Question about Garmin nuvi 2557LMT - GPS receiver
Nuvi 2557lmt how to reset - Garmin nuvi 2557LMT - GPS receiver
My garmin is not showing anything but waterways and unpaved roads.
Make sure that the unit isn't set to "Off Road" in the navigation settings. "Off Road" is for hiking. Also make sure that you have a valid city navigator map that contains streets and that it is selected (check marked) on the map info screen. Otherwise you may just be using the base map which only contains major highways
Dec 14, 2015 | Garmin nuvi 2557LMT - GPS receiver
Tip
Garmin Nuvi 1250 Hard Reset_2
Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245 , Nuvi 1250, Nuvi 1255, Nuvi 1260
Models: Nuvi 1300, Nuvi 1300, Nuvi 1310, Nuvi 1340, Nuvi 1350, Nuvi 1370, Nuvi 1390
Models: Nuvi 1410, Nuvi 1440, Nuvi 1450, Nuvi 1490
Does your Garmin Nuvi 1250 Freeze at Loading Maps?
Does it lock up or stop working?
This tip will describe how to perform a hard reset of the device, and how to backup your 'Favorites' in case the hard reset erases them. The next step in fixing your Nuvi when it doesn't start properly is to update its system software using Garmin WebUpdater.
A hard reset (or Clear All User Data) has been known to resolve unit quirks and strange behavior. It's generally recommended to perform it after a firmware update but is not required by any means. However, if you're seeing quirks and strange behavior with your unit after the firmware update, it is a good idea to do a hard reset of the unit.
Backup and Restoration Procedure for Favorites:
The Hard Reset procedure has been known to delete your Favorites, so back them up beforehand.
  1. From the Nuvi drive, copy '/Garmin/GPX/current.gpx' to a backup location on your computer.
  2. After the hard reset, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Nuvi, but be sure to rename it 'temp.gpx'.
  3. On the next power cycle, the Favorites will be read from 'temp.gpx' into the non-user accessible memory area on the Nuvi where they are actually stored.
Perform the Hard Reset:
*Note that this will clear all user selected settings on the unit
  1. Power the unit off.
  2. Remove the battery and wait several minutes.
  3. Install the battery.
  4. Press and hold (and continue to hold) the bottom-right corner of the screen while powering the unit on.
  5. Continue to hold the screen until the "Do you want to erase all user data?" prompt appears.
  6. Press "yes" and the unit will reboot. This resets all your location settings and user preferences.
If possible after the hard reset, let the unit sit outdoors in the open for about 30 minutes or so to let the unit re-acquire the satellite almanac data.
You have now performed a hard reset of your Garmin Nuvi 1250 series GPS unit.
I hope that helps.
__________________________________________
Garmin Nuvi 1250 Manual Download
Garmin Nuvi 1250 QuickStart Download
Garmin Nuvi 1250 Webupdate
Garmin Nuvi 1250 Favorites Backup
on Jun 18, 2010 | GPS
Tip
Garmin Nuvi 1490 Hard Reset Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245...
Does your Garmin Nuvi 1490 Freeze at Loading Maps?
You have now performed a hard reset of your Garmin Nuvi 1490 series GPS unit.
I hope that helps.
Garmin Nuvi 1490 Manual Download
Garmin Nuvi 1490 QuickStart Download
Garmin Nuvi 1490 Webupdate
Garmin Nuvi 1490 Favorites Backup
on May 27, 2010 | Garmin nuvi 1490T GPS Receiver
How do I access traffic on my garmin satnav
Do you have a traffic receiver? if no,you need to purchase one but if yes;
Ensure you are using the right cable and it is properly plugged in
Ensure that you are in a traffic coverage area when accessing traffic
Check to see that the service isn't disabled on your device
Update the traffic receiver software on your using GARMIN EXPRESS
Jan 31, 2015 | Garmin nuvi 2557LMT - GPS receiver
Tip
Garmin Nuvi 1450 Hard Reset Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi...
Does your Garmin Nuvi 1450 Freeze at Loading Maps?
You have now performed a hard reset of your Garmin Nuvi 1450 series GPS unit.
I hope that helps.
Garmin Nuvi 1450 Manual Download
Garmin Nuvi 1450 QuickStart Download
Garmin Nuvi 1450 Webupdate
Garmin Nuvi 1450 Favorites Backup
on May 27, 2010 | GPS
Tip
Garmin Nuvi 1450 Hard Reset Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245...
I hope that helps.
on May 27, 2010 | Garmin nuvi 1450 GPS Receiver
Load maps into 2557LMT?
Use Garmin Express to load maps on your nuvi.
Sep 07, 2013 | Garmin nuvi 2557LMT 5" GPS Navigator -...
Tip
Garmin Nuvi 1370 Hard Reset Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi...
Does your Garmin Nuvi 1370 Freeze at Loading Maps?
You have now performed a hard reset of your Garmin Nuvi 1370 series GPS unit.
I hope that helps.
Garmin Nuvi 1370 Manual Download
Garmin Nuvi 1370 QuickStart Download
Garmin Nuvi 1370 Webupdate
Garmin Nuvi 1370 Favorites Backup
on May 15, 2010 | GPS
Tip
Garmin Nuvi 1200 Hard Reset Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245...
Does your Garmin Nuvi 1200 Freeze at Loading Maps?
You have now performed a hard reset of your Garmin Nuvi 1200 series GPS unit.
I hope that helps.
Garmin Nuvi 1200 Manual Download
Garmin Nuvi 1200 QuickStart Download
Garmin Nuvi 1200 Webupdate
Garmin Nuvi 1200 Favorites Backup
on May 14, 2010 | Garmin nuvi 1200 Car GPS Receiver
Garmin nuvi 2557LMT - GPS receiver Logo
596 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
