Question about Sony Bravia KDL-46X2000 46 in. HD-Ready LCD Television
Standby light does not turn on
Standby light does not come on but the tv can be started form the panel power button. The remote is working fine but the tv cannot receive the ir
    Top Expert:
  • Sony Master
  • 74,634 Answers
Sounds like a main board [motheboard] fault. Contact service center.
Posted on Aug 01, 2013
  • 38 Answers
SOURCE: Hi, I have a new tv bought in france a tucson TL32HD782 Led light flashing but tv not working please help
Unplug it for a couple minutes. Try it again. If still not coming on, it's new you say? DON'T mess with it. Return it or call the place you bought if from. It's under warranty......That's the good news.
Posted on Dec 05, 2008
  • 668 Answers
SOURCE: TV suddenly stopped working - won't switch on from
The Power Supply is probably causing the problem if you are not getting any response or LED flash or Stand by
Posted on Jul 04, 2009
vinnyq
  • 157 Answers
SOURCE: sony bravia kdl-52w3000, turn tv on, no picture or
Most likely this is caused by a defective main board. Changing the main board will fix the issue about 95% of the time.
To be absolutely sure, the voltages need to be checked on the power supply. If they are not the values listed in the service manual, then you should replace the power supply instead (accounts for the other 5% of the time).
Posted on Oct 07, 2009
  • 277 Answers
SOURCE: The TV will not turn on either with remote or
your power supply is blown
Posted on Jan 19, 2010
  • 8457 Answers
SOURCE: will not turn on
Power supply board have dead leakage gases componnents call capacitors.These capacitors are dead or will not work properly.These capacitors alway bulges up it top or puff up it top.U know basic electronic's and soldering?Take ur tv aparts.Go all around the power supply board searches for these bulges or puff it top capacitors.Replaced these leakage gases capacitors,ur power will return to normal functions,and work.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Posted on May 03, 2010
How can i repair a tv that turns on but has no picture or sound
Have you tried a factory reset? I had a similar problem my TV was stuck on standby (red light only) I did this
  1. Turn on the TV.
  2. Wait approximately 40 seconds for the TV to completely start up.
  3. On the TV remote control, press and hold the UP ARROW button
and it worked!
Oct 16, 2015 | Sony KDL46EX400 46 in. HD-Ready TV
Rca 42pa30rq
Hi! Hope this will give hint... I understand some televisions nowadays are fully controlled using remote but there is always a standby power button for the television remote function. If the there is no power after turning on using the standby power button please check power cables, supplies and fuses. If the television has a standby power waiting the remote to act on but no response after pushing the remote's power button check the battery and its contact. Goodluck.
Mar 18, 2014 | Televison & Video
No standby light
Depending on the brand and MODEL number here is what I think happened.
All TV sets have a Standby power supply. It runs all the time even if set is off but plugged in.
It supplies among other things the power (usually less then 12 volts DC to run the remote circuitry---It usually is not fuse protected so if a strike hit nearby it may have come in via the power cord.
Trouble is almost certain to be in the standby supply.
Mar 17, 2012 | Televison & Video
I have lost the remote control now the tv will not turn on
The remote should not have any effect whether the T.V. turns on or off.
Have you tried to press the power button so that the standby light is on? On most Tv's the light should be red. Once the standby light is on press the button on the TV to change the channel, either the + or - button. This should switch the tv on.
May 03, 2011 | Televison & Video
The TV worked fine on Sunday evening, turned it off the normal way when went to bed. Came down to turn on in the morning and only the red light comes on indicating standby mode. I have unplugged...
There seem to be a problem that is why the television is not coming up and stays stuck on standby mode.
First try to turn on the television using the remote of the television and ensure that the battery of the remote is properly working, you can as well try to push the channel button on the television if the remote does not work.
If it does not come up both by using the remote and pushing the channel button, then it means it is a hardware problem, and that is from inside the unit of the television. Since the standby light comes up, it simply means power is reaching the main panel of the television.
This mainly used to be caused by a faulty or bad capacitor on either the main panel or the power panel of the television.
To check and fix, follow the steps below:
Dec 07, 2010 | Insignia NS-LTDVD19-09 LCD TV
TV doesn't turn on
I have a Mintek DTV265 which is almost the same TV the red light don't blink it stays on as long as the Power button is on. Try turning on the TV by pressing any of the buttons on the side of the TV Channel up or down, Volume up or down , or source. If it comes on then your TV is alright. I had one of them jumbo universal remote controls and it actually had a code that worked on my TV.
Mar 02, 2010 | Initial DTV372 37 in. HD-Ready LCD TV/DVD...
Remote control not working - not batteries, have changed them. Red lcd light is not showing will not turn on using remote control when tv is on standby
you can use buttons on side of tv to turn on
are batteries in right way
to test remote if you have camera on phone switch it on and point remote into camera and you should see flash of light when press any button if not you can get new remote form charles hyde and son ( CHS ) web site you will need model number on remote
Jan 02, 2010 | Samsung LN-S4051D 40 in. LCD Television
Hi, i have 2 televisions different makes both turn on to standby but wont turn on fully, the bush tv when i push programme button to turn on the red standby button flashes but nothing else.
I have the same problem, my Bush LCD worked fine last night but won't turn on today. The main power button on the TV puts it onto standby but the remote or the buttons on the side won't turn it on!....HELP!
Sep 06, 2009 | Televison & Video
TV wont turn on with power button or remote
Try putting the cables back where they were. After that re-route them again but this time use the manuel.
If that doesn't work, consult the TV's manuel.
Jul 04, 2009 | ViewSonic N3735W 37 in. LCD TV
Open Questions:
See all Sony Bravia KDL-46X2000 46 in. HD-Ready LCD Questions
Sony Bravia KDL-46X2000 46 in. HD-Ready LCD Television Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
