Question about Bushnell SCOUT 1000 Rangefinder
Lcd screen is missing some spots in the display.
There is like haze spot
LCD Panel White Spot Cleaning Technique - YouTube
? 4:13
https://www.youtube.com/watch?v=0OzjLMKFYk8
Jun 9, 2012 - Uploaded by joegingCA
Simple Technical procedure on how to remove a white spotproblem of an LCD Panel. ... Don't like this video? ... How to remove liquid spots from LCD screen - Duration: 5:16. ... Building a liquid crystal display (LCD) - Duration: 13:49. ... 2:18:17. Samsung/Mitsubishi/Toshiba DLP TV Repair - Black & White ...Missing: 170s4fb ‎haze
LCD TV - Problem with white glow seeping in from edges - MyBroadband
mybroadband.co.za/.../349324-LCD-TV-Problem-with-w...
MyBroadband
Jul 12, 2011 - 15 posts - ‎9 authors
Results 1 to 15 of 17 ... After googling it seems this is quite a common problem withLCD panels, though I .... Earlier this year I read that Philips have sold off their LCD TV... Yeah, something like that, unless demo stock is treated differently? ... bleeding from the edges as well as in the middle of the display.Missing: 170s4fb
How to Fix LCD Monitor Ghost images - MadeByMark.com
Jan 14, 2016 | Philips 170S4FB 17" LCD Monitor
LG W2261 VP HDMI problem, 1920:1080 doesnt fit right, there is 2cm dark screen at the edge of the display Got drivers installed for analog -vga and digital -hdmi Tried the buttons on monitor...doesnt...
This problem seem to be the LCD screen have dead pixels or a bruise spots on the LCD screen itself that why you have dark spot or spots on the LCD Screen.This problems can't be repair because this problems doesn't causes by the electronic circuit boards.Tried move the monitor as an angles to the right or to the left might help some lessen the dark spot on the LCD screen that all you could do.If this problems is a very dard bruised spot will not help all or if it is dead pixels on the LCD screen itself.
Nov 21, 2012 | Computers & Internet
Black spot on tft screen camera nicon s5100
black spot means something bad with your lcd screen. it will not display the picture perfectly.you can change another one lcd. the lcd screen for nikon s5100 is full new and with backlight. that means it will protect well if it is with backlight.
www.skiliwah.cn/
http://www.digitalcamera-parts.net/
e-mail:e-8090team@hotmail.com
Aug 22, 2011 | Cameras
There is a brownish spot near the bottom of the screen - almost looks like a burn spot about 6" by 2.5" on my Samsung LCD 40" tv screen.
U have a burn in image to LCD screen panel like display the same image too long like hours in and out.Sorry this problems,have to live with it.Can't remove burn in images problems.
Mar 22, 2011 | Samsung LN40B530 40 in. LCD HDTV
A dark spot in the middle of the LCD display screen.
It can't be removed, unless its a dirt spot and then you can take a paper towel with some glass cleaner on it and then you can wipe off the screen.
Try that anyway and if it doesn't come off then you know the LCD is going bad on you and you'll have to get it replaced eventually.
Sep 03, 2009 | Dell Computers & Internet
Faint white spots on macbook pro lcd screen
If the spots remain in the same place I'm sorry to say no. Be careful what you clean the screen with. I'm a fan of a warm wet damp only rag. Using alcohol or other cleaners may damage the surface. There are also cleaners available at local stores. You don't need anti-static on an LCD display. The spots can be from pressure on the display applied at some point even if that pressure happens when closing or transpoting your laptop.There is no way to fix it.
Sep 18, 2008 | Computers & Internet
White bright spots on screen
These kind of patches or spots are called as Dead Pixels.
If you find any thing that doesnot change colour along with the other part of the Display according to the image, those spots are referred as Dead Pixels where the LCD needs to be replaced.
Contact your nearest HP Authorized Service Center and find the cost to get the LCD replaced.
Aug 03, 2008 | HP Compaq Presario v3000z Notebook
Bubble-like spots on lcd
Your Licquid Crystal Display appears to have gone bad... much like a dead pixel in a TV, you get a dead spot on the display of your lcd that looks like a bubbe.
You need to have the screen replaced or you will have to live with the bubbles. If the PC is still under warranty I'd send it in for repair. You may be able to pick up an inexpensive replacement on eBay, but make sure you are careful if you replace the screen yourself.
Apr 27, 2008 | Acer TravelMate 4150LCi Notebook
Green spots
Hi there
Sounds like you've got a faulty LCD.
Unfortunately it will need replacement before it will get any better
Dec 15, 2007 | Hitachi CP-S225 Multimedia Projector
Bushnell SCOUT 1000 Rangefinder Logo
Top Bushnell Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you a Bushnell Optic Expert? Answer questions, earn points and help others
