Wont print I have cleaned heads and done nozzle check numerous time and it wont print anything no even test results.I am using non epsom ink and have done for some time with no problem
    Problem Solver:
  • 5 Answers
What kind of printer do you have
Posted on Aug 31, 2007
SOURCE:
Have just installed new ink to my Epsom Stylus sx215 but wont print, just blank pages
Do a "nozzle check". Do you get anything?
Did you remove the tape pull-off tabs that let ink flow?
If you get nothing or very little with the nozzle check, and you did remove the tabs. do a "head clean" and try again.
Feb 14, 2015 | Epson Stylus Office Equipment & Supplies
Print head go left and right non stop when the command for print is given - but does not print anything even when ask to do a nozzle check - the printhead goes al the way left and right again and again...
When was the last time the machine worked, please? What you describe sounds like clogged or dry print heads.
What happens if you try cleaning the heads not the standard once, but at least four time in a row without doing anything else in between, please? Don't try a test, don't switch off; just run the cleaning routine at least four times in straight row. (Sorry that might use a lot of ink)
Feb 04, 2014 | Epson Stylus Pro 9900 - 44" large-format -...
Epson CX5500 fault number 1180 Posted by Author imageGuest on 2/17/2013 Details Despite head cleaning and nozzle check several times, the fault persists. What can I do ??
How nozzle check result? Perfectly or Appear "another" lines.
Possibility: waste ink on the bottom plate of the head. Will disappear by itself, when used continuously. Try printing with enabling "Thick paper" option.
Feb 18, 2013 | Epson Office Equipment & Supplies
One colour cartridge on epsom sx200 is empty yet it wont allow me to print in black only
umm... this is not a solution because I don't think there is one apart frombuying new inks. Epson and all other inkjet printers do this to preventthe coloured print head nozzles from getting blocked. If they are notused for a long time the ink dries up and blocks the nozzles. Epsonrecommends printingat least once a month with all colours to prevent this. Printing inblack only option will only work if the colored inks are OK. Wheneverthe printeris turned on it performs a head clean, this is why the coloured inksget used over time even though they are not used for printing.
www.Quikshiptoner.com
Nov 25, 2009 | HP LaserJet 2840 All-In-One Printer
Printer will only print in colour ink, not anything in black text
The issue your having is more then likely the ink cartridge itself or the printhead. Here is the steps in checking and possibly fixing the issue. Step 7 though should be done by a repair tech.
(1) Check that the orange cap or tap is not on the printhead.
(2) Remove the printhead and re-install it.
(3) Perform printhead cleaning, and visually check the test print for non-discharge of ink from nozzle.
(4) Perform head-refreshing, and visually check the test print for non-discharge of ink from nozzle.
(5) Replace the appropriate ink tank.
(6) Replace the printhead
(7) Replace the purge unit.
Jun 18, 2009 | Canon Office Equipment & Supplies
I have a c86 printer. The test on the 4 color ink patterns says nothing. I have cleaned the heads numerous times and have replace all of the ink cartidges twice. Same old situation. I have used Windex to...
You can try soaking the print heads for 24 hours (or more), as follows. Turn the printer on, and as soon as the print head moves out of its parking position, pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way. Look inside the print head parking area on the right and you will see a small rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head by hand fully
into its parking position so that the cup full of fluid comes up over the print head. Do not turn the printer on at any stage in this process. Leave this for at least 24 hours, then turn the printer on and try a head clean/nozzle check again. If you get any ink on the nozzle check, then there is hope! Repeat the head clean/ nozzle check process 2 or 3 times, but not more. Leave for 24 hours for any air bubbles to disperse, then repeat. If nothing, repeat the soak process once more. If still nothing, post a new comment detailing what you have done and the results.
May 01, 2009 | Epson Stylus C86 InkJet Printer
Can you help? After changing the cartridges, I keep getting a message about the ink head being incorrect...I am directed to press 'OK' which does not help; then to turn printer off and on again, which...
Cleaning your head might resolve your problem. Perform the below steps to clean the head:
Print Head Cleaning / Head Refreshing If the printed nozzle check pattern is broken, missing, or a specific color is not printed, clean the print head (Cleaning) or print head deep cleaning (Deep Cleaning). Note:
  1. Cleaning the print head consumes a small amount of ink. Cleaning too often reduces the amount of ink in the ink tanks.
  2. Print head cleaning is performed when you connect the power cord. Your machine may perform print head cleaning periodically to avoid clogging.
Overview:
Step1:
Print the Nozzle Check Pattern.
To check whether the print head nozzles are clogged, print the Nozzle Check Pattern.
downicon.gif If the print quality is poor, perform print head cleaning.
Step 2:
Perform print head cleaning.
This unclogs the print head nozzles
Print the Nozzle Check Pattern again.
If the print quality is still poor, perform two print head cleanings.
downicon.gif Print the Nozzle Check Pattern again.
Step 3:
Perform deep print head cleaning.
This is a more powerful cleaning.
Displaying the Maintenance screen
  1. Ensure that the printer is powered on.
  2. Press the <Menu> button.
  3. Press the left or right cursor to select [Maintenance/settings], then press <OK>.
  4. Press the left or right cursor to select [Maintenance], then press <OK>.
Print Nozzle Check Pattern
  1. Press the Open button to open the output tray.
  2. Load letter-sized plain paper in the auto sheet feeder (ASF) or the cassette.
  3. Display the Maintenance screen on the printer.
  4. Press the up or down cursor to select [Nozzle check], then press the <OK>.
  5. Press the up or down cursor to select [Yes], then press <OK>. (The nozzle check pattern is printed.)
  6. Confirm the nozzle check pattern.
05sj00160_03a.gif 05sj00160_03b.gif < 1 > The normal nozzle check pattern
< 2 > The abnormal nozzle check pattern
< 3 > Some black ink lines are broken.
< 4 > White lines are present in the color ink pattern.
< 5 > Both black and color inks are not present.
Note:
  1. When all patterns are printed normally, press the up / down cursor button to select "All A" and press the OK button.
  2. When any patterns are printed abnormally, press the up / down cursor button to select "Also B" and press the OK button.
Print Head Cleaning:
  1. Display the Maintenance screen on the printer.
  2. Press the up or down cursor to select [Cleaning], then press <OK>.
  3. Press the up or down cursor to select [Yes], then press <OK> to start print head cleaning.
    Note:
    Do not do any other operations until print head cleaning is completed.
  4. Print the nozzle check pattern and check the print head status.
Deep (Print Head) cleaning:
  1. Display the Maintenance screen.
  2. Press the up or down cursor to select [Deep cleaning], then press <OK>.
  3. Press the up or down cursor to select [Yes], then press <OK> to start print head deep cleaning.
    Note:
    Do not do any other operations until print head deep cleaning is completed.
    Note:
    If the printed result does not improve even after doing print head deep cleaning, turn off the printer. Then, after 24 hours or later, do print head deep cleaning again. (After a given time interval, ink could dissolve itself, resulting in ink unclogging.)
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Apr 22, 2009 | Canon Pixma MP500 All-In-One InkJet...
Epsom stylus c84 major lines thru pages. Already cleaned heads.
Have you tried a cleaning cycle? If not, try one (right click the little printer icon in the bottom right corner of the screen and select head clean). Now run a nozzle check (right click the little printer icon in the bottom right corner of the screen and select nozzle check). Is there any sign of ink on the paper. Try up to three cleaning cycles. If ink is now flowing, but not yet perfectly, don't carry out any more cleaning cycles. Just leave the printer for 24 hours (to allow any air in the print head to disperse). Then repeat the cleaning cycle/wait process. It may take a while to restore a perfect nozzle check print.
If you have already done lots of head cleans with no result, and you're sure you have good ink cartridges properly installed, then You can try soaking the print heads for 24 hours (or more), as follows. Turn the printer on, and as soon as the print head moves out of its parking position, pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way. Look inside the print head parking area on the right and you will see a small rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head by hand fully
into its parking position so that the cup full of fluid comes up over the print head. Do not turn the printer on at any stage in this process. Leave this for at least 24 hours, then turn the printer on and try a head clean/nozzle check again. If you get any black ink on the nozzle check, then there is hope! Repeat the process
until you get a full black nozzle check. If nothing, repeat the process once more. If still nothing, post a new comment detailing what you have done and the results.
Mar 29, 2009 | Epson Stylus C84 InkJet Printer
Epsom stylus all in one dx7450
press 'Control' + 'P' on a page (as tho you want to print)
click 'Maintenance'
there you'll find various options to clean heads etc, that should do it. tho it does deplete your inks considerably each attempt. & you'll probably find it needs more than one clean.Good luck!
Jun 08, 2008 | Epson Stylus Multifunction Inkjet Printer/...
Poor colour
3. Use the [<] or [>] cursor button to select 'Maintenance/settings', then press the <OK> button.
4. Use the [<] or [>] cursor button to select 'Maintenance', then press the <OK> button.
How to print a nozzle check pattern
1. Extend the paper output tray. (Confirm that the paper thickness lever is set to the left.)
2. Load a sheet of A4 or Letter-sized plain paper in the auto sheet feeder.
3. Display the MAINTENANCE screen. (See How to display MAINTENANCE above.)
4. Use the <up / down > cursor button to select NOZZLE CHECK and press the <OK> button.
5. Use the <up / down> cursor button to select Yes, then press the <OK> button. The nozzle check pattern is printed.
White lines are present ,black and/or color inks are not present.
- When all patterns are printed normally, press the <up / down> cursor button to select 'All A' and press the <OK> button.
- When any patterns are printed abnormally, press the <up / down> cursor button to select 'Also B' and press the <OK> button.
Top of Page
How to do print head cleaning
Note: Cleaning the print head consumes a certain amount of ink.
1. Display theMAINTENANCE screen. (See How to display MAINTENANCE above.)
2. Use the <up / down > cursor button to select CLEANING and press the <OK> button.
3.Use the <up / down> cursor button to select 'Yes', then press the OK button to start print head cleaning.
Note: Do not do any other operations until cleaning is completed.
4. Print the nozzle check pattern and check the print head status. (See How to print a nozzle check pattern above.)
Top of Page
How to do print head deep cleaning
Note: Print head deep cleaning consumes more ink than print head cleaning.
Perform this procedure only when print head cleaning cannot resolve the print problem.
1. Display the MAINTENANCE screen. (See How to display MAINTENANCE above.)
2. Use the <up / down> cursor button to select DEEP CLEANING and press the <OK> button.
3. Use the <up / down> cursor button to select 'Yes', then press the <OK> button to start print head deep cleaning.
Note: Do not do any other operations until deep cleaning is completed.
Note: If the printed result does not improve even after doing print head deep cleaning, turn off the printer. Then, after 24 hours or later, do print head deep cleaning again. After a given time interval, ink could dissolve itself, resulting in ink unclogging.
When the printed result does not improve even after these steps, replacement of ink cartridges may be required.
Nov 14, 2007 | Canon Pixma iP6600D InkJet Photo Printer
Open Questions:
TOSHIBA customer support phone {\#;-{+1'8OO;8O3^1O69} NuMbEr USA .ANITA This TOSHIBA USA phone number +1:8OO:,:8O31069 is ranked #2 out of 2 because 7,728 TOSHIBA USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO:,:8O31069 is to reach the TOSHIBA USA customer support department for problems like Where to buy, Complaint, customer support, Repairs, Returns. As far as we can tell, TOSHIBA USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. TOSHIBA USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O31O69 and ways to call or contact TOSHIBA USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling TOSHIBA USA Calling TOSHIBA USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our support call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from TOSHIBA USA customer support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with TOSHIBA USA's customer support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare TOSHIBA USA's phone numbers against each other. Contacting TOSHIBA USA in General While I8OO8O31O69 is TOSHIBA USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO8O31O69 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach TOSHIBA USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact TOSHIBA USA.
Oct 18, 2019 | Toshiba Computers & Internet
\Q;- PANASONIC customer support phone {+1'8OO-8O3^1O69} NuMbEr USA .ANITA This PANASONIC USA phone number[ +18OO-8O3-1069] is ranked #2 out of 2 because 7,728 PANASONIC USA customers tried our tools and information and gave us feedback after they called. The reason customers call [+I8OO-8O3-1069] is to reach the PANASONIC USA customer support department for problems like Where to buy, Complaint, customer support, Repairs, Returns. As far as we can tell, PANASONIC USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. PANASONIC USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O31O69 and ways to call or contact PANASONIC USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling PANASONIC USA Calling PANASONIC USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our support call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from PANASONIC USA customer support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with PANASONIC USA's customer support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare PANASONIC USA's phone numbers against each other. Contacting PANASONIC USA in General While [+I8OO-8O3-1O69] is PANASONIC USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that[+ I8OO-8O3-1O69] is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach PANASONIC USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact PANASONIC USA.
Oct 18, 2019 | Panasonic Computers & Internet
KODAK customer support phone {\#;-{+1'8OO;8O3^1O69} NuMbEr USA .ANITA This KODAK USA phone number +1:8OO:,:8O31069 is ranked #2 out of 2 because 7,728 KODAK USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO:,:8O31069 is to reach the KODAK USA customer support department for problems like Where to buy, Complaint, customer support, Repairs, Returns. As far as we can tell, KODAK USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. KODAK USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O31O69 and ways to call or contact KODAK USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling KODAK USA Calling KODAK USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our support call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from KODAK USA customer support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with KODAK USA's customer support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare KODAK USA's phone numbers against each other. Contacting KODAK USA in General While I8OO8O31O69 is KODAK USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO8O31O69 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach KODAK USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact KODAK USA.
Oct 18, 2019 | Kodak Computers & Internet
\Q;- HP customer service phone {+1'8OO-8O3^1O69} NuMbEr USA .ANITA This HP USA phone number[ +18OO-8O3-1069] is ranked #2 out of 2 because 7,728 HP USA customers tried our tools and information and gave us feedback after they called. The reason customers call [+I8OO-8O3-1069] is to reach the HP USA customer service department for problems like Where to buy, Complaint, customer service, Repairs, Returns. As far as we can tell, HP USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. HP USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O31O69 and ways to call or contact HP USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling HP USA Calling HP USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our service call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from HP USA customer service can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with HP USA's customer service department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare HP USA's phone numbers against each other. Contacting HP USA in General While [+I8OO-8O3-1O69] is HP USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that[+ I8OO-8O3-1O69] is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact service for you to look at as well. One thing to keep in mind as you try to reach HP USA help by calling them, is that other customers give their customer service at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact HP USA.
Oct 18, 2019 | HP Computers & Internet
Computers & Internet Logo
120 people viewed this question
Ekse
Alun Cox
