Question about Kenmore 78812 / 78814 / 78819 Gas Kitchen Range
Kenmore Gas Range/Freestanding/ Electronic Ignition
My oven will operate normally, but the top part of the range will not light. The gas company says there is no gas getting to the burners. The ignition is attempting to operate normally. I have recently moved into a new home and do not know if there is a secret combination to operate the top burners or not... Thank you, Pam
  • Anonymous Mar 28, 2014
    Sears Gas Range Cleaning Unit will not operate due to error code F5
I have an electronic ignition Kenmore Gas Range. The Model Number is 790.78573407.
Am getting the error code F93 in the oven control panel. The manual says the likely cause is "Maximum oven door lock time exceeded". When I plug the oven the "door lock light" flashes and then the "F93" error code flashes. Am not able to use the bake or broil.
Posted on Oct 14, 2007
Oven shut off and won't re-light
defective glow bar or bad safty valve. But if the glow bar does not light at all, most likely it will be a bad glow bar
Jul 09, 2014 | Summit WNM4307KW 36" Freestanding Gas...
Clock,timer and oven does not work on Kenmore gas Range
Let me know the model# and ill see if there are any thermal fuses. If not than most likely you will have to replace the EOC (Electronic oven control). Available at www3.sears.com
Oct 04, 2007 | Kitchen Ranges
Hi,My oven won't light but I can smell gas and hear the clicking when I went to light it Kit. Aid model # KGSS907 Thank you. Steve
which one is your model KGSS907SBL00 (30`` Slide-In GAS OVEN CONVECTION)
> KGSS907SBL01 (30`` Freestanding GAS OVEN CONVECTION)
> KGSS907SBL02 (30`` FREESTANDING GAS OVEN CONVECTION)
> KGSS907SBL03 (30`` Freestanding Gas Range with Convection Oven)
> KGSS907SBT00 (30`` Slide-In GAS OVEN CONVECTION)
> KGSS907SBT01 (30`` Freestanding GAS OVEN CONVECTION)
> KGSS907SSS00 (30`` Slide-In GAS OVEN CONVECTION)
> KGSS907SSS01 (30`` Freestanding GAS OVEN CONVECTION)
> KGSS907SSS02 (30`` FREESTANDING GAS OVEN CONVECTION)
> KGSS907SSS03 (30`` Freestanding Gas Range with Convection Oven)
> KGSS907SWH00 (30`` Slide-In GAS OVEN CONVECTION)
> KGSS907SWH01 (30`` Freestanding GAS OVEN CONVECTION)
> KGSS907SWH02 (30`` FREESTANDING GAS OVEN CONVECTION)
> KGSS907SWH03 (30`` Freestanding Gas Range with Convection Oven)
> KGSS907XSP00 (30`` FREESTANDING GAS OVEN CONVECTION)
> KGSS907XSP01 (30`` FREESTANDING GAS RANGE WITH CONVECTION OVEN)
Jan 04, 2013 | KitchenAid KGSS907SSS Gas Kitchen Range
I have a frigidare brand self cleaning gas range and the oven will not light
If the rest of the unit work properly, then you are having an electronic ignition issue. Contact your manufacturer and then a professional they suggest to have it repaired.
Sep 02, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
The gas is connected on the rear side of the stove but the pilot light is not lit, nor will it light. trying to trouble shoot the problem before deciding to purchase a new oven/range. Also, I remember...
You may have a pilotless ignition.Check around door frames for model #plate.
Also , open broiler door ,turn on oven and look inside . If you see an orange glow appear after awhile, that is the electronic igniter and you have an electronic ignition(no pilot).In this case the top burners use a spark ignition system.If you don,t hear clicking when you turn on a burner your ignition module might be bad.
Easily fixed though.
Aug 18, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
I have proble with whirlpool gas range SF265lxtq When I tried to use the oven, I setup the oven by the keypad, but the oven does not get hot, and i did not smell gas. What should I do ?
Your Direct Spark Ignition System contains a
Gas Distribution Valve and a Direct Spark Ignition
(DSI) Control that interfaces with the
Electronic Oven Control, and spark electrodes.
This provides the direct spark ignition and gas
distribution for Whirlpool self-cleaning gas freestanding
ranges. You must familiarize yourself with this system
before attempting any repair. Look through this service
repair manual for direct spark HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 01, 2010 | Whirlpool SF265LXT (Gas ) Kitchen Range
Oven won't work
sounds like electronic ignition is worn out
May 26, 2009 | Hotpoint 30" Self-Cleaning Freestanding...
When turning on oven it says f3 or f13 err and i can erase it
All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 06, 2009 | Electrolux Kenmore 30 in. Gas Freestanding...
No ignitors on gas range top
Pull out the bottom drawer and look for a cover over the spark ignition module. The ovens have glowbars and they have nothing to do with the top( different circuit).40a0b9a.jpg
Mar 11, 2009 | Maytag 30" Self-Cleaning Freestanding Gas...
Unplug the unit and see if this will reset the board. If this doesn't work then replace the oven control board.
Kenmore 78812 / 78814 / 78819 Gas Kitchen Range Logo
716 people viewed this question
Top Kenmore Kitchen Ranges Experts
Sal De
Marvin
Marvin
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
