Getting a car out of thick sand - Computers & Internet
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 72 Answers
Remove the air from your rear tires and now press the accelerator. It would come out.
Posted on Aug 01, 2013
I have a 06 Toyota corolla and have changed the starter 3 times but it still won't start. When I turn the key I hear a single click and a humming sound
Do the following:
- Clean the battery terminals with Luke-warm water, dry them with dry cloth and fix them firmly.
- Check the battery to engine ground wire. Remove the engine side ground wire and clean it with sand paper to provide a good contact. Replace this wire with a thick one to hold the current during starting. Also battery to starter wire should be thick enough to hold the current during starting.
- Check the alternator output and the battery health.
Apr 11, 2017 | 2006 Toyota Corolla
I am laying a walkway with paving stones. If I add 2 inch of sand to 375 sq feet of space, how much cubic ft of sand will I require?
Since a cubic foot is 12" x 12" x 12", if you were to make the sand 12" thick you would have 375 cubic feet of sand. However, since you want your sand 2" thick (which is 1/6th of a foot), you simply divide the 375 by 6 to get the value of sand in cubic feet (62.5).
Nov 17, 2016 | Office Equipment & Supplies
Sand Filter Pump
sounds as if you either have a clogged skimmer or a colasped hose , for this type stuff to happen
i have used coils of thick copper wire (dont rust) to keep hoses from sucking closed
Jul 08, 2014 | INTEX Sand Filter Pump
How do I sand the magneto on a Briggs & Straton 19.5 engine?
No need to sand it..it works on magnets rust does not effect it..but if you wish too.Remove the top cover of the engine and remove the mag..just make sure you measure the clearence with a clearence gauge before removing most are about the thickness of a business card...good luck
Jun 23, 2014 | Craftsman Garden
Can i refinsh the front o my refigorator
sure,. modify,. in real life we never really "fix",. we merely "adjust."
For best results scrape,, sand with low grit paper, graduate to higher, but don't go back to lower grade sand paper,. prime and paint.
Take your time so you do not get drips by planning on several light coats compared to one thick coat... watch the over lap and keep the sprayer at equal distance in a pattern either inside out or outside in - just be consistent.
Best regards
Ck
Dec 01, 2011 | GE Refrigerators
No spark
could be the coil needs sanded on the ends or the flywheel mag needs sanding. adjust coil thickness of 2 matchbooks
Nov 25, 2011 | Toro LX423 20HP Lawn Tractor 13AX90RS848
Rim of copco white enamel round dutch oven is chipped
U can get white "Araldite" to repair this. Build it up gradually to the thickness required. you may have to sand it back to match the rest then polish it.
Jan 03, 2011 | Ovens
Sheets keep coming off during sanding
The sandpaper will come off for one of these reasons: 1. The spring clips are to loose to hold the sandpaper. 2. You are using sandpaper that the paper's either too thick for the clips to hold it or too thin to withstand the work you are putting it through. 3. (Most likely) You are pushing down on the sander too hard while sanding. These types of sanders work by their own weight with only a little help from you.
Dec 30, 2010 | Bosch 1297DK 14 Sheet Palm Sander Kit
How do I replace the sand in my waterco t400 pool pump. Is there a manual available
Replacement of the sand is easy but there are a couple of things you want to do first.
Make sure you have a good shop-vac, get gloves, and purchase the proper sand.
This sand filter calls for #20 silica filter sand. (this will be available online, at your pool store, or at any water treatment facility).
Here is the link for this filters manual, and for the brochure (which has good pictures)
http://www.waterco.com.au/CMS/uploads/brochures/ZZB0512_Thermoplastic.pdf
http://www.waterco.com.au/CMS/uploads/Manuals/Sand_manual_829006.pdf
The manual has step by step instructions on filling and starting the filter.
The only part it doesnt tell you about is how to empty the old filter media.
To start this:
1. turn off circulation pump
2. Bleed any pressure or vacuum from the system using the bleeder valve, or just rotate the multi-port valve.
3. Open the drain valve at the bottom of the filter if there is one (some dont have one)
4. remove the collar between the multiport valve, and the tank. (this should be 2 phillips head screws)
5.Remove the multi-port valve.
you now have access to the sand.
6. Remove sand by whatever means (either a scoop or a good shop-vac with a thick hose)
be sure to be carefull once you get 2/3 of the way down the inside of the tank. There are LATERALS down there that are most likely brittle from chlorine.
Once sand is removed check and clean the laterals at the bottom of the tank.
Clean and flush the filter body and follow the directions in the manual to fill and start-up the filter.
If this helped, please vote positively for me.
Nov 01, 2010 | Pool & Spa
Water leak in travel lite truck camper has caused over cab bed area plywood to decay. Need diagram or schematic to determine best method of repair.
Hi brad, I had the same problem with a camper. I do not know of any available schematic, but would recommend dis-assembly of ceiling area to fix. It's not any easy job, but the only way to fix it properly. Remove all water damage section, make sure water is not pooling on the exterior roof. If it is collecting on the roof, you must brace it from underneath to raise any 'dips' so it sheds water, and make sure you apply a sealing coat (available at trailer stores, or on line) on the exterior. Also, if you park the camper when not in use, make sure you tilt it to help shed water more quickly. You have to use your carpenter and auto body skills to fix this. Don't put it off, I did and the roof deteriorates very quickly once you notice you have a problem. To remove plywood that is damaged, use a skill saw set at the minimum depth (thickness of the plywood) so you don't cut thru anything else. Use a drill to determine the thickness. To install new plywood, cut to fit the opening(s). Next get 3" wide by 3/4" thickness boards, place above cut out area, half on existing ceiling, half hanging over cut out, screw in thru existing ceiling into boards, attach replacement piece, screw into overhanging boards. You can putty over the joints, sand sand and paint, or just glue some sort of fabric to cover the area and make it look finished. Good luck!
Sep 14, 2009 | 1999 Chevrolet C2500
Computers & Internet Logo
14 people viewed this question
David Payne
David Payne
