Question about Garden
Stihl hs 61 carburator problem. I have problem
Stihl hs 61 carburator problem. I have problem with my carburator I Think? It will start for a few sec, in idle but then it dies when trying to rev it up. I have done factory specs. when adjusting H/L needles I also cleaned the carb and all its channels. the membrane looks good, what more can I do? Im thinking of bying a new carb but they are hard to find for me so any tip on where to get one?
  • 3567 Answers
SOURCE: when start go to rev it just dies
Remove the throttle stop adjuster and the air screw adjuster and spray carb cleaner in the holes.
Be sure to put these two screws back in the same hole they came out of. IMPORTANT > do not tighten these two adjusters down. Only screw these in until they LIGHTLY seat. Now turn each adjuster one and one half turns outward. Turn the pilot screw 1/4 turn counter clockwise. Check the float level. Before putting the slide back in the throat of the carb, move the clip on the jet needle one notch lower.Put the rest of the carb back together, clean the air filter and install the carb. Let the float bowl fill then start the engine. Adjust the idle speed with the Throttle stop screw. This process should get you back on the road. A “very helpful” rating for this answer? Thanks!
Posted on Jun 22, 2009
s_s_m_o_k_i_
  • 162 Answers
SOURCE: Lawn Trimmer wont reach full revs.
you might want to check the magnito for rust build up.
it also wouldn't hurt to check the float or maybe even the valves.
since you adjusted the idle and mixture ur probly gonna have to adjust them again to get them back where they should be especially if rust build up on the magnito is the cause of your problem.
it wouldn't hurt to check the fuel filter either.
Posted on Jul 27, 2009
  • 86 Answers
SOURCE: Won't stay running
HI. I THINK IF YOU PUT A KIT IN THE CARB I THINK THAT WILL FIX THE PROBLEM. JIMBO
Posted on Sep 15, 2009
  • 26 Answers
SOURCE: cuts out on acceleration
if you have over 200 hours on this FS 80 then you may need a valve adjustment(yes this 2-stroke has valves). if you wanna try to do it yourself it should be set @ 0.1mm @TopDeadCenter. my advice is take it to any stihl dealer and let them do it. its scheduled maintenance
Posted on Feb 27, 2010
SOURCE: stihl saw TS400 will not get fuel through,NON START
how much fuel can be put into a stihl saw ts 400 and how long will the fuel last while in constant use
Posted on Apr 20, 2010
My HS 45 seems to drip oil while cutting, I think it is damaging plants. Is it because there is too much oil in the fuel mix?
Fuel mixture for that model is 50 to 1. Stihl also sell their own premixed fuel and oil which is Ethanol free and non aromatic.
I wondered if it has a blade oiler, but it doesn't. I does however have a gearbox with oil in it. I wonder if it is leaking. Do you know where the excess oil is coming from?
You model is listed here and the Manual and details of the fuel are on his page.
STIHL HS 45 HomeScaper Series Hedge Trimmer
Oct 04, 2016 | Stihl Hs45, Hs 45 Hedge Trimmer 450mm 18"...
Repair manual for a Stihl HS 86C petrol blower/vac/shredder
According to my Stihl technical reference this is not a blower, vac, shredder. Model number wrong. HS prefix is for a hedger.
Feb 11, 2015 | Stihl Garden
Why is my Stihl HS61 not firing up?
Try cleaning out the carburettor and make sure u are using new fuel and the correct mixture
Jun 28, 2014 | Stihl Trimmer Blower Hedge Pruner...
Need a new Stop Switch
You might be able to obtain a replacement switch directly from Stihl
May 06, 2013 | Stihl Hs 60, 61 Hedge Trimmer Stop Slide...
Air and mixture screws setting hs61
Standard Carb settings on Stihl equipment are H 3/4 turn out anticlockwise from full screwed in position. L 1 full turn out anticlockwise from full screwed in position. :)
Nov 02, 2012 | Stihl Bg Fr Hs 60 61 65 72 74 76 80 81 86...
Stihl 250 chain saw will not pick up speed
Is the chainbrake in the 'off' position.? Pull the black hand guard back to release the 'chain brake'.
Oct 16, 2012 | Stihl Bg Fr Hs 60 61 65 72 74 76 80 81 86...
Why my stihl fs 250 not accelerate
Have you removed the chain brake.? Pull back the front 'black' hand guard to release the chain brake.
Jul 21, 2012 | Stihl Bg Fr Hs 60 61 65 72 74 76 80 81 86...
Stihl HS 80 stops after a while
Check the fuel tank vent, it could be creating a vaccum in the fuel tank which is stopping the carb from drawing up the fuel. Then you're having to wait till the pressure in the fuel tank equalises again.
Jun 22, 2012 | Stihl Ignition Coil, Module Air Gap Guage...
Why does my Stihl BG 86 Leaf Blower not accelerate?
remove the muffler and run it if ok open the muffler and clean the screen in side they build up with carbon and stop exhaust flow
Jun 15, 2012 | Stihl Bg Fr Hs 60 61 65 72 74 76 80 81 86...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
