Gom player Script error EXP:lang=GetLanguage(); CODE undeclared function
IR 2016i Black and White Copier i got this proble .Turn the main power .switch (on the main unit's side) OFF & OnNagain . error code no is :E000007-0000
E007 0000 Fixing film sensor failure
Main Cause/Symptom : The fixing film sensor is faulty
Countermeasure :
- Check the connector of the fixing film
sensor.
- Replace the fixing film sensor.
- Replace the DC controller PCB.
Nov 07, 2011 | Canon iR 2016i Black and White Copier
My download movie not playinng
It is possible that you do not have the video format downloaded program within your PC. So check on the type of file that was downloaded and if the PLAYER FOR THIS FORMAT is downloaded and installed , you will be able to play.
Sep 27, 2011 | Computers & Internet
Every time i open the GOM player it would ask for "FIND codec"
GOM Player includes many codecs (XviD, DivX, FLV1, AC3, OGG, MP4, H263) Along with different media format such as AVI, MPG, MPEG and DAT, GOM Player also supports streaming Windows media format (WMV, ASF, ASX).
Possible Reason:
* Ensure that you have downloaded a genuine version and not a broken file, which is likely to miss some codecs, GOM is a FREE media player with popular audio & video codecs built-in. So you won't need to install separate codecs for most videos. For those videos that require a separate codec, GOM Player will find one.
* Without the appropriate codec, you'll be prohibited from playing AV files/the codec for which the file you are playing is missing (playback error), which prompts you to "Find Codec" screen. In the case you need other codecs, the 'Find Codec' popup will assist you in searching for the correct codec to play your file. If you didn't find any: first reason is likely to be the issue.
Fixes:
*Search Result will be shown on a new internet page. Once youve found it, simply download and install to watch the AV files.
Jan 12, 2011 | Computers & Internet
I have a gom file in my emails that I can't open on my computer, But I do have gom media player...I downloaded the newest version but it still wont open...
to open the file you should download the file to your computer first. after that if the gom player doesnot work download atest vlc player from www.videolan.org & run the file. hope it will work.
Dec 15, 2010 | Gretech GOM Media Player
Codes
GOM Player is a free multimedia player no code is needed.
If you need additional codecs to play other Audio/Video formats, you can download from http://www.free-codecs.com/
Hope it helps.
Nov 15, 2010 | Gretech GOM Media Player
My gom player is looking for a codec to play my downloaded videos from you tube
Your GOM player might not be updated, or it simply doesn't support the format of the video that your playing. GOM playeer usually supports .3gp .mp4, etc ( usualy formats from cellphones ). Try downloading the FLV player, it usually supports alot of video formats.
Sep 17, 2010 | Gretech GOM Media Player
Gom player sound problem when i play film
may be the gom player itself has some problem try to download again and install from here http://download.cnet.com/GOM-Media-Player/3000-13632_4-10551786.html
Aug 20, 2010 | Computers & Internet
Computers & Internet Logo
328 people viewed this question
David Payne
David Payne
