Question about Samsung RF26XAERS
WATER LEAKS INTO REFRIGERATOR JUST BELOW THE WATER TANKS. MOISTURE SEEMS TO FOLLOW THE WATER LINES INTO THE UNIT. WHERE DO THESE LINES GO AND CAN THEY BE REPLACED? MODEL RF26XAERS
2 Suggested Answers
Krazytech
  • 725 Answers
SOURCE: Water leak
Unplug the refrigerator, open the door and get a blow dryer and warm up the freezer. wait until the water stop dripping out or about 12 to 24 hours and then you can plug it back in . it will work for 2 to 3 weeks. To unplug the drain.defrost the freezer .remove the back cover. Use a pipe cleaner to clear the drain. pour a few cups of hot water down the drain. the drain hose may be just pulled off ...it must let the water drip in the pan.
Posted on Aug 17, 2008
Do I have to fill the tank under my mobile aircon CEG Model 8000R/C before I start the unit or is a catchment tank ?? Thanks in anticipation
Air conditioners unit produce moisture, if it is not drained to outside it will spill over to floor. CHECK FOR A drain line to outside.
Feb 09, 2015 | Heating & Cooling
I think my cooling unit is shot, but about the same time of my fridge going out I had what seemed like a water leak. It was in a closet no where near any water lines,but on the same side of the closet...
These RV fridges are filled with ammonia, sounds like your unit has a leak, You should remove your fridge and possibly get it repaired , refilled and tested, or find a used one, These units are a few $$$$.
Oct 12, 2010 | Dometic RM2652 Refrigerator
I have whirlpool 220 classic refrigerator for last two week we find water outside front door of the refrigerator or below vegetable box . what is the problem
It can be due to an overflow of the drain tank that is at the rear bottom wherein when the defrost timer works , the frost condenses down to this tank.
It can also be a leak in the pipe line to the tank that causes the water to flow out.
It can be due to condensation within the door side that is flowing out., or even the collection tray leaking over , crust of frost falling out of the tray.
Oct 05, 2010 | Whirlpool Refrigerators
Ge profile .. refrig water leaking from freezer door near lower hinge.. seems like the water line?? any help ??
Must be the line going to water dispenser. The manual below has pictures. Use it as a guide to repair the leak.
PSS service manual
Aug 17, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Maytag MFI2569VEB1 french door refrigerator has started leaking water from underneath. Seems to be coming from the left (facing) side, near the front. I checked water connection in back and in the left...
I will look for your service manual and tell you that first it's most likely a blockage in the defrost condensate line. There are many reasons for this happening for example water leaking from a water supply line for the dispenser or ice maker, a in the defrost pan,
water leaking and draining through the refrigerator cabinet, but most are caused by a defrost drain line blockage.
Below is a link that may be helpful so try to take it all in and use the parts that most refer to your specific problem, Thanks Sea Breeze
Dec 17, 2009 | Refrigerators
Refrigerator leaking water
This sounds like the water line from the icemaker and the cool water reservior inside the refridgerator side. The line is a rigid plastic hose and could be a leak at one point that is small enough to allow water to run along the line. Also sounds like you have a humidity problem. Check the door seals and wipe them off and apply a thin coat of die-electric grease to the seal. this will help keep it pliable and soft.
The water in the bottom leaks into a trough that is made into the fridge. This usaully evaporates, This is for the auto-defrost. It keeps the water from getting on the floor.
Check to see if the outer door gets hot at the edges. If not, It may not be auto-defrosting.
I would first check the water line first as this seems to be a more serious issue right now. The line is probably loose at one of the connections between the ice maker and water reservior.
Jun 14, 2009 | Maytag MSD2456G Side by Side Refrigerator
Moisture on back black panel near the middle of the back of refrigerator
If this is equipped with an icemaker, check the water line for leaking also the ice maker water valve for leaking.
If you have a external condensate drain line on the rear,is it cracked and leaking?
May 25, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Water leaking from freezer
During the defrost cycle heaters inside the walls of the freezer turn on to melt the frost. The melted frost "water" is supposed to drain into a pan under the fridge where it will evaporate. I think the drain line from the freezer to this pan may be blocked. I'd also check the seal on the freezer door. If it's not sealing well it lets a lot of moisture into the freezer which means more water during the defrost cycle.
May 18, 2009 | Kenmore 64802 Top Freezer Refrigerator
Water seeping around fitting on back where water line fastens tp
Where does the water seep from?
The compression fitting you speak of is for the ice maker and through door water (if you have it.).
If water is on the floor, then chances are the drain pan underneath the unit has a hole in it, or for some reason, the water is not getting to the pan.
If water accumulates inside the freezer, check that the tube leading to the pan on the bottom of the refer is not clogged in some way.
If the water is in the refrigerator side, there may be a hole in the tank for the through the door water dispenser. It would leak everytime the icemaker dropped ice and refilled.
Jan 19, 2009 | Amana ARS2464B Side by Side Refrigerator
Samsung RF26XAERS Logo
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
