Question about Samsung SCX-5635FN All-In-One Laser Printer
Had a paper jam in my scx-5635, cleared it but the error still comes up and won't let me scan anything
SOURCE: [no paper] in SCX-4200
there 9is a paer sensor which senses when there r papers ,prob might b that either it is not functioning or on of the sensor is depressed
Posted on Jul 31, 2007
  • 3422 Answers
SOURCE: Samsung SCX-4521 "Paper Jam 2" won't clear
Hi there have you tried the door at the back of the machine as there maybe a piece stuck in the fuser unit. If not open the back door and check that there is a small black lever in the middle of the two rollers sticking up as this is the sensor arm that determines that there is a paper jam or not. If this is still there then the paper will be stuck just after the paper cassette within the paper path.
Hope this helps you.
Goodluck,
please don't forget to rate me as fixya..
Posted on Feb 01, 2008
I had this problem too. For me the answer turned out to be the paper sensor in the back part of the machine, behind the little back door just under the top part of the machine. This sensor hangs down from a thin rod that runs across the width of the machine, and is held in place by a small spring that encircles the same rod that supports the finger. The finger had apparently gotten moved so the spring was dislodged from its proper place. I was able to rotate it around the rod with my finger & get the spring moved back to where it should be. This seems to have cleared the problem--I'm keeping my fingers crossed.
Posted on Feb 04, 2008
SOURCE: dispaly pannel showing scanner error & also not scanning SCX-4300
my scaner error what i can do in samsung scx 43000
Posted on Feb 09, 2010
  • 360 Answers
SOURCE: Samsung scx-4521F giving me document jam error
hello please check it properly.some time their have a small piece of paper.
or clean adf unit & service.
Posted on Sep 09, 2010
My samsung scx-4623f always "paper jam in exit area" every time i print even though i always put out the jammed paper in the exit area.
While Samsung SCX-4623f printer always "paper jam in exit area" you get paper checks or trigger sensor paper cup
cong ty bao ve support
good luck
Jul 07, 2014 | Samsung SCX4623F Laser All-in-One Printer
Lanier 5635 Sorter
Under user tools, system settings make all prints, copies to come out in internal tray, the front and rear covers have to come off to remove screw 1 each side the SC code is shift tray motor error
Dec 18, 2013 | Lanier Office Equipment & Supplies
Samsung scx 5635 has error code 02-000 is this a fuser problem and how do you reset.
I have a samsung scx-5635 Fn and im getting an error message of 02-0000. what does this code mean?
Sep 12, 2011 | Samsung Office Equipment & Supplies
Samsung SCX-4521F All-In-One Laser Printer states there is a document jam and toner empty but no documents are jammed and the toner has ink....cannot find the paper sensor to check if its causing the...
hello try to do this
press #1934 and right arrow key disply appear ready tech press menu &left arrow key display new cartridge press enter button twice. then toner empty message is over do previous simulation for go normal condition.
paper senser is located at back side of the machine remove backside cover and see heater unit near the hot roller paper senser is located
Aug 19, 2010 | Samsung SCX 4521F All-In-One Laser Printer
Paper Jam 2 displays however there is no paper jammed in the machine
This is caused by exit sensor or the problem may be a small peice of paper is still remaining. Or if its software error which will be cleared from service center. Please approach them.
Nov 25, 2009 | Samsung SCX-4216F All-In-One Laser Printer
I was wrong...
This is a common issue if you are using generic or remanufactured toner cartridges. However, if you are using authentic Samsung cartridges, then check that the paper size is correctly defined in the application you are printing from (i.e. Word, Excel, etc.). If both issues are ok, then my last guide is to take the unit to an Authorized Service Center and have the paper path senors replaced.
Oct 30, 2007 | Samsung SCX-4100 All-In-One Laser Printer
Jul 29, 2007 | Samsung SCX 4200 All-In-One Laser Printer
Samsung SCX-5635FN All-In-One Laser Printer Logo
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
