I NEED A SERVICE MANUAL FOR A FUJITSU SIEMENS AMILO SI 2654 NOTEBOOK THANKS
  • 101 Answers
SOURCE: fujitsu siemens amilo pro keyboard replacement
Hi is that you want to replace the existing keyboard from your mom's laptop ? if so right above the keyboard you will find a removable plastic panel (it is fragile breaks very easily so be carefull ) which would secured in place with snap on plastic locks or 3 screws would be securing it in place which you can see on the rear of the laptop , if the battery compartment is under the top portion then remove the battery you can see these screws . In any case please take your OWN TIME TO ANALYZE and only then attempt this. If you are succesfull in doing this then remove the other screws visible that holds the KB in place and lift up the KB slowly because the connecting cable is flexible PCB and you could easily TEAR IT OFF if you pull hard . The Connector also needs lot of attention - very thin and small release the side catches by lifting it with a watch screw driver very slowly else you will end up breaking it . If you have come to this stage GREAT replacing KB is reverse of all this procedure.
Posted on May 10, 2008
nyilasrobert
  • 627 Answers
SOURCE: Fujitsu Siemens AMILO Pro V2000 PC Notebook
there is no default bios password
all i know at the some fujitsu laptops if you enter 3 times wrong bios password the computer locks
This is a security issue
Posted on Jul 09, 2009
SOURCE: I have a Fujitsu Siemens Amilo Li 2727. The
Try downloading the automatic driver update tool from the website.
This should normally fix this problem by updating all drivers.
Posted on Aug 23, 2009
  • 74 Answers
SOURCE: remove bios password
A. By Using the Motherboard Jumper:
In most motherboards CMOS battery is soldered, which makes it difficult to remove the battery. In this case we use another method.
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
B. By Using Software:
I have found that BIOS/CMOS Password Recovery Tool is the most effective.:
BIOS/CMOS Password Recovery Tool is a program that works instantly to remove any lost or forgotten BIOS/CMOS password. Simply boot your PC to DOS and execute the program, and get access to forgotten BIOS/CMOS passwords in just seconds
BIOS/CMOS Password Recovery Tool Service: http://www.biospasswordrecovery.com/
Posted on Dec 16, 2009
SOURCE: my fujitsu siemens amilo notebook screen black.
Check num lock key of laptop press num lock if numlock key is on and off when you press it then dispaly working fine only issue with screen resolution .
For that when you power up the computer press F8 key then enter in enable vga mode.
Then go to start menu ->control panel->display->settings.
Change screen resolution to 1024*768 then apply and ok.
But if num lock is constant when you press numlock key then you need to refix RAM memory.Open back cover of laptop then refix RAM memory.
Then check if still same issue then pull cmos cell from motherboard then check again if still same then try with another RAM .
When you power up the computer press F1 or F2 or "del" key if you are able to see bios screen then you not need to open back cover of laptop only make sure SATA is disabled and your harddrive is detected in bios.
Let me know if you need further assistance.
Thanks for using FixYa.
Posted on Dec 19, 2009
Fujitsu amilo Si3655 laptop screen coming blank
It Sounds Like The Problem Is Caused By Settings For A
Screen Saver You Have Enabled! If This Is Correct Then
All That Is Needed Is To Ajust The Settings Or Disable It
Completely! See The Manual For Both The Laptop And The OS For Further Details!
Apr 02, 2014 | Fujitsu Siemens Amilo Si 3655 13.3" Laptop...
Fujitsu Siemens Amilo Si 3655 disassemble
Why Do You Want To Remove The DVD Re Writable Drive
In The First Place ?
Don't You Like The Idea Of Saving Your Data To A DVD Or CD Rom Disk ? I Know I Do !
Feb 15, 2014 | Fujitsu Siemens Amilo Si 3655 13.3" Laptop...
Have just picked up a Fujitsu Siemens Amilo pro Vo2110 but no speakers, where can I buy? Thank you
you can use any speakers to your Fujitsu Siemens Amilo. the best thing that u can do is bring the notebook with you so you can try the speakers.
Apr 02, 2010 | Fujitsu Siemens AMILO Pro V2010 Notebook
Connection to wireless
There is any wireless adapter showing in the control panel.
According to the laptop specs, this laptop did not come with wireless capability. You need to purchase a wireless notebook adapter for it or us it with a network cable.
See the specs on this link:
AMILO-D-1840-FUJITSU-SIEMENS-Laptop-220304">http://www.twenga.co.uk/specs-AMILO-D-1840-FUJITSU-SIEMENS-Laptop-220304
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Apr 07, 2009 | Fujitsu Siemens AMILO Pro V1000 Notebook
No drivers
Hello there
I understand you need drivers for Fujitsu Simens Amilo Pro V2000 Notebook. Please click on the below link or copy and paste it in the address bar of a web browser. In that page enter the product name and click ">>" next to the search bar. You will get all the drivers for your Notebook model.
http://www.fujitsu-siemens.co.uk/support/downloads.html
Thank you
Feb 18, 2009 | Fujitsu Siemens AMILO Pro V2000 Notebook
I need a manual to help me replace a motherboard
http://www.fujitsu-siemens.com/Resources/168/1477897752.pdf
http://support.fujitsu-siemens.com/com/support/manuals.html
hope this helps
Dec 29, 2008 | Fujitsu AMILO Pro V1000 Notebook
Silviu bd
Driverele pentru modelul tau le poti descarca de aici: http://support.ts.fujitsu.com/com/support/downloads.html
nu uita sa selectezi mai intai sistemul de operare pe care il folosesti. Bafta.
Oct 22, 2008 | Fujitsu Siemens AMILO D-7830 Notebook
Amilo pro 2030v faan
We did not find any results for Fujitsu > AMILO Pro V1000 (FAP:GBR-147150-H01 ) needing a fan for my laptop computer. Other searches you may want to try: Related searches Click on the Link above, Good Luck.........Please dont for get to Vote, Thank You.
Dec 15, 2007 | Fujitsu AMILO Pro V1000 Notebook
Computers & Internet Logo
79 people viewed this question
David Payne
David Payne
