Question about Boating
Evinrude E50PL4EE will not pump water - Boating
3 Suggested Answers
  • 106 Answers
SOURCE: how do i replace the water pump in a 2005 150 hp evinrude outboard motor
Take the cowling off. Also drop the foot. There wil be a stainless linkage rod that runs the length of the motor that you will have undo to drop the foot. The water impeller will be inside a stainless casing that you will have to disassemble.
Posted on Aug 19, 2012
richsteve777
i know i need a knew cable i put in trouble shooting for all how do i install it the cable is broke i know that. because it broke down below on the motor i dont know where it hooks up on the top of the motor 1990 40 hp evinrude model number is te-40-elesr cable tilt assist.what dont you guys understand. where can i get a diagram where the cable hooks up on the motor. duh
Posted on May 19, 2014
We replaced the water pump on a 1990 Evinrude 25 hp motor, but it isn't working. Can you help us?
It may look easy in the book but there are a few things that can go out. Such as the key/roll pin that drives the impeller can slip out on assembly. Water tube out of hole or damaged OR pieces of old impeller in it depending on why you needed to replace it. There are more but if you are not a trained tech it may be time to find one.
Nov 29, 2014 | Clymer Evinrude/Johnson 2-40 HP Outboards...
Does motor on 1975 25 horse evinrude have to be in gear for water pump to work
The water pump HAS to be working whenever the motor is started. You'll burn you water pump impeller out very quickly if it isn't.
Jun 28, 2014 | Boating
Need to see the assembly differences on a evinrude 35 hp (1978) long shaft and short shaft. I am changing my long shaft to a short shaft and there is a tube that I don't know the purpose of.
Try going to: http://shop2.evinrude.com/Index.aspx?s1=gett3uheq5c0nce2mjg11d1eh0&catalog_id=0&siteid=1
There you can search out all differences. You will need year, make and model # of your engine.
The tube is probably a water pump alignment tube to insure the water pump tube goes into the water pump since its not visible during installation.
Oct 06, 2013 | Boating
Trying to get lower unit off a 88 25hp evinrude motor
www.youtube.com go there and type water pump replacement 25hp Johnson or evinrude. You can also go to
Thank you, Lewis Hot Headz Marine
Sep 25, 2013 | Boating
I have a evinrude 28hp outboard which is not pumping water. drive shaft seems in place and impeller in good nick. have put hose at bottom of inlet pipe and water runs through motor and out outlet. water...
Check pump housing and plate for wear,make sure aluminium housing not corroded under plate. Suggest fitting electric drill to drive shaft and emerse lower unit in bucket of water.make sure drill doesn't get wet.is motor going into gear,maybe splines are rusted off in crankshaft,could also have holes in inner exhaust side plate
Sep 04, 2013 | Sierra International 18-4310 Marine...
How do i replace the water pump in a 2005 150 hp evinrude outboard motor
Aug 17, 2012 | Boating
Can't get 1976 evinrude 6hp to pump water I changed water pump
have you changed the impeller inside the lower unit.
There is copper pipe to redirect water up into the engine.
When you replaced the impeller make the copper pipe is insert onto the engine.
Jul 31, 2012 | Light Outboard Motor Boat Bass Fishing...
How to replace impeller on evinrude 115
disconnect the lower unit from the power head . makeing sure where the shift rod position is . then you will be getting near the water pump impeller .if you get it wrong the shifting won't work
Apr 24, 2010 | Boating
CHANGE WATER PUMP IMPELLER FOR EVINRUDE OUTBOARD MOD# E28ESLETD
Crowley Marine Boat Parts & Diagrams have diagrams of all the components, and the catalog is easy to go through to pull them up, OEM and other brands, no cost for the images.
Mar 19, 2009 | Boating
Boating Logo
79 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Boating Expert? Answer questions, earn points and help others
