Ir c3100 error code e000733 001 - Computers & Internet
CANON IR 3300 ERROR CODE IS : E000733 - 0001 WHAT IS IT THIS ERROR BECOMES
Posted on Jul 11, 2014
My copier CANON-c3170 is not working due to Error- E000070-0001
Not a good code to have. Its a problem with the transfer belt home position sensor or maybe a broken tension arm. The disassembly involved to remove that belt assembly is brutal and the belt assembly is expensive also. Love the canon copiers but the c3100 and c3170 units are terrible machines. I would think twice about investing the money it will take to repair it.
Jul 23, 2012 | Office Equipment & Supplies
Canon c3100 display say wait
No error code after waiting? Could be heater or toner or Image formation-developement. addition function 2 and 8 at the same time additional functions again. Copier>display>error . If 20 code exists developement if 0-8 heater
Jan 09, 2012 | Canon iR 2016i Black and White Copier
Canon Ir C3100 Error 000070-0002
A E000070-0002 deals with the transfer belt. I believe it deals with the two tension arms, one may be broken...... It is not easy to get the unit out of the copier.... Good Luck
Jun 26, 2011 | Canon imageRunner C3100 Copier
When i get my c3100 started i get an error code e 000013-0000 . can you tell me what the problem is
Waste toner bottle full, open front door, one screw, make sure small cut out in the neck of the bottle is clean afterwards.
Oct 31, 2010 | Canon imageRunner C3100 Copier
Canon iR 3100CN Error code E000732-0001
E732 Reader communication error
0001 DDI-S communication error Check on connection between the reader controller PCB and the main controller PCB, Check on the
reader power supply
Hope that helped!
Jul 25, 2010 | Canon iRC3100 Printer
What is Canon C3100 error code E000008 0001
The reading of the fixing roller life counter has reached its upper limit.just reach the counter reading at svc mode.
Mar 06, 2010 | Canon imageRunner C3100N Copier
IR 3100 error. E020-01A9, E020-02A9,
E020-01A9 Error Code : iR C3100 Series
Hi there
I have looked it up and what it says about it I have put down for you so you can gave it a try hope it works for you.
Approved
Symptom
E020-01A9 Error Code.
Cause
For ATR control, the detected Toner/Density ratio exceeds the lower limit (3%) 3 times continuously for Yellow
Action
The ATR Sensor and Patch Image Read Sensor both determine toner density. Depending on the density readings the copier will or will not add toner. Check the status of the Drum Unit under COPIER>DISPLAY>MISC>DRUM-LIFE. The Patch Image Read Sensor looks at a patch of toner that is generated on the drum for each colour and determines the amount of toner that is in the patch by the amount of reflected light. If the drum is not creating the patch correctly, the patch reading will be affected. Replace the Drum Unit if it is 80% of its rated life or higher. ..
Feb 16, 2010 | Canon iRC3100 Printer
Canon ir-c3100 copier error code
The ITB or Intermediat Transfer Belt is slipping or not being driven properly. It is NOT fun to take out, particularly if you have a finisher attached. If you have proffessional experience with copiers and are really determined, let me know and I may be able to set you up with a manual. Otherwise, call a pro.
Jul 26, 2008 | Office Equipment & Supplies
Computers & Internet Logo
123 people viewed this question
David Payne
David Payne
