Question about Whirlpool Duet GHW9150P Front Load Washer
My washer keeps popping new circuit - Whirlpool Duet GHW9150P Front Load Washer
    Problem Solver:
  • 11 Answers
You havent given details when the breaker pops. Is it right away, in wash cycle, spin cycle or drain? If it pops right away, there has to be a short circuit, but it fills water up then as soon as the motor starts n it pops, it could be motor. If blows during spin, definately motor drawing too much current. Then it could be the breaker that is weak/faulty. The breaker if not faulty it will pop if the current drawn by the motor exceeds it's rating or there is a short.
Posted on Aug 01, 2013
Keeps blowing circuit breaker
It could be the circuit breaker, those do sometimes go bad, but it could certainly be something plugged into that circuit pulling more current than it should. Try disconnecting everything on that circuit. Does the breaker still pop? No? Plug one thing in. Pop? If not, keep going until you find the one that's a problem, and check the total amount of current all the devices you have plugged in use.
Most standard plug circuits are only rated at 15 amps. For example, a toaster may pull 12, a hair dryer 10. You can't run both at the same time on one circuit.
Jul 10, 2015 | Electrical Supplies
Why ge washer not spin or agitate?
Check to see if any power to that outlet to see if you have some power by plugging in a light or other electrical device. No power? check circuit breaker for Washer electrical outlet. If it pops back, you have a short somewhere. Unplug washer then try circuit breaker again. If the circuit breaker stays on, you have a problem in the Washer. Call Service man or may be cheaper to find a lightly used replacement, or buy new.
Aug 31, 2014 | GE WBSR3140DW Top Load Washer
ECM fuse keeps popping and fuel system don't work
There should be two ECM fuses. Number one powers the injectors and some of the solenoids along with the ECM. Number two or B powers the fuel pump relay and the rest of the ECM including the sensors that provide data to the ECM. Both are 10amp circuits.
You may need to get a shop manual to have the wiring diagrams to troubleshoot the circuits.
Sep 20, 2012 | 1988 GMC S-15
My amana fridge keeps blowing the GFI circuit
change the GFI circuit to 20 amp
Mar 30, 2017 | Refrigerators
What do I do when the big spring that is seemingly behind the rubber bladder of the the door opeing keeps popping out on my Whirlpool washer Duet?
that spring is for the door water seal if it "pops" off when you have a load of washing being washed you will flood your kitchen floor with water,,,fit a new door seal and a new spring fast!
Jun 29, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I bought a new circuit board for my ASKOw6021 washer because the old board was fried. I put in the new circuit board and now the washer will not spin and the door pops open. Any advice?
Could be a faulty door interlock.
This is a common problem of boards blowing, as the door lock shorts, and blows the main board.
Ifthe door does not lock, then it will not spin.
Hope this helps.
Feb 09, 2010 | Asko W6461 Front Load Washer
My fuses keep popping any ideas?
You have not supplied sufficient information so here is one possibility.
If you replace a fuse you must use one that is the correct amperage for the circuit.
Check your owner's manual for the correct amperage fuse for the circuit concerned and make doubly sure the correct one is installed.
If it is the correct amperage for the circuit please supply more information on the problem including which fuse keeps blowing:
1. Is the fuse popping immediately you replace it in the fuse panel and switch power to the circuit or only after a period of time of operating the vehicle? For example, if it is a lighting fuse, does the new fuse blow immediately you switch on the light concerned?
2. What is the function on the vehicle that has the power cut when the fuse blows?
3. Has there been any work carried out on any part of the electrical system or on electrical components of your vehicle prior to this problem arising? If so what was done?
Dec 05, 2009 | 1993 Mazda Protege
Whirlpool Duet GHW9150P Front Load Washer Logo
73 people viewed this question
Dan Webster
Dan Webster
Sal De
