Lg intellowasher wd-8015c not draining?
The washing machine isn't draining the water, I have opened the p-trap at the bottom of the machine and rinsed out the water (dirty) also 2 coins came out too but have tried it on a wash again and it still won't drain the water? What can I do to try and fix this? thanks
  • 19 Answers
SOURCE: Running water
Sounds like your stand-pipe has fell over,located behind machine that the drain hose goes into.This pipe must be vertical,and secure.The top of the washers drain hose loop that goes into the stand-pipe, should be as high as your soap dispenser.If this is not the problem then your water pump must be pumping the water out all the time.Can you hear the pump? If so, some faults can force the washing machine into a constant cycle of filling with cold water and pumping the water away if it thinks the washing machine is overheating (possible faulty thermistor).Hopefully its only your stand-pipe causing the loss of water.Lets know how you get on.Good luck.
Posted on Sep 05, 2007
  • 343 Answers
SOURCE: hello. I have an LG intellowasher front loader
If you've waited the normal time for the interlock to allow the door to open and it's still locked, the interlock switch itself is probably faulty. Tricky job. Best to find a repair technician........Nomess
Posted on Apr 18, 2010
  • 2006 Answers
SOURCE: My LG WT-R807 8KG top
Did you try it in other cycles (delicate, permanent press, etc.)? The more symptoms - what works and doesn't allows better advice. Because right now it could be the control board, the timer, the drain pump and more.
Also you need to give us the model number off the id tag in your unit since that once keeps coming back as invalid.
Posted on Jul 14, 2011
SOURCE: LG Front Loader Washing machine: WD8013F
when we press wash,does not start. all light start flashing after 30 seconds.
Posted on Aug 18, 2011
  • 490 Answers
SOURCE: washing machine not spinning or draining water
its your drain pump if you can hear it humming but no water is draining it is blocked or jammed by a foriegn object (most probably a 20 cent coin or bobby pin/s), if you can hear it working as normal but still no water it may have a blockage sumwhere along the drain pipe either that or the impellor has snapped off the shaft and is ratteling around and not actually turning, and with the spin that is directly related to yor drain pump issue as the washer will not even attempt to spin if water remains in the tub, incredibly easy to do hit me back if you want detailed instructions
Posted on Oct 14, 2011
LG intellowasher 7kg wd-8015c
SURE VINEGER IS VERY GOOD ON CLEANING WASHER
May 02, 2014 | Washing Machines
My lg intellowasher 7kg wd-10130f does not pump and always stop and pre-wash , time lights become flash
Have you check the trap for something lodged in it, if there is water in the machine you can use the small hose next to the trap to remove the water from the machine before opening the trap. If you don't know about the trap read the owner manual. If you need help after that please feel free to contact me.
Mar 29, 2014 | Washing Machines
Lg intellowasher wd-8015c won't drain?
Most probably pump is blocked or the hose is blocked. Put drain hose lower or the blades are broken. It is not that hard to check if you know where the pump is and you can take it off without requiring special tools.
Aug 01, 2013 | Washing Machines
LG Intellowasher 7kg wd-8015c leak
Most of the time it is the door seal, open the door and check all the way round. check the sump hose and pump, sometimes it can leak from the soap draw hose to the outer tub, but not in your case I think. In most cases this can be fixed easy and is the door seal. to find out if it is coming from the front or the back, just place some news paper on the floor under the machine and take a look to see if it is the front or the back. a door seal is about 15/25 pounds retail
Oct 24, 2012 | Washing Machines
LG Intellowasher (Model WD-1023C)
The water pump can be blocked and thus stop the machine from finishing the wash cycle. In front on the bottom there is as hatch that can be opened with a flat screwdriver, the small black rubber pipe can be used to first drain all the water before the opening the filter. Small objects such as coins coluld be found in here, blocking the pump. Clean the pump by removing these, optionally blowing into the outlet (yuck!), to dislodge anything. If that does not help to fix the problem, you can clean that actual water pump, but this requires you to use a screwdriver to remove the pump.
Tilt the machine on its side, the pump is attached with 3 self-tapping screws. (if you can't figure out what the pump is you should probably let a technician do this). The pump has 2 parts to it, take it apart carefully and clean out all the dirt that has accumulated in there. Plastic friendly, waterproof grease can be applied to the pump spindle and bearing if available.
If the problem still persists a new pump is available from LG at a reasonable cost.
Jul 30, 2010 | LG Washing Machines
Hello. I have an LG intellowasher front loader wd-8015c which has finished its cycle but the door will not open.... how can I get it to manually open? I have tried doing another rinse cycle and pumped out...
Apr 18, 2010 | Washing Machines
Washing Machines Logo
187 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
