Question about Hayward 116k BTU HeatPro Digital Heat Pump HP21003T
HAYWARD HEAT PUMP POOL HEATER FAN WON'T SPIN - Hayward 116k BTU HeatPro Digital Heat Pump HP21003T
  • Anonymous Apr 17, 2016
    If you cant spin it the berings are out and you need a new motor
  • 2,760 Answers
If your meaning the top mounted fan , if the compressor does run , and the top fan does not , fans do go bad there not too expensive and don't require a rocket scientist with a truck load of tools to replace them , two biggest things to look for are Height of fan away from hitting solid object (compressor) and match wires color for color (turn power off !!!) , replace capacitor as well they aren't included with motors there extra !!! new motors do say on package what size capacitor to buy (it might be different than old one?)
Posted on Apr 19, 2016
SOURCE: pool pump is very loud
loud pumps are most times caused by bad bearings and need to be replaced or better yet replace the whole pump new bearing cost about $100 to replace but not always easy to find someone to do hope this helps
Posted on May 13, 2009
  • 156 Answers
SOURCE: The pump only hums when plugged in. Any suggestions?
It sounds like the impellor is locked. Take this part off and then see if the pump is turning but before you do, some of them have a big screw driver slot in the shaft. If it does, turn it to see if you can free the impellor. I have done this many times and they will continue to work for years after. They just get stuck from rust, etc. and also being frozen a little. Hope this helps.
Posted on Jul 06, 2009
thepool
  • 78 Answers
SOURCE: My hayward pool heater is displaying P5 and the
You heat pump is actually displaying "PS" for Pressure Switch. Either there is not enough water flow or the switch could be bad. If you have a sand filter, put the filter head in the "bypass" mode and try again. If the heater works, filter problem. If not, heater problem. Instruction book found here: http://www.haywardnet.com/products/Manuals/pdfs/Manual122.pdf
Posted on Apr 21, 2010
thepool
  • 78 Answers
SOURCE: Heat pump will not start
Could be a firmware issue and require a new mother board. Unfortunately, you probably have done all you can on your own. Time to call the local HVAC service person...
Posted on Apr 22, 2010
thepool
  • 78 Answers
SOURCE: Hayward pool heater - p5 code
The code is "PS" for Pressure Switch and means there is insufficient pressure to operate (low flow) or the switch itself is bad.
Value position to heat pool
turn the valves so ALL the water goes through the heater and back to the pool
Apr 17, 2014 | Hayward Pool Products Pool & Spa
My Hayward H400 will not turn on
Does the heater sound like it is trying to fire? (Fan on, clicking sound). Check your filter pressure. If it is high, it may be causing the heater not to fire because the heater doesn't know the pump is running.
Apr 12, 2014 | Hayward H Series Pool & Spa Heater 400k...
Hayward h300 pool heater won't start
"LO" is simply informing you that the Heater is not sensing proper water flow through it! A Flow Problem.
A special sensor, called a pressure switch is this source. But... That does not mean it is bad - No, it is in most cases just doing its job!
Most common reason - Dirty Filter.
A good cleaning of the cartridges, or maybe a breakdown and recharge of a DE Filter, or a good cleansing backwash of your sand filter, will remedy this situation.
Or... Check for any OTHER reason or situations water flow may be reduced through the heater:
  • enough water in pool or spa?
  • If you have a weir gate in skimmer, is it stuck in the UP position?
  • Are any valves closed?
  • Do you have a bypass valve at the heater?
    • If open, this will reduce the amount of water going thru heater, close it to the point, LO goes away.
  • Could be debris in front of Pressure Switch, in the copper tubing
    • Unscrew and remove pressure switch, turn pump on. But first, align end of tube so that when water squirts out it will shoot out from heater and not onto electronic heater components!
  • If all above is good, you may have failed pressure switch?
  • Etc
Good Luck - hope this helped.
Sep 17, 2012 | Hayward H-series Electronic Gas Pool...
Hayward HP error
check voltage coming in if ok check voltage after transformer if ok check safety circuit pressure switch voltage both leads if not replace or check for plugged copper line
May 04, 2012 | Hayward Heat - Pro 2100 Heat Pump Pool...
My hayward pool heater is displaying P5 and the fan is not moving. what does this mean?
Apr 08, 2010 | Hayward 116k HeatPro Heat Pump HP3100
Hayward Pool Heater is not working. Fan turns on, but that is it.
I had the exact same problem. The propane guy had to come back and put the regulator right by the heater instead of being on the tanks. Did this and boom heat. This was after 6 days of calling and calling hayward tech and service guy. Hopefully it will continue to work :/
Jun 07, 2009 | Hayward H Series Pool & Spa Heater 400k...
May 26, 2009 | Hayward 116k HeatPro Heat Pump HP3100
Hayward 116k BTU HeatPro Digital Heat Pump HP21003T Logo
108 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
