Question about Panasonic TH-50PHD7UY 50 in. HD-Ready Plasma Television
TV shuts off
Shuts off after a while of watching, and then shuts off after it is turned on again
Check for cold soldering connection in the low voltage circuit.if possible there could be a bad filter capacitor.
Posted on Dec 16, 2007
SOURCE:
Tv Shuts off By Itself
When something like that happens the problem is probably in the power supply section of the receiver.
Jun 20, 2016 | Mitsubishi Televison & Video
Shuts off and on while trying to watch, the power light flashes 30 times when off then the tv comes back on again
Power supply trouble. The TV keeps trying to start then operates for 2 seconds and shuts down. The cycle keeps repeating until eventually the TV will not start at all.
Nov 27, 2013 | Sony KDF-60X5955
Tv shuts off after 10 seconds
one of the energy cables is damaged, so tv 'safety protcol' turns on, not to burn shuts off.
go to service
Apr 18, 2013 | Sylvania 6427TE 27" TV
Turn tv on watch it for 20 mins. screen shuts off but green power light is still on. turn it off manualy wait a few mins. turn back on watch for anouther 20 mins or so then screen shuts off again
The reasion your set is shutting off is because the power supply is dieding, and you need to replace the electrolytic caps on the power supply, or purchase a new one, go to www.partstore.com sand check to see if they have your power supply.
Aug 17, 2011 | LG 50PX5D 50 in. Plasma HDTV
Harmony 550, TV comes on, then shuts off
Can you test it again, and look at the remote. Does the remote flash, indicating that another command is sent that is powering off the TV?
Mar 26, 2010 | Logitech Harmony 550 Remote Control
Sony KDF-50E2000 shuts down and blinks repeatedly twice.
The 2 blink error is a temperature error and the 6 blink error is a thermal fuse error. You may need to unplug the set and get you a can of canned air, take off the back lower cover and blow out all of the fans inside the set.
Oct 20, 2009 | Sony KDF-50E2000 50" HDTV
My Magnavox digital converter box shuts itself off every 5 minute
Check that you have not got an auto power off setting on. Check that the aerial connections are good. That the signal is strong from the stations it is picking up. Weak signals can cause the box to shut down.
It the box is very hot when it shuts down, you might have a fault on it.
Apr 04, 2017 | Philips Magnavox M61117 (DBM61117)
52 INCH RCA REAR PROJECTION SHUTS OFF
Your TV is overheating.. easiest remedy is to point a fan at the back of the TV or... clean the inside of the TV, Im sure its full of dust and stuff... this prevents air circulation inside the TV thus creating more heat...
Jun 19, 2009 | RCA HD52W56 52" Rear Projection HDTV
Panasonic TH-50PHD7UY 50 in. HD-Ready Plasma Television Logo
166 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
