Question about Home
My porcelanosa system pool shower has only lukewarm water.the bath water from same pump is fine
frcs68
  • 1605 Answers
SOURCE: shower head leaks water when water is turned on
take out the cartridge from the fixture and make sure it has all of the "O" rings and stoppers.
look at the instruction again, make sue you are installing it the right side up. if all that, the shower still leak, then you need to talk to the place you brought the fixture, it may have a defective cartridge.
Posted on Jan 13, 2009
lester482529
  • 226 Answers
SOURCE: water leaks from shower head while bath faucet is running
sometimes there are orings or gaskets that get tore in assembly one of those may be bad,or if it is around the threds you might try wraping teflon tape around the thred once or twice.hope this helps
Posted on Jun 14, 2009
  • 82 Answers
SOURCE: no cold water coming out of bath/shower, only
Is it a Delta brand, single handle valve? If so, chances are you need a new "stem" and can be purchased at any plumbing suply store or home store. You will need to shut the water off to the house to do this (unless you are certain you know where the shutoffs are). Good luck
Posted on Sep 03, 2009
  • 81 Answers
SOURCE: Low shower head flow from Delta R1824 shower
Try exchanging the Delta head with one of the other shower heads you are happy with if you haven't already done so. No change in the flow means it's not in the head, and change means it is.
If it is in the head, since you are on a well and not a municiple water supply, you might consider removing the factory install flow controll device located just below the threaded area that mounts to the shower arm. These inserts can be a real bugger on some heads and each one is a little different than the last. The trusty nail often works well.
Your body sprays, I believe, are factory fixed at something like 2.2 gpm and non adjustable.
Also consider for a moment a garden hose with trigger spray head on it. When you squeeze the trigger the water will shoot out a certain maximum distance. If you were to take an ice pick and poke a hole in the hose, that maximum distance will be slightly reduced. The more holes in the hose the less the maximim distance. Correspondingly, the more holes you poke the less distance each hole will squirt because you have the same pressure and volume of water but more exit points.
A monitor has a flow rate of about 6 gpm at 85 psi which is pretty average for shower valves. If your other showers have only one exit point(i.e. one head) and the R1824 has 3 with the same pressure and volume, the garden hose illustration can also explain the volume change as well.
Posted on Jun 01, 2010
  • 28 Answers
SOURCE: Water from my shower tower is not hot enough. I
what brand of shower handles do you have and do you have just 1 temp handle or is it separate hot and cold?
Posted on Nov 17, 2010
How to increase water pressure on wall mounted shower
Yes,,,
You could fit a shower boost pump if you water supply to the shower is gravity fed. Pump both the hot and cold so that the water pressure is equal...
Salamander pumps are the best and have flow switches which activate when the shower is turned on..
There are cheaper pumps available... you get what you pay for...
http://www.screwfix.com/p/salamander-pumps-rsp50-positive-head-shower-pump-1-5bar/99043
Just for a guide....
Apr 12, 2017 | Home
BRAND NEW RINNAI BOILER E75cn Shower runs hot then warm then hot then lukewarm then cool then lukewarm then cold
get the installer people back to set the operation correctly as it should have been test run before they left
read your operators manual for settings or trouble shooting
Feb 24, 2016 | Home
Shower takes too long to get hot then runs lukewarm then hot lukewarm then gets cooler & and cooler &cold
There is a temperature adjustment on the hot water tank.
Perhaps it is set too low. They are often red in color.
Feb 24, 2016 | Home
How to get hot water to the sink
did you turn on the hot water heater? water pump? limited,, and there is a nice dutchmen owners dot org site which I belong to,, alot of smart guys. good luck
Jan 26, 2015 | Dutchmen 2013 Coleman Explorer CTU271RB
Why? 200L 400kpa kwikot geyser-average house, 1 person, after 1 hot shower water is lukewarm, why?
You are most likely using enough water for 2 people. Take a shorter shower.
Jul 09, 2014 | Pool & Spa
Water barely lukewarm
is the heater running ? did u raise the temperature higher that the existing water temperature in pool ? are u running the pool pump long enough to achieve the temperature that you want ? IF CHECK (OK) 1- check the internal flow valve control is located between the cold and hot water little black cap, check the condition ,make sure no calcium deposit build inside, 2-is the water temperature in the heater is the same as the pool temperature ? is the pump got full prime with no air ? is the filter is clean ? is this heater propane or natural gas ?
Jun 12, 2013 | Sta Rite Sta-Rite Max-E-Therm High...
Shower only stays lukewarm
sounds like the mixing valve needs replacing
Feb 26, 2012 | Plumbing
My water heater was serviced(drained and circ pump replaced) and I'm still getting lukewarm water for my showers. It doesn't get as hot as it used to at all. I can't even wash my hair-it gets cold too...
If the water is only cool in the shower, it could be the shower valve. However if water is cool at all taps, something is not working on the water heater system.
Gary
Dec 18, 2010 | Kohler K-T10335-4-CP Lyntier Rite-temp...
Every time i turn the shower on it tripps the electric
if you mean it trips the breaker in the breaker box for the house you have a dangerous problem going on.is the shower system a newr fancy one with any pumps for the water etc? in that case it may be a bad pump. if not then you may be getting water into the electrical system somehow and you need an electrician to look into it right away. one other option is does turning on the shower activate any lighting fixtures in the bath? if so then that may be the source but you still need an electrician to service the system asap. dont use the shower anymore until you get it checked out.
Jun 04, 2010 | Home
Our Saniflo - Saniplus works fine and efficiently when we flush the toilet, if we use the shower or bath,when emptying the water the flow is not as strong/as much pressure like a toilet flush & the...
Sounds like a restriction in the outlet pipe, the 2 galls from a flush are OK but the bath or shower is more, especiallly if you have flushed before you shower, try drain unblocking chemicals or flushing the outlet pipe with mains water from a hose
Mar 09, 2009 | Saniflo & Saniplus& Macerator Pump
Home Logo
82 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
