Question about Necchi 3537 Mechanical Sewing Machine
Do not know how to release lock to wind bobbin
  • Necchi Master
  • 7,365 Answers
Here is a link for a manual, that should have the information in it
http://www.sewusa.com/Sewing_Machine_Manuals/Necchi_Manuals/3537_Instruction_Manual.htm
Posted on Aug 01, 2013
Bobbin wont come off the spindle after winding
Some machines actually have a lock to secure the bobbin in place when winding. You will need to find and release that lock.
Oct 01, 2016 | Sewing Machines
I am trying to wind on a bobbin and keep getting an error message of E9 which says in the manual When Motor is locked it will not allow me to wind bobbin
The machine you're talking about isn't indicated. However, when the motor is locked it is trying to run the needle and feed dogs at the same time that it is trying to wind the bobbin. This cannot be done simultaneously.
*** The place where you place the bobbin must be set firmly against the bobbin.
***Some newer digital systems still need the hand wheel to be released by hand. (Turn it, push or pull it)
Sep 29, 2015 | Sewing Machines
Why does display read "WINDING BOBBIN" and won't clear?
This video may help:
Winding an Elna bobbin
Perhaps the bobbin winding mechanism has not been released. (She unsnaps the bobbin when finished winding.)
Aug 31, 2015 | Elna Quilter's Dream 6003Q
Brother CS 8060 bobbin wont wind...but motor runs
no idea... did you lock thread onto bobbin so it holds to wind?
Jul 17, 2009 | Brother CS-8060 Computerized Sewing...
I have a designer 1 that won't release the bobbin.
Winding too tight;
Whenever your bobbin won’t come off any Viking, Designer 1 included, it’s because it wound too tight. This is how you know. It went on easy! To get it off, don’t pry, slowly unwind all thread, it will change shapes and let go of the bobbin winder. My favorite way to wind a bobbin on a Viking is to thread the machine through the needle and go under the foot then up to the bobbin winder (it has to be under the foot or it winds too tight. If it still winds too tight, lay your thread down instead of standing it up, the weight of the thread can increase tension on the winding process also check that you use a spool cap as large as or slightly larger than your spool. If it still winds tight. I’ll explain what bad thread can do.
Test your thread quality to start, thread your machine and LIFT the presser foot (this opens the tension disks). Pull your top thread straight back. If you feel no tension no mater how much thread you pull, your thread is good. If that your machine passes that test (tip: always check your thread this way when you thread your machine)
Mar 12, 2009 | Husqvarna Designer I
Singer 2662 winds bobbin only half full.
there is an adjustment on the bobbin winder. Just bend the little spring flap that rides inside the bobbin while winding. Bend it up a little. The flap being pushed up is what releases the shut off
Jan 05, 2009 | Singer 2662
Kenmore 15516 bobbin
1. Remove the bobbin case
2. Release the clutch by pulling out the handwheel
3. Draw the thread from the spool andguide the thread throught the hole in the bobbin from the inside to the outside
4. Put the bobbin on the bobbin spindle
5. Push the bobbin to the right
6. Hold the free end of the thread and depress the foot control, wind until full
7. Push the handwheel in (to wngage the clutch)
8. Push the bobbin spindle back tot he left to resume sewing mode.
9. Place the bobbin in the bobbin case (thread should feed clockwise)
10. Draw the thread through the slot in the bobbin case
11. Continue to draw the thread under the tension spring and through the opening Pull out about 4"' of thread
12. Holding the latch open position the bobbin case into the shuttle and release the latch
13. Case should lock into place when released
Hope this helps!
Bonnie
Sep 27, 2008 | Kenmore 15516 Mechanical Sewing Machine
Cannot wind the bobbin
Check to make sure that the bobbin is locked onto the winder. If is not locked on then nothing will move. I know I had this problem as well and found that the bobbin must be locked on the winder.
Aug 24, 2008 | Brother CS-8150 Computerized Sewing...
Can't wind the bobbin
Bobbin will not lock on bobbin spindle, what can I do?
Mar 20, 2008 | Brother CS-8150 Computerized Sewing...
Bobbin Winder won't release
i have a husqvarna rose, i has the same problem when i started using my machine. i was suggested to not wind the bobbin so fast. the reason it gets stuck is because the thread is so tight on the bobbin it actually makes the bobbin a tiny bit smaller, making it hard to get off again. if you dont wind it so fast, it doesn't get so tight.
kylee
Mar 14, 2008 | Husqvarna Viking 1
Necchi 3537 Mechanical Sewing Machine Logo
Top Necchi Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
