Question about Garden
I had to change the blade on my CM1936. The hex bolt that holds the blade on had fused to the thing it screws onto -- the metal bar with threads that goes through the middle of the mower. I had to saw off the hex bolt. Now I need to replace the thing the hex bolt screws on, but I cannot tell what it is. Which part is it? Is it the bottom of the motor assembly? It appears to be called a mandrel or a spindle on other mowers but Black and Decker does not use that term.
You shouldn't have sawed it off. This wasn't a hex bolt, it was a nut threaded onto the motor shaft. The motor shaft is now damaged and so the entire motor will now have to be replaced....unless you can get a machinist to drill and tap a threaded hole in the center of the remaining motor shaft. Good luck!
Posted on Aug 27, 2013
  • 257 Answers
SOURCE: Mower stalls when engaging blades
check the safety switch for engager could be bad,, hope this help,, good luck
Posted on Aug 15, 2009
  • 62 Answers
SOURCE: Where can I find a Manual for Black Decker 19\'' Mower
Is this the lawnhog model MM875?
http://www.blackanddecker.com/ProductGuide/Product-Details.aspx?ProductID=2508
Check here for the owners manual
Posted on Apr 18, 2009
  • 3 Answers
SOURCE: Need image, assembled craftsman model 917.276813 lawn mower deck
http://afternoon-tea.bordadom.vu.cx/index.html italian wine bar
[url=http://afternoon-tea.bordadom.vu.cx/index.html]italian wine bar[/url]
<a href=http://afternoon-tea.bordadom.vu.cx/index.html>italian wine bar</a>
Posted on Aug 26, 2009
  • 95 Answers
SOURCE: Have 54 inch Craftsman mower deck that I am
Depends on how old the deck is. Some of the older spindles and mandrels were not made to came apart. The newer ones you can put the nut on the top threade to protect the threads and a couple of taps it should come out. If you have a model number you can got to sears web site aa they will have an exploded view. http://www.searspartsdirect.com/partsdirect/index.action
Posted on Mar 21, 2010
SOURCE: Black and decker mower switch wiring
I have a Black and Decker Electric mower #M2370, which I would like to use this year before moving to a condo. Last year, the mower was stopping and starting depending on how the lever was positioned. I suspected the wiring so I removed the on-off switch lever. The wiring appears intact. Part of plastic inside the lever maybe broken. Can i use the mower without the lever by just pushing the black button?
Posted on Mar 31, 2010
How to change radiator fan blade on 1998 Toyota Tacoma
You must never have opened the hood &
even looked or ever worked on a vehicle
Appears all the motor options have 4 studs & 4 nuts
holding the fan clutch assy on & 4 bolts holding the
fan blade to the clutch
Nov 20, 2014 | 1998 Toyota Tacoma
How to change knives
First, safety stuff: Make sure the jointer is unplugged and be very careful with the knives, they are quite sharp.
You should have enough room between the tables to get the knives out, if not remove the stationary, outfeed table. There are four hex-cap screws on each knife that hold the clamp bar on. Remove them with an allen wrench or hex driver if you have one and take the clamp bar and knife out. Pay attention to which way the bevel is on the knife so you put them back on the same way. If the blades have never been turned, they are double sided and can be turned around so the opposite side is out. The knife and clamp bar are designed to go on only the right way. Make sure you get the hex-bolts on very tight. Do the other knife, replace the table and make a couple test runs to check allignment.
Jan 27, 2012 | Delta Machinery Masonry Tools
I need directions on how to change the baldes on a reciprocating saw.
There are 2 types of clamps that hold the blade in that type of saw.
Since this one most likely has the type where the blade is held in place with a set screw and a "U" shaped piece of metal that holds the blade tight against the shaft. There should be a screw hole in the shaft of the saw. The blade rest next to the shaft and then the metal piece clamps the blade against the shaft. This is all held in place by a set screw that screws into the shaft. This screw uses a hex key to remove and tighten it.
If your tool doesn't have this style then it should have a twisting clamp. This will rotate and release the blade. Sometimes a pliers is needed to loosen the collar, but not to tight tho.
Jun 30, 2011 | Skil 921502 85 Amp Reciprocating Saw
How do you change the blade on a miter saw
first unplug the tool, raise the head and loosen the bolt that holds the lower guard in place. DO NOT disassemble the lower guard, pull it down and it will move out of the way somewhat. Next there is a spindle lock that you push in rotate the blade until locked and hold it while removing the hex bolt, which should be left hand thread, I would use a pair of gloves when holding the blade just for safety. Remove the outer flange and spacer (if needed) reassemble in the opposite order and before trying rotate the new blade by hand to make sure turns freely. Let me know if you need more assistance.
Feb 16, 2011 | Saws
How do i change the blade on my delta 10" mitre saw
Exploded diagram for your SM100M miter saw is here.
User manual is here.
Page 20 covers blade change operation.
Make sure you unplug your saw! You need to remove a screw from the cover and rotate the cover to the rear. Use a hex wrench in the motor shaft to keep the saw blade from turning, and loosen the arbor nut with a 1/2" wrench. The arbor is reverse threaded, so you'll turn it clockwise to loosen, then counterclockwise to tighten it up after you have swapped the blade.
Rotate the cover back after that's done, and replace the screw.
If this was useful, please vote. Thanks.
Nov 23, 2009 | Delta SM100M 13 Amp 10" Compound Miter Saw
Replacing a starter
I would drive car onto ramps or raise front end on jack stands. 1st take out the two hex head screws that hold on the plastic cover between starter and motor. I had to use a pair of large pliers to pull cover down, you have to pull hard. Then you can see the two bolts that hold starter on. They might be very tight or rusted. I had to use a 1/2 drive breaker bar to break mine loose. The front bolt will be easy but the back bolt is difficult. You will probably need flex-socket. I ended up putting a 1/2 " drive breaker bar onto a 3/8 drive flex-socket with an adapter. This back bolt is about 5" long and difficult to remove even after it is out of the threads. Now take off the two wires that are on the terminals on the back of starter. You will need a 8mm wrench or socket for the small one. You may have to try several ways to remove the starter after it is loose. You then reverse the process This is a fairly difficult job and I do not know if you can do it without a flex-socket for the back bolt..
Oct 19, 2009 | 1993 Oldsmobile Cutlass Ciera
Need to take off fan clutch, have taken off parts in the way
4.9L SFI
SPECIAL SERVICE TOOL(S) REQUIRED Description Tool Number Fan Clutch Holding Tool T84T-6312-C Fan Clutch Nut Wrench T93T-6312-B
Removal
  1. stj~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: The large clutch assembly nut has a right-hand thread and must be rotated counterclockwise to remove it.
    Remove the fan clutch (8A616) from the water pump (8501) by turning the large nut, which is part of the fan clutch, using Fan Clutch Holding Tool T84T-6312-C and Fan Clutch Nut Wrench T93T-6312-B.
  1. Remove two screws retaining fan shroud.
  1. Remove the fan blade (8600), fan clutch and shroud.
  1. If the fan blade and fan clutch have to be separated, remove the remaining bolts attaching the fan blade to the fan clutch
5.0L, 5.8L and 7.5L Engines
Removal
  1. Remove screws retaining fan shroud (8146) to radiator (8005).
  1. Remove four screws retaining clutch on water pump hub.
  1. Pull fan clutch and fan blade off water pump pilot and remove fan clutch, fan blade and shroud from vehicle.
  1. Remove four screws and separate fan clutch from fan blade.
Item Part Number Description 1 8509 Water Pump Pulley 2 57632-S Screw and Washer Assembly, 5/16-18 x .62 Hex 3 8600 Fan Blade (5.0 and 5.8L) 4 8600 Fan Blade (7.5L) 5 8A616 Fan Clutch 6 380288-S2 Screw and Washer Assembly, 5/16-24 x .88 Hex A — 16-24 Nm (12-18 Lb-Ft)
Mar 10, 2009 | 1994 Ford F150 Styleside Supercab
Trying to take apart a Kenmore Ultra Wash 665
normal threading on the screw, trick is totry to hold the impellar, while trying to loosenthe bolt, sometine placing a screwdriver in form the side, allows you to hold it
Mar 07, 2009 | Kenmore Dishwashers
Change blade
OK first raise the cutting head. Loosen the screw that holds the guard in place and move out of the way. Find the spindle lock on the right hand side of the gearcase and turn blade by hand (UNPLUG SAW FIRST) until it locks. With the wrench supplied with saw put it on the blade bolt and turn it clockwise to loosen, it has left hand threads, remove outer flange and blade. Let me know it you need any more help
Jan 24, 2009 | Black & Decker DW713 10 In. In. Comp Miter...
Changing the saw blade on a Ryobi Mitre saw
There may be a push button type blade lock, and on many of these saws the retaining bolt for the blade is backwards threads, e.i., looking at the top of blade retaining bolt, turn it clockwise to loosen. This would normally tighten, but in the case of many of these saws, it loosens it.
Jan 04, 2009 | Ryobi ZRTS1342L Factory-Reconditioned 14...
Garden Logo
76 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
