Vizio e320vl Hello, I am looking for some p[possible service on my vizio TV, the two problems are that (I dont have the original remote) that I cannot program my directv remote to the TV and believe the sensor may be shot. The second problem is that when i plug in a device through an HDMI it automatically changes the source to the other hdmi port. Any ideas on how to fix this? Thanks a ton!
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 36 Answers
Ok for the first issue you'd better contacting you dealership to buy an original remote.
for the 2nd issue,actually no can do! :\ so you might want to keep the device plugged all the time and change through the sorces using your remote.
Posted on Aug 01, 2013
SOURCE: will not correctly switch between different HDMI
I have the exact same problem/symptom. I suspect this is a very common problem only folks just now discovering it as we buy new hdmi devices. I called technical support and got the "sorry, out of warranty" talk. Mr Badge #74754 claimed that this was not a known problem. Would love to hear of others having this problem.
Posted on Mar 07, 2010
SOURCE: My Philips 42PFL3603D/27 that does not connect to hdmi device.
At the rear or side of the PC there should be either or both of a 15 Pin DIN Plug, HDMI socket. or a Yellow RCA or 4 -7 pin DIN. Now IF these are present then YES you can connect to a TV. Now some TV's have a connector a DB15 MALE, so that the cable from the PC to the TV, is DB15. this plugs in directly, with appropriate DB15 cable. This, however, will ONLY take the VIDEO to the TV, Audio is delivered via the "Audio Out" Jack on PC, and Plugged into the AV Sockets on the TV, with a dual cored coaxial cable, they are Red & White. Some PC's also have a Yellow RCA Connector, OR a 4 -7 Pin DIN Socket, that requires a Special Adapter Cable (That generally came with the unit, and are colored and marked as to output) to use, for Video/Audio Out to TV. This signal is Composite or SVHS Video & Stereo Out. This connects up TO the TV's Composite/SVHS input Jacks and the Red & White Audio IN, RCA Jacks, &/or DIN SVHS socket.
First you need to know if your PC can output to a TV. Then you need to get the adapter & cables that connect the PC to the TV. Then you need the correct TV drivers installed for your video card. When they are all installed, you need to "Enable" that Monitors, the TV's, Desktop. You need to set either a "Cloned" display or "Spanned, Extended Desktop". Go to "Display Settings" Now ensure the TV/Monitor connected has the correct input/output display settings. Adjust the screens resolution via the resoloution "Slider", it is best to start with, 800x600 32 bit color. or even lower. and once working OK, THEN increase to max resolution, your TV can handle, find out from manual. Once it is all connected up. It should all just work great. Now, from then on, &, to get it to work every-time, the process is. Turn everything OFF. Connect the leads between PC & TV, Turn the TV, ON. Then, startup the PC up. It should "Detect" that it has TWO "Monitors" ie: One Monitor & One TV/Monitor, & you should see your desktop appear after a bit. Now you have screen 1 & screens 2. Now, if you are using "Cloned" mode, then whatever is displayed on the Master monitor, will be displayed on the TV. If you used Spanned, mode, in this mode, however, you will have to."Drag" the Video window, over to the TV, and it is though, you have one "Big Desktop". Now IF using Nvidia or ATI then BOTH of those have thier OWN, Control Panel, this, all then can make it all a lot easier to do it. So I would suggest that this method be used. But if you get stuck, or just want to do it by hand, then the the "By Hand" method is the only way.There is a great program called MultiMon, this allows great control over dual displays, and is well worth installing.
Posted on Mar 10, 2010
Testimonial: "While my problem did not get solved, he helped me as much as he could. Thanks!"
  • 3 Answers
SOURCE: I need to change the source on my tv to HDMI without my remote
Not sure if yours is the same but Philips codes work with Skyworth and if you hit the TV/AV button on the side of the TV and the table of options should come up. And then with the channel +or- go up and down till you are on HDM1 or where ever you want and then touch the TV/AV again when you are there.
Posted on Mar 28, 2010
SOURCE: hdmi port not working for ps3
believe it or not it might be your tv. mine did the exact same thing and i thought it was my ps3 but who wlda guessed its the tv lol. soo heres what you do. leave ur ps3 plugged in to your tv through hdmi, then all you do is unplug your tv from the wall, and wait for about 20 mins then volia!!!!! hmdi at its best. i do not know how it works but it does and i hav not had a problem since.
Posted on Sep 15, 2010
SOURCE: Sharp Aquos 46" HDMI problem
I have a similar problem. The Sharp TV aquos appears to be shutting down my blue ray player and dvd recorder when connected via HDMI. They work fine and never close down when I connect them via the rca cables either single video connection or a composite 3 cable rca lead. I have 3 HDMI inputs on the tv and the problem occurs on all 3. Any suggestions?
Posted on Apr 25, 2011
I have a Vizio E320VL with a video problem.
The Tcon boar or the LCD panel is faulty. You have to replace the TCON board to confirm it.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Jun 05, 2016 | Vizio E320VL 32 in. HD Ready LCD TV
Way to single the remote as it seems to be lost.
Sorry there is no way to signal (single) the remote . some phones had that as a feature but not tv remotes
Nov 01, 2015 | Vizio E320VL 32 in. HD Ready LCD TV
E321vl no power. could this mean bad logic board?
The downside of a product getting a power surge is it will never be just right. It is not worth the cost to repair it. Consider buying a new TV instead. Suggest a Smart TV.
Mar 24, 2015 | Vizio Power Supply Input Main Board Unit...
How do i get my tv working again
Janet, it is possible your television was on placed on timer, remove the timer then move on.
Aug 21, 2014 | Vizio L32 32 in. LCD HDTV
Vizio E320VL has lost sound
if you have basic idea in electronic repair, you can open the back door using a screw driver to gain access the internal part of the tv. then look for the speaker first if worn out you can also check the resistance using an analog tester. by the way before you do this initial checking you can check first weather the audio is set to off or mute in the settings, also check the volume adjustment .
Nov 02, 2013 | Vizio E320VL 32 in. HD Ready LCD TV
The colors are going out in Vizio E320VL. Can I fix this by replacing the main board or is there another solution?
Sounds like a faulty Timing Control board, I had the same problem except yellows showed up green.
Apr 03, 2013 | Vizio E320VL 32 in. HD Ready LCD TV
Vizio E320VL has yellow light but wont turn on even with a new Power Supply
The power supply get's it "turn on" signal from the main board. It is very likely you have a faulty main board. Do you have electronics experience??
May 15, 2012 | Vizio E320VL 32 in. HD Ready LCD TV
I turn my vizio on then it just turns itself off
Tries tv unplug,replug it back like an hour later.By letting the tv resetting itself back to the factory setting.The tv should be working again,if have the same result.Mean the power supply board is the causes and the problems.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to by a refurbish power supply board for the replacememt.
Jan 30, 2011 | Vizio E320VL 32 in. HD Ready LCD TV
I have to put my remote right in front of the TV to get it to work if I move back it will not work.
Change the batteries or the sensor has lost all sensitivity in the TV and requires servicing.
Hope that helps.
Jan 16, 2011 | Vizio E320VL 32 in. HD Ready LCD TV
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
