Question about Sony Audio Players & Recorders
I have a 5 disc Sony home theatre system and it will not eject the DVDs or play them. It just keeps saying please wait
  • 3 Answers
Has anyone got the regional code for a lg dvd player bh7520tw
Posted on Aug 01, 2013
SOURCE: Phillips Home Theatre System
to play discs from different regions on HTS3548:
Before you begin, ensure you have connected your DVD player to your TV and both have the power on. Once you have connected the TV, follow the instructions below.
-- Open the disc tray
-- On the remote control, press in sequence:
Disc Menu
Stop
7 3 4 4 6 6 0
OK
-- Make sure Region 0 is showing on the TV.
This should hopefully help!!!!
Posted on May 04, 2008
SOURCE: DVD load / eject problem
This is a solution to all those who have either a DVD which does not load and which cannot be ejected and also to those who have the system stuck in MP3 mode. The solution is the same for both problems. Unfortunately due to the design of the HTS6510 it’s not a simple job but if you are methodical and take your time then most people should be able to do it.
 I personally think the problem stems from dust building up on the laser. I noticed that the extraction fan at the back of the unit draws air, partly, in from the front slot and over the DVD and (Sony) laser.
Anyway I’ll talk you through what I did but please be aware that this is not a screw by screw, connector by connector account.
You’ll need a small torx screwdriver (the unit is put together almost exclusively with a single torx screw size),  a very small Phillips screwdriver and a pair of snipe nosed pliers. Also a couple of small bowls to hold the screws in will be a good idea.
Firstly make sure the unit is disconnected from the mains. Then begin by undoing  the four torx screws at the back of the unit which are holding the cover on. Then remove the silver plastic side sections by sliding them towards the back of the unit. Under these you’ll see two more torx screws to be removed on each side. Remove these and you can then remove the top cover.
Have a look at the first attached picture. You should see the same thing with the lid off the box. I’ve labelled all of the assemblies up. There are four circuit boards which are arranged two on the top and two underneath these. You will be removing the top two (Audio amplifier board and the power supply board).
The aim of the game is to move the front section (the bit with all the control buttons on) away from the main section so that you can get access the to the DVD housing (this is the player unit where your DVD is housed). The front section is attached to the main section by four plastic clips (the plastic barb to metal slot type). Two are accessed from the base of the unit and more on each side. Don’t unclip these yet because the circuit boards are attached by ribbon cables which attach to the front of the unit . It is these ribbon cables which must be disconnected before the front can be unclipped and access can be got to the DVD unit. There are also a couple of bonding leads which attach the front of the unit to the ain chassis. These have small spade (push on) connectors and are very simple to remove.
You don’t need to disconnect all of the ribbon cables – just enough for you to be able to swing the front of the player out of the way.  Make sure you mark any connectors which you disconnect in some way so you remember where they connect to when you re-assemble the unit. I used a permanent marker to put a series of dots on the ribbon end of the connector and board end of the connector. (i.e. one dot on each denotes a pair, the next pair has two dots etc etc.)
Some of the leads which you will need to disconnect are attached to the two processor  boards which sit below the two uppermost circuit boards. Gain access to these by removing the four screws (one on each corner) holding the power supply board onto its mounting (there is also a nylon support in the middle of the board – squeeze it with a small pair of pliers to release the board).
Next remove the black plastic insulator sheet below the board. With this board removed, the metal shelf which the Audio amplifier board is attached to can now be removed. Note that some of the screws on the external back of the unit will also need to be removed before you can do this. You don’t need to take the audio amplifier board off the shelf – just remove the shelf and audio  amplifier board together.
You should now have an assembly which looks like my second picture. As with the top two boards unplug the connectors on the boards to allow the front section of the dvd player to be moved away from the main part of the system. Again don’t forget to mark the connectors so you know how to re-connect them.
If you have got this far you are doing very well!  I then undid the four screws holding the dvd housing and unshipped the entire housing, but with hindsight this wasn’t necessary. There are four Phillips screws holding the top cover of the DVD housing on. Remove these with your Phillips screwdriver and lift off the lid.
You can now remove the DVD / CD. At the same time carefully remove any dust which has accumulated in the DVD housing. Take care not to damage the delicate lens or its assembly. I used a dry cotton bud but a blast of dry air or a lens cleaning brush would be an even better choice.
Once the dust is removed refit the cover the DVD housing and assembly is basically a reversal of the dismantling. Once its all back together switch on and they system will be back to normal. If it doesn’t switch on – open it up and recheck your connectors – most likely one of them isn’t properly engaged.
Posted on Nov 02, 2008
welcomejee
  • 10594 Answers
SOURCE: I have a sony DAV DZ230 home theatre system
Push Power Protect is error sign when unit got problem in Power Amplifier section.
Let me know if you have electronics repair experience to help you further as I have all necessary info and schematics of DAV-DZ230 home theater system.
Posted on Nov 24, 2008
welcomejee
  • 10594 Answers
SOURCE: why does push power protector keeps flashing in
This is an error massage and comes when home theater got some internal problem specially in amplifier output section that can have defective output IC etc.
It is not user level repair and requires qualified tech for fix.
Thanks.
Posted on Sep 14, 2009
  • 864 Answers
SOURCE: how to turn off demo mode on a sony home theatre system davhdx265
Here is the manual: http://www.docs.sony.com/release/DAVHDX265.pdf
See page 18 for illustrated instructions for turning demo mode on or off.
Posted on Sep 15, 2009
DAV-DZ777 no longer plays TV sound through home theatre. DVD, radio etc still works...
The hdmi needs to be ARC compatible and connected to the HDMI connected labled Arc.
Sep 10, 2016 | Sony Home Theater: DAV-DZ777 CODE FREE...
My Sony Home thatre system DAV-DZ10 give a message : No Disk. How to solve that problem? Any help?
All DVD players will say no disc if there is no disc in the drive when closed. If however it does so when there is a disc in the drive, plus the disc is clean and undamaged, then you have a problem. It could be caused by dirt on the lens, but since it was doing funny things before there might be an electronics issue. I would still clean the lens first.
Jul 05, 2015 | Sony Dav-dz100 Home Theatre System
I have sony HCD-FL5D and I can't get my disk out of it,when turn on my device it displays "PLEASE WAIT" I have waited but nothing special happend,what should I do?
i have a sony HCD-FL5D .it is not playing disc and not eject disc and when playing tape A/B it is on standby. i am worried about this please helpe me.
Apr 01, 2011 | Sony DHC-FL7D System
I have sony avd-k800p and it keeps going on protect mode and then shuts off.how do i fix this
I am having Sony HTD-C800DP Home Theatre system. I would like to know how to play DIVIX DVDs. I couldnt successful. Any one of you please help me in this. Kindly send information to my e-mail id thayumanavan@yahoo.com
Thanks in advance.
Regards,
Thayu
Jan 24, 2010 | Sony HTD-C800DP System
Panasonic home theatre system 5 cd changer says no play when inserting dvd
Try cleaning the pickup with a cleaner disc-i'm assuming this unit IS supposed to play DVDs, of couse!
Stan
Mar 19, 2008 | Panasonic sa-ht930 Home Theater Audio...
Sony DAV SB100 home theatre DVD / CD problem
Grating adjustment is off, Compounded by dirt on the secondary lenses...accordianman
Feb 19, 2008 | Sony DAV-SB100 System
Disc Menu
Stop
7 3 4 4 6 6 0
OK
Jan 02, 2008 | Sony DAV-SA30 System
Problem playing CDs
did you put the firmware update, perhaps it can solve the problem
Nov 11, 2007 | Sony DAV-DZ100 System
SONY Model No: DAV-D150G DVD play problem!!
dav-dz100 a disc cannot be ejected and locked
Oct 06, 2007 | Sony DAV-DZ100 System
Once you have connected your dvd player to your tv and the tv is turned on. Turn on the machine and press "disc" on the remote control. Open/Eject the disc tray. Press STOP on the remote control. Enter the following numbers slowly on the remote control " 7,3,4,4,6,6,0". Configuration will appear on the bottom left hand side of the TV for three seconds. Press "PLAY" to close the tray. The DVD player eill return to normal operation. This SHOULD make the player Region free.
Sep 01, 2007 | Audio Players & Recorders
253 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
