Question about Panasonic RR-930 Desktop Cassette Transcriber / Recorder
I need to buy the main belt of rr-930 panasonic microcassette
4 Suggested Answers
  • 18 Answers
SOURCE: My Panasonic RR-930 transcriber speeds
Start by cleaning the capstan roller. The rubber roller and small steel rod just above it, control the tape speed. Just a little lint, build up or animal hair wrapped around this can cause the speed to vary. Clean with alcohol and a Q-tip.
Posted on Jul 28, 2011
  • 145 Answers
SOURCE: the backspace on my Panasonic
There is a switch on under the tape deck that wears out or comes loose. This is something that needs service. We can fax it. 8663219780
Posted on Aug 16, 2011
  • 145 Answers
SOURCE: where is the closest area to buy a foot pedal for
Have you found it? Check dictationmall.com
Posted on Oct 06, 2011
Panasonic RR-930 does not backspace with or without pedal. It engages the mechanism but appears stuck when tape is inserted. Runs fine without tape in deck.
The ancient tape is junk. Buy a new one. You might also try slamming the old tape against a wall or desk to loosen up the tape layers. Then FF and RW all the way.
Apr 20, 2015 | Panasonic RR-930 Desktop Cassette...
My stereo earphones with panasonic 930 only have sound coming out of one side. Do I need special ear phones?
Hello, This model needs a mono headset. You can get an adapter at Radio Shack for about $3. Item 274-368. You cam also purchase the correct headset, DH50 at dictationmall.com
Oct 13, 2011 | Panasonic RR-930 Desktop Cassette...
WONT REWIND OR ERASE
Could be a number of issues. Worn belt, loose reel cap on rewind spindle or broken rewind activation switch. You will need to get it serviced as none of the solutions are easially repairable.
Jul 11, 2011 | Panasonic RR-930 Desktop Cassette...
It won't play, rewind or fast forward.
Most likely the belt is broken or has jumped off. This requires some major disassembly, but the belts can be purchased for about $2. If the belt is okay, then check motor leads, they often break off.
Jul 07, 2011 | Panasonic RR-930 Desktop Cassette...
Have a panasonic RR930 microcassette transcriber. Right now the foot pedal will not allow rewind though when I press the pedal I can hear it engage. I can, however, rewind right on the unit itself. ...
If neither rewind nor backspace work, the common problem would be that the solenoid grease has dried up and the solenoid is not retracting all the way. However, the track that the mechanism moves in also wears out, as well as the plastic rocker that depresses the rewind button where it engages the metal slide.
If backspace works but not rewind from the pedal then the problem is the pedal.
Mar 23, 2011 | Panasonic RR-930 Desktop Cassette...
Spindles for the cassette do not turn
There is a rubber drive belt inside that needs to be replaced. It is Panasonic part number RDV101YA and this website says they have it:
http://www.partstore.com/Model/Matsushita/Panasonic/RR930.aspx?ModelAliasNumber=rr-930
I've never had to work on one of these machines so I can't tell you exactly what you might need to remove to get at the old belt and pulleys it rides on, but usually it isn't too bad of a job. Anyone with some patience and who is comfortable with small tools should be able to change it. Just keep track of what screws came out of where, what other pieces had to be moved, etc. so you can put it all back together. (Camera phones are great...you can take pictures at each step so you can look back.)
Dec 05, 2008 | Panasonic RR-930 Desktop Cassette...
Spindles will not turn
There is a rubber drive belt that needs to be replaced, Panasonic part RDV101YA. This place says they have them:
I've never had to work on one of these so I can't say exactly what you might have to remove to get to the old belt and pulleys it rides on. But it's usually not too bad of a job to change a belt.
Nov 12, 2008 | Panasonic RR-930 Desktop Cassette...
Panasonic RR-930 Desktop Cassette Transcriber / Recorder Logo
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
