Xerox 5335 User prints from Pastel, no printouts at printer, only one page printed displaying error: ColorSpaceMismatch.
SOURCE: Print server won't speak to printer
I'm having much the same problem with my IOGear print server and my Vista ntebook.  I have 2 printers USB connected to my print server, and the print server ethernet connected to my router.   If I ethernet connect my notebook everything is just fine, but as soon as I go wireless my IOGear print server software does not see the server.  Vista continues to see it and I can connect to it for admin purposes using its IP address through Internet Explorer.  Solve Mac's problem and you'll probably solve mine as well.
Posted on Oct 24, 2007
  • 2072 Answers
SOURCE: Xerox 4150 Multifunction Printer
From my expreiences with that product, you should reload the machine software.
If the machine is less than one year old call for service it is under warranty.
If not you can go to www.xerox.com and download the firmware,10.100.32.000.
It will resolve many software issues on that product.
You can download it to your computter then upload it to your machine.
Some of the versions of software on that product have some issues. Most are resolved with that version.
You will also need to download the 4150 printer setting utilities if you are going to do this yourself.
You may lose your LDAP settings, so be sure you print out a settings or configuration page before you do the upgrade.
Posted on Feb 25, 2008
SOURCE: Error timeout
There is a firmware update for the Phaser 8500 that fixed this for me.
Posted on Aug 06, 2008
SOURCE: 3 dasrk vartical lines printing while taking xerox/printout
clean the narrow glass which is previous to bigger one, using a cloth dampened with water.
Even though the problem is not solved, clean the charger Roller with a dampened cloth. allow the chagrer Roller to dry. and then you can try to take copies.
Posted on Nov 26, 2008
  • 65 Answers
SOURCE: Xerox M15 PCL6 error
I would go to the xerox website and try downloading the PCL5e driver. It works just as well and even better in most cases. I hope this helps.
Posted on Dec 07, 2008
Xerox 7760 Wrong paper size error when trying to print to A4
First your computer selects the printer to output to, so make sure your default printer is selected.
Next, within your printer you may have selected a different page size for output as a default.
The printer it self should allow you to load and auto detect paper size. If this feature is not enabled see if it is a choice.
Also whatever you are trying to print check page setup in the program you are using make sure to ensure they match.
Sep 16, 2016 | Xerox Phaser 7760DN Laser Printer
Xerox 560 error code 127-212
Error Codes
If an error caused the printing to end abnormally or a malfunction occurred in the printer, then an error message code (***-***) is displayed.
If an error code not described in the following tables is displayed, or the problem persists even after you have tried the following solutions, contact the Customer Support Center.
Tip
If an error code is displayed, all print data of the printer as well as print data stored in the built-in memory of the machine is discarded.
Error Code: 127-212
Error Category: Print; Other Problems
Cause: Detected an internal print check error by the FreeFlow
Print Services Controller.
Remedy: Remove and reinsert the command/video cable between the FreeFlow Print Services Controller and the printer. Power off and on both the printer and the FreeFlow Print Services Controller. If the problem persists, call the Customer Support Center.
*** extracted from my Fuji Xerox Color 560 Printer - Printing Systems User Guide
*** I assume we have the same printer
Jul 13, 2012 | Lenovo ThickCentre M58p Desktop 7479A3U
Xerox workcentre pro 55 pcl xl error
We have a WorkCentre 7655 that has been working fine for ages but is now causing some issues. A user who is running Windows 7 32 bit edition is sending files to print (using the secure print function) - the system is reporting they have spooled fine to the printer - but when they go and release the document they are getting (more often than not) about 16 out of 21 pages (for example) and then a PCL XL Error (Subsystem: Text, InternalError 0x50, Operator: Text, Position: 8564). I have another document that 9 times out of ten will actually crash the WorkCentre completely and cause it to reboot mid way through printing.
The driver we are using is the latest: "Xerox WorkCentre 7655 rev 2.0 PCL6"
As mentioned the user is running Windows 7 - the printer is shared from a Windows 2003 Server which has the same version of the driver.
Jan 06, 2012 | Xerox WorkCentre Pro 575 - 550 Copier
The printer is cutting off my printouts on the right and bottom sides.
is it when u print to it or on copying? Make sure paper in the trays matches the control panel display,if u printing from any microsoft software ie word go to page setup (clk on the menu) the paper is A4 not american letter 8 1/2 X 11.
Mar 30, 2010 | Xerox WorkCentre PRO 128 Copier
Phaser 7760 dirty printing
Dear User,
This is a common problem of all laser printers, don't worry i will give you solutions for this. If you can able to remove the DRUM set from the printer and check that any power leak or not, IF yes clean it well and insert into printer again take a printout , afterthat also coming like dirty. So please change the drum and put a NEW DRUM. Your drum capacity is crosed beyond the limit.
I hope that my suggession will helpful to you, if yes please rate this ...
Feb 27, 2010 | Xerox Phaser 7760/GX Laser Printer
Unexpected size in tray 2
whenever i took printout of a multipage file of Powerpoint. Everytime i have to preses the ok button to proceed with the print. because every page an eror comes displaying on screen of printer "UNEXPECTED SIZE IN TRAY 2" when i press the OK button it start printing the page. everytime i have to press the ok button to take print out. For example if i give a print command to a file that is having 15 pages. i have to press 14 times the ok button to complete the printing of 15 pages. pls help me in this
May 14, 2009 | HP LaserJet 2840 Printer
PDF files only print in landscape
Found it! The problem was that Adobe was set to print with page scaling set to Tile. Even though you see the preview as portrait (with page setup AND printer setup also in portrait), for Tile, it prints in landscape.
User said this fixed it.
Mar 25, 2009 | Adobe Acrobat® 8.0 Standard Full Version...
I have a HP Professional Deskjet 1220C. It starts off printing full colour images ok but about a quarter of the way through it starts printing in red. Please help me.
Try the following below if it continues to print in red half way through then either your ink carts have expired or something is wrong with them if you are using coral draw to print images there is know problems with that I have listed the solution to that as well. please tell the results of the test page as well please. and also I have included a few other tests please run through these. The sample page can be used as a quick check of the image quality from the black and color print cartridges. Unlike most printing, this page prints from the bottom of the page to the top for user viewing during printing.
  1. Turn the printer off and then turn it on again by pressing the POWER button.
  2. Press and hold down the RESUME button and release it when the Power light starts to blink.
The sample page can also be printed from the Toolbox (provided the Toolbox is installed) to verify that the printer is connected to the computer properly and that the printer and printer software are working properly.
  1. Double-click the Toolbox icon on the Desktop or run it from the HP Deskjet 1220C Printer program group.
  2. Select the Printer Services tab and click Print a Test Page
Printing the diagnostic page The information displayed on the diagnostic page includes the printer model, serial number, service ID (born-on date), firmware revision, total page count and last error code (see Figure 2). If an error code (hex) number is displayed, it represents the last error that occurred regardless of whether the problem that caused the error has been fixed and the printer is presently operational. To print a diagnostic page see the following:
  1. Turn the power on.
  2. Press and hold down the POWER button.
  3. While holding down the POWER button, press the RESUME button four times.
  4. Release the POWER button.
Running the pen recovery diagnostic test If printouts have incomplete text or graphics that are not corrected by cleaning the print cartridges, use the pen recovery diagnostic test. The pen recovery diagnostic test is a three-level cleaning procedure that attempts to clear blocked print cartridge nozzles. The tests can be run either from the Toolbox under Printer Services or by pressing the button sequences below. The Level 1 print cartridge cleaning is a light cleaning mode. Use this level first to clear blocked nozzles.
  3. While holding down the POWER button, press the CANCEL button twice.
After running the Level 1 print cartridge cleaning routine, run the nozzle pattern test explained in the "Printing the nozzle pattern test" section below to verify that the cartridge has recovered. If no irregular gaps are present on the printout of the nozzle pattern test, the print cartridge has recovered. If there are irregular gaps in the printout, run the Level 2 pen recovery. The Level 2 cleaning is an intermediate cleaning mode to be used if the Level 1 mode does not recover the nozzles.
  3. While holding down the POWER button, press the CANCEL button twice and the RESUME button once.
After running the Level 2 print cartridge cleaning routine, run the nozzle pattern test explained in the "Printing the nozzle pattern test" section below to verify that the cartridge has recovered. If no irregular gaps are present on the printout of the nozzle pattern test, the print cartridge has recovered. If there are irregular gaps in the printout, run the Level 3 pen recovery. The Level 3 cleaning is the most intensive cleaning mode that takes about two minutes to complete. Use this level as a last resort in recovering clogged nozzles. This routine uses a considerable amount of ink.
  3. While holding down the POWER button, press the CANCEL button twice and the RESUME button twice.
After running the Level 3 print cartridge cleaning routine, run the nozzle pattern test explained in the "Printing the nozzle pattern test" section below to verify that the cartridge has recovered. If no irregular gaps are present on the printout of the nozzle pattern test, the print cartridge has recovered. If irregular gaps still appear in the printout, replace the cartridge. NOTE: Do not use the pen recovery tests unnecessarily or the life of the print cartridge will be shortened. Printing the nozzle pattern test This test prints a pattern to determine which nozzles, if any, are clogged or not firing and can be used to verify a successful cleaning routine (see Figure 3). Look for irregular spaces or gaps in the test pattern; these indicate faulty nozzles.
  3. While holding down the POWER button, press the CANCEL button eight times and the RESUME button four times.
Printing the calibration page This test provides calibration of the print cartridges. Calibration includes print cartridge alignment and optimizing the turn-on energy for the installed color print cartridge.
  3. While holding down the POWER button, press the RESUME button three times.
Eight green checks, one on each line of the printout, signify that the calibration was successful. ----------------------------------------------------- Printing the infinite H test This test prints continuous pages of the letter H and is useful for troubleshooting paper feed problems or other intermittent problems that are difficult to replicate.
  1. Turn the printer on.
  3. While holding down the POWER button, press the RESUME button eight times.
  5. Press and release the POWER button to terminate the test.
Aug 14, 2008 | Office Equipment & Supplies
Xerox DocuPrint P8 Laser Fuzzy Printing
Maybe a bad fuser . That would cause ghosting and reprint on the page
Feb 02, 2008 | Xerox DocuPrint P8 Laser Printer
Phaser 8550, scratch lines through printout
For the lines try the remove stripes and also the remove smears procedure you can run from the panel.
The Led screen is a known problem. Send Xerox an E-mail and they will replace it.
You have to pay for phone support if your not under waranty.
But they will replace the screen.
Oct 10, 2007 | Xerox Phaser 8550DX Laser Printer
Computers & Internet Logo
41 people viewed this question
David Payne
David Payne
