Brady minimark beeping
Brady TLS2200. I turn it on and get a error CHKSUM
Once again, first thing in a GOOGLE search!
Brady TLS2200 manual
https://www.cableorganizer.com/images/brady/tls2200/manual.pdf
Page 77 error messages
Error in Checksum
The software was improperly installed on your printer. (or lost or corrupted in the memory.)
Contact Brady Technical support group.
Aug 03, 2016 | Brady TLS 2200 Label Printer
Print preview looks fine but just get a blank label from label mark. prints ok when not done from pc
You likely need to use Brady's software to create the label on the PC, and your PC will need the correct printer drivers to communicate with the Brady. The software and drivers should be available from Brady.
Apr 02, 2015 | Brady TLS 2200 Label Printer
Need activation key
If you have misplaced your key, you will need to contact Brady. They should be able to find it for you.
Customer Tech Support Brady
Jul 23, 2014 | Brady LABELMARK SOFTWARE for PC
I looking Print head for Brady Model 1344 please find to me .
The Brady 1344 printer is really a Datamax E4304 printer with 300dpi print head. A google search will produce numerous companies selling this printhead
Hope this helps
May 15, 2011 | Brady 1344 Thermal Label Printer
I am trying to find a printband for a Brady THT 2034 printer...is this actually a Zebra model that has been rebranded?
In the heading it says Brady BP-THT-600X+ , but in the comments it refers to a Brady THT 2034.
The THT600X+ is zebra, The THT2034 is datamax. I have printheads for both. www.clearprintsolutions.com
Aug 24, 2010 | Brady BP-THT-600X+ Thermal Label Printer
Brady ID Pal. Display says:
Brady printers have a sensor that reads information from the cartridge. The printer will not work if a connection cannot be made to the cartridge.The most common cause of failure is in the cartridge and switching to a different cartridge usually fixes that problem. Having the same problem with two cartridges is starting to indicate there is a failure in the printer, although it is possible (but not likely) to have two cartridges in row fail. A good first step is to be sure the printer is clean. If that doesn't work you'll most likely need to send your printer in for repair. A good source of free tech. support for the Brady ID Pal is Graphic Products. They even help people who are not their customers, They also do Brady printer cleaning and some repairs. They have an online for for requesting tech. support located at: http://www.graphicproducts.com/request-support.php or you can call 1-888-326-9244.
Feb 08, 2010 | Brady ID PAL Thermal Label Printer
87 people viewed this question
k24674
jasbo
jasbo
