Question about Gateway LX6810-01 MCP7AM01G1 MB.G5409.005 Socket 775 Motherboard
I just need to know where to plug all of the wires back into the motherboard specifically the red and white power button wires
Where on a Gateway DX4200 MB does the red/white wire coming from the power on switch?
You'll need to get your hands on the manual for that specific motherboard to determine where the pins are for the two Power On plugs. Lacking that, many motherboards have the pins for the entire set of front panel wires labeled--I do suggest you get a magnifying glass if you're stuck with this route, and the labeling is often not specific as to the precise placement of the plugs onto the motherboard's pins, meaning you'll sometimes have to simply trudge through the tedious process of trial-and-error.
Apr 28, 2014 | Gateway Computers & Internet
Emachine w3107 wiring diagram
Good luck on finding a wiring diagram. Usually those plugs represent the Power Button, the Hard Drive and the other sometimes represents a reset button. If you remove the cover and sit the computer on it's side, take a flashlight so you can see inside at the motherboard. If you look from where the wires come from on the front they usually stick into little prongs on the side of the motherboard. The motherboard will have little written identifiers such as hdd for the hard drive light, pwr for power or power reset, fan for fan, etc.
Also sometimes if you look on the little piece at the end of the red, white and black wires where it plugs into the motherboard prongs, sometimes it will have writing on it as to which one it is.
Mar 24, 2012 | Computers & Internet
I need to find out where the 3 little plugs go that are connected to the power button theres a blue/white black/white red/white plugs comming from it going to the motherboard
Sometime these connectors from the desktop case front panel have labels indentifing what each connector/plug is for. From your description they could be a reset switch or LED indicators for hard disk or power light etc.
If the plugs are not labeled then trace the wires back to the front panel to identify what they are attached to.
When you connect the LED indicators to the motherboard and it does not light up when they suppose to, then turn the plug around 180 degrees.
The LED are polarity sensitive ie they only light up if the + and - leads are connected to the motherboard correctly.
Nov 08, 2009 | Computers & Internet
I need to know where 3 wires go
The wires should be labeled HDD,POWER, and i think RESET or somthing, just look on the motherboard within cord reach and you should see all three labeled on the motherboard all grouped together.
Oct 26, 2009 | E-Machines eMachines Desktop PC
Unplugged power button from emachine t3624 forgot how to
If you can not see a "+" and "-" sigh on the connector as well as on the motherboard, then try it both ways. If you get it wrong the first time, it will not harm anything, just plug it in the other way if it does not work. Good luck!
Jul 19, 2009 | eMachines EL1210-11 PC Desktop
How to place indicator led cables to motherboard
hey look close to the nearby processorin motherboard there is 9 pin (depends on motherboard) for power and for reset button... close your eyes to motherboard at that place you will find also the name which are mention in motherboard e.g. power and reset in motherboard just plug red wire in power and and green for reset ( depends on motherboard) you an chk manually ...
Apr 05, 2009 | Computers & Internet
Gigabyte GA-8INXP Motherboard Problem- front connector pins
If the wires from the reset switch is white/blue the blue wire is positive, Hdd red/white red is positive power Green/white Green is positive etc. The wires on the speaker connector will be red/black/black/white - red is positive. The colored wire is always positive. On all GA mb's the positive connection is always towards the back of the MB and are marked with a + on the base of the pin as you can see on the photo. Hope this help.
Sep 19, 2008 | Gigabyte GA-8INXP Motherboard
Wiring info
Most Mobo's have printing next to the places that are jumpered or pluged into. The ones you need sould be close to the edge of the mobo, that is close to the front {power button} side.
May 30, 2008 | E-Machines (308714) Motherboard
Front panel wiring
Hi, Maybe we can wing it if you can send an image of the motherboard closeup on the F_PANEL connections and the wires from the front panel itself, or get the specific motherboard model during POST so we can try getting URL of manual. In some instances, the front panel wires are: Green wire, power on green light +, white wire is power on green light -; Red & Black, speaker; Red & white - HDD red activity light indicator where red is HDD + & white is HDD -; Orange & white - Reset Black & White - power on Post back so we can figure things out. Good luck and kind regards.
Aug 23, 2007 | Micro Electronics PowerSpec 8250 PC...
Gateway LX6810-01 MCP7AM01G1 MB.G5409.005 Socket 775 Motherboard Logo
41 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
