Question about Sharp Televison & Video
Sharp lcd tv modellc 32d44u power light blink no power i what to fix it i a tv technician allso
    Top Expert:
  • Sharp Master
  • 75,599 Answers
How many times do this power light blinks at one time switch ON? Count it. These are fault indication, called blinking codes. From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. If you're somewhat in electronics, you can make it right too. If you wish to get more details about these blinking codes, and fault indications, check the site linked here. http://electronicshelponline.blogspot.com/ Pull up previous posts, either by type in the Brand name to your set in its search box, or view it in Mosaic / Timeslide / Flipcard option
Posted on Aug 01, 2013
4 Suggested Answers
diodeic
  • 1622 Answers
SOURCE: Sharp AQUOS LC-32D44U 32 in. LCD TV turns off
Its the problem of overheating in the power supply board of the TV.on the power supply board of the TV there are few capacitors and IC.any of this ic is got short or may be weak.so due to this when you start the TV the current passes from electric outlet to the power supply board of TV.but when the current passes from that weak/faulty part at that time current gets stopped or slow and the board overheats and TV shuts off. this is a common problem faced by many other users too.the possible option to solve this issue is to check the power supply board by a meter and continuity tester and replace the faulty component on the board which is short due to which power supply board is getting overheated.its bit technical job but yes its not at all a costly repair to do or get it done by the technician. for required parts it can be easily available from local electronic hardware shop.
Hope this help in solving the problem, take care
Posted on Sep 14, 2010
walesarumi
  • 6993 Answers
SOURCE: my sharp aquos lcd tv
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to.
I do not think it needs replacement, rather some defective capacitors are causing this issue.
Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors).
After replacing these capacitor(capacitors) most likely the normal operation will be restored.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Good luck.
Posted on Dec 26, 2010
budmrtn
  • 11361 Answers
SOURCE: sharp 37" tv flat pannel
It is blinking because it sensing shorted circuits that are drawing too much current so it goes into safety shutdown mode, the shorts will more likely to be in the inverter board which draws the most power from the power supply module, try disconnecting the power cables to the inverter board to see if the TV will come on without the pictures but still has sound.
Learn more how to Troubleshoot LCD TV here:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Posted on Apr 01, 2011
My Sharp Aquos LC-32D44U Is malfunctioning.
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jan 13, 2017 | Sharp AQUOS LC-32D44U 32 in. LCD TV
Sharp aquos dolby digital tv has sound but no picture
go to source on your remote then click down to the second one like HD ONE.
Feb 21, 2015 | Sharp AQUOS LC-32D44U 32 in. LCD TV
SHarp TV does not turn on
Check and replace damaged component/s at it main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts.
Apr 01, 2014 | Sharp AQUOS LC-32D44U 32 in. LCD TV
My tv will not come on the power light is blinking on and off
Replace the electrolytic caps on the power supply module or just replace the power supply.
Mar 09, 2011 | Sharp AQUOS LC-32D44U 32 in. LCD TV
Can not power on and there is a green light flashing
You can reset the video board by holding Vol_+ and Channel - (or Vol - and Ch +) and pluging the TV in the wall and powering it on. It will run a reset cycle. It temporarily fixes this issue in most cases on most 32" sharp aquos LCD's. If this does not work, try downloading the service manual for this TV and go to the troubleshooting section. Most likely you have a power supply issue or a bad board, this can only be diagnosed by a technician, if your qualified to dive in we can start taking the set apart and start testing boards, if not I advise you to call a tech to help, that way if something breaks it's not your fault and a repair always comes with a Warranty. Most places will give you an estimate so you can decide if the repair costs out weight the costs of a new set.
Jan 07, 2011 | Sharp AQUOS LC-32D44U 32 in. LCD TV
Power blinking green light
Power supply section may be the problem, that will be the first place to look, look for caps with leaking/bulging tops, see examples of failed TV and monitors due to bad caps here;
http://s807.photobucket.com/home/budm/allalbums
http://www.badcaps.net
Jun 13, 2010 | Sharp AQUOS LC-32D44U 32 in. LCD TV
TV turns off on its own and the power and opc lights begin to blink
Like so many LCD sets--probably a bad CCFL inverter on this one too. I have seen it before a number of times on these sets.
Oct 09, 2009 | Sharp AQUOS LC-32D44U 32 in. LCD TV
TV not coming on
return it you have 14 days
Sep 19, 2009 | Sharp AQUOS LC-32D44U 32 in. LCD TV
Mt sharp aquos 32D44U doesnt recognize any remote please help
Unplug the TV from the outlet, press and hold power button on TV for 10 seconds, release, plug the TV in. Enjoy.
Aug 18, 2009 | Sharp AQUOS LC-32D44U 32 in. LCD TV
Televison & Video Logo
23 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
