KV-36HQ100
I have a Yanmar 4.5 KVA Generator running into a Trace 2.5 KVA inverter/charger, the inverter requires 205-220volts to operate,once the inverter connects the voltage drops on the genny over a ten second+-...
try adjusting the gen voltage at no load to run at 240 volts
when the load comes on it will drop back to 220-235 volts
check the load output from the inverter as 2.5 kv is nearly 80% of the genset duty cycle
4.5 KV is start up KV and the duty KV is around 3..8 kv not the plated 4.5 kv
to get constant 4.5 kv you will need a 5.5-6 kv unit
if the current draw from the inverter is excessive , the engine may not have enough in reserve to over come the load and will not pick up the rpms
take the gen set and the inverter to a shop that has a calibrated load bank to test accurate power output to determine if the engine needs an overhaul
May 28, 2017 | Electrical Supplies
I need the user maual of Sony KV-ES34M80 in PDF format. As I have lost my original manual
Hello
What do you want? User manual for Sony kv-27v36; or service manual for kv-es34m80? Clear your post please.
OK.
Dec 22, 2010 | Sony KV-27V36 27" TV
Does this Sony Model KV-DR29M69 have the (pip) feature?
yes here is the link for your owners manual
http://www.sonydigital-link.com/tv/crt/crt.aspx?site=odw_en_GB&m=KV-DR29M69
Dec 18, 2009 | Sony KV-DR29M69 29" TV
Picture flashes off and on kv-32S22
Your local TV repair guy should be able to go in and recharge the picture tube. Just had mine done for about $165 and it looks good as new (and this was on a KV-32s22 that we picked up at a yard sale). Well worth it.
Feb 04, 2009 | Sony KV-32S22 32" TV
Setup codes for a sony kv-20fs12
i have sony kv 14 gmr1mk r2ks always shorted and the other 1 appear like a lightning in midle of screen.. kv 21gmr1mk when adjust the brigth and contras it shut down the picture and blinking..can u help me how to troubleshoot this problem? what remedy you sudgest..thank you...
May 03, 2007 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Schematic for a Sony KV-32S26?
Hi! I do not have the KV-32S26 Schematics, but I do have the KV 32S 22 schematics. Do u want those? there must only be minor differences. Or can u tell what the problem is and I shall try to send you the specefic circuit. mail me at 'guptapravin@hotmail.com' and i shall send the schematics as a mail attachment.
Sep 14, 2006 | Sony KV-32S26 32" TV
Televison & Video Logo
18 people viewed this question
Top Televison & Video Experts
