water passage but more than likley u have a bad sensor the sensor is located on the main exhuast if you go on the right side of the ski and look in the engine compartment it will be located at 9 oclock u will see it sticking out of the exhuast with one wire comming out after u run the ski and the buzzer goes off pull the seat and see if the engine is really hot if u can not touch it will be hot but it has to be very hot for the sensor to pick it up if u can touch the motor and exhuast it is a bad sensor
Posted on Jul 08, 2009
PWCYoda
  • 118 Answers
SOURCE: rear seat removal, fx yamaha jet ski, latch will not release the seat
As bad as this sounds its the only way. Grab yourself a 2x4 and a nice size prybar.
Lay 2x4 across the back grab handle as to not damage it then put prybar directly under seat latch and pop it up.
Posted on Oct 29, 2011
PWCYoda
  • 118 Answers
SOURCE: my 2004 yamaha jet ski fx 1100 wont start
sounds like either your fuel pump has gone out or engine has possibly skipped some teeth on the timing chain. make sure u have fuel pressure going into throttle body assy or if you have good hearing, you should be able to hear the fuel pump running for about 5 sec if u just tap the starter. also need to make sure youve got no water in the tank, so the easiest thing for u to check on your own would be to cut off the hose clamp at fuel rail and put the hose into a clear glass jar and tap starter. if it fills up then its probably not a pump, but if the fuel looks cloudy then you got water on there.
Posted on Oct 08, 2012
Yamaha waverunner fx cruiser sho
check impellor blades not bent ! scoop grate not bent ? wear ring not badly worn ?not got some rope or debrise on impellor ?
May 26, 2014 | Boating
Relay replace starter
if its xlt 1200 its inside the big black electric box at rear of engine ! unbolt it and remove the back cover !
Jan 10, 2014 | Yamaha Waverunner Xl 800 / Xlt 1200 Jet...
Won't start
Fuses in the electrical box?
Jul 18, 2013 | Yamaha 2006 WaveRunner FX Base
Jet ski start is not working
is the starter button putting out power to the starter?
Jun 29, 2012 | Yamaha Jet Ski Pwc Cover For Waverunner...
I have a Yamaha FX Cruiser HO (2010). The jet ski died in the water on me last week. I determined it to be a fuse. Replaced the fuse with the extra one and it burned out again. Any suggestions?
i have a 08 yamaha fx sho it keeps on freezing up in the water and dying of, i was almost 10 miles into the ocean and had to be towed by one of my fellow riders. whats causing this problem?
Jul 16, 2011 | Yamaha 12V Air Pump
How Do I Turn Off Or Rewind Hours On 2008 Yamaha 1100 VX Jet Ski..Thanks cdm2164@gmail.com
Mate.You buy a new jet ski or don't sell it to anyone that wants a true ski.I will put your i.d. on a list.If you left the key on,you should,ve said so.
Jun 15, 2010 | Boating
YAMAHA FX 1100 HO 2006 ROUGH IDLE WAVERUNNER
I have a Yamaha fx 1100 that starts real slowly the battery is fully charged but the bike sounds like its not got alot of power going to the starter can anyone help solve this also battery terminals are clean and not corroded
Jul 28, 2009 | Yamaha 12V Air Pump
Hi I have a 2009 Yamaha SHO i were just wondering why can you still hear some parts of the motor spinning after you have shut down the motor..
It is the supercharger slowing down from its high spinning cycle. Dont worry about it, because it is normal. Trust me, I asked the same question on my 2008 SHO. You have the same motor I do.
Dec 23, 2008 | Yamaha 12V Air Pump
Water Sport Logo
59 people viewed this question
Top Yamaha Water Sport Experts
Colin Stickland
Colin Stickland
Piyal Perera
Piyal Perera
Are you a Yamaha Water Sport Expert? Answer questions, earn points and help others
