Question about Mtd Garden
Lawnflite 603 drive belt has come off , how is it configerd around the pulleys
    Loyalty:
    Visited the website for 30 consecutive days.
  • Mtd Master
  • 1,101 Answers
PartsTreeRepairClinic may have a video
Posted on Feb 13, 2018
crayzeetrayn
  • 837 Answers
SOURCE: replace motion drive belt garden tractor craftman 917273080
On what make and model riding mower ..
Posted on Jan 19, 2009
MNfisherman
  • 11896 Answers
SOURCE: what size drive belt for a mtd lawnflite 11 hp
(1991) 131-531C611/505
(1990) 130-531C611/505
(1992) 132-531C611/505
(1993) 13-505 / 133C561C611
Posted on Jul 20, 2009
mowerman1857
  • 389 Answers
SOURCE: The mower deck drive belt slipped off the idler
Get the model number off the tractor, go to:
www.murray.com
enter the model number and you will find a manual with pictures of how to route the belts along with a lot of other good information
Posted on Sep 30, 2009
  • 66 Answers
SOURCE: my 603 lawnflite ran over a man hole cover and
Should be just behind the dash
Posted on May 30, 2010
Testimonial: "Hi thanks will check it today,i also need a workshop manual for the 603 lawnflite 30" cut,would a manual from another lawnflite model be the same?,also has anybody else heard of the lawnflite 603 model or others, sucking manhole covers into its cutter deck,beware all lawnflite owners,this has happened to me on its second cut from new,i have cut our lawn with a westwood tractor for the last 26 years,and never had any trouble with manhole covers!!!!!!!!"
richroth
  • 9472 Answers
SOURCE: i need help replacing the
The drive belt connects to the fron of the machine Just above the PTO clutch. connected to the vertical crank on the engine. It slips through a series of pullies to the back side od the mower. One pully will be on a tention spring. that is your golden ticket to getting the tention you need.
hello sir,
Looking at the pullys. for routing your new belt. V pullies for the inside portion of the belt and flat pullies for the outside.
You can usualyl take the chassis and pedals off as needed. the pebals have pins holding them on.
the seat has a safty switch that gets unplugged.
There are bolts hidden under the foot map as well which snaps up and down careful with these as that mat will never be the same if you break the clips.
THe back of the mower near and above the gastank you will see a pull thats ontop of a hydrostatic pump thats the last pully.
I have done these before without removing the body. However its not easy and you had better be limber.
Ohh and of course remove any decking under the mower or drop it all the way down for easier access.
Posted on Dec 24, 2010
How do I change the deck belt on a Lawnflite 603LT Tractor mower
you have to get under the lawn tractor , I usually will put it up on some blocks there is usually a diagram somewhere on the deck to show how the belt goes, bu here it how it works, it always turns the same way and always goes on and off hthe same, that said the belt is woven on and around a couple bars and tabs to rub on the pulleys the same . disengage the belts and gears and raise the deck to its highest cutting setting find the spring loaded pulleys and retainer tabs and remove these first , when you replace belt MAKE SURE you put belt under retainer clips against pulley or you will ruin a new belt in a minute!!!! IN A MINUTE! so check it 3 times it should run smooth then start it
Sep 11, 2016 | Garden
How to replace cutter belt Lawnflite ride on mower 903 auto drive , it came off and don't have operator manual for configuration
There are idler and tensioner pulley's, you sould maybe go to a dealer they could maybe help with the proper routing.
Apr 18, 2015 | Garden
Lawnflite 991 sp6e self propelled lawnmower
Buy LAWNFLITE Spares
This site may have the part you are looking for.
May 17, 2014 | Mtd Garden
Diagram for 5 pulley belt 98 pontiac transport.
start from bottom crankshaft pulley and ac compressor turn belt tensioner counterclockwise or lift forward then run pulley belt around crankshaft pulley and around AC compressor,run pulley belt around power steering pump then around alternator,once drive belt around alternator you done make sure drive is center of crankshaft pulley and AC compressor pulley.and belt back is center against water pump pulley before releasing the belt tensioner.
Aug 27, 2012 | Pontiac Trans Sport Cars & Trucks
My 603 lawnflite ran over a man hole cover and
May 29, 2010 | Garden
What size drive belt for a mtd lawnflite 11 hp
Jul 20, 2009 | Garden
Stiff turning
you could be low on pwer steering fluid. CV joints won't affect steering. That is for powering the wheels.
Very important. Make sure shop did not overtighten a/c belt. If they did, you could be in danger of breaking your crankshaft snout. It may be a good idea to check that.
Also, did they tighten the power steering belt correctly?
Did this steering issue sstart after repairs
go here for help
http://autos.groups.yahoo.com/group/villagerquest/
  1. The tension for the water pump and power steering drive belt should measure 603-691 N (135-155 lbs) for a new drive belt, 495-583 N (110-130 lbs) for a used drive belt. The limit for drive belt tension is 196 N (44 lbs).
    1. Adjust the water pump and power steering drive belt tension as follows:
    2. Raise and support the vehicle.
    3. Remove the RH front fender splash shield (16102).
    4. Loosen the water pump and power steering pump drive belt idler pulley locknut.
    5. Tighten the drive belt tension by turning the water pump and power steering pump drive belt idler pulley adjustment bolt counterclockwise.
      1. Tighten the water pump and power steering pump drive belt idler pulley locknut to 33-37 Nm (24-28 lb-ft).
      1. Install the RH front fender splash shield.
      Deflection Adjustment
      1. NOTE: If the drive belt has been in service for some time, it should be inspected before adjustment. A drive belt that is severely glazed, frayed, cracked, or contaminated with oil must be replaced. Minor cracks in the back of the drive belt are acceptable as long as no large pieces are missing.
        Apply 98 N (22 lbs) of pressure to the drive belt at a point midway between the power steering pump pulley and the water pump pulley.
        1. NOTE: Always check the drive belt deflection when the engine is cold, or has been stopped for at least 30 minutes. A drive belt is considered new if it has been used on a running engine for less than five minutes.
          The drive belt deflection should measure 8-10mm (0.31-0.39 inch) for a new drive belt or 10-12mm (0.39-0.47 inch) for a used drive belt . The limit of deflection is 16.0mm (0.63 inch).
        1. If the drive belt deflection is not as specified, adjust the water pump and power steering pump drive belt tension. Refer to the procedure in this section.
  1. The tension for the A/C compressor drive belt should measure 603-691 N (135-155 lbs) for a new drive belt or 495-583 N (110-130 lbs) for a used drive belt. The lower limit for drive belt tension is 196 N (44 lbs).
    1. Adjust the A/C compressor drive belt tension as follows:
    2. Loosen the A/C compressor drive belt idler pulley tensioner bolt.
    3. Tighten the A/C compressor drive belt idler pulley adjustment bolt.
May 25, 2009 | 1995 Mercury Villager
Garden Logo
70 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
