Question about Homelite Mighty Lite Lawn Trimmer
Homealite 26cc hard to startweed wacker - Homelite Mighty Lite Lawn Trimmer
    Problem Solver:
  • 8 Answers
One small two-stroke engine, the spark plugs becomed gummed quite fast. It is a recommended maintenance procedure to replace them yearly. This is often neglected.
I would recommend replacing the spark plugs, it is cheap to do so and should be done regardless.
Another suggestions is to check your fuel mixture. Ensure that you are using the correct mixture of fuel and oil. Too much oil can hinder the detonating ability of the fuel and make it harder to start.
IF the trimmer was stopped VERY suddenly by jamming or stopping the trimming end, you may have damaged the starting mechanism.
As always, start with the easy and required steps.
Hope this helps.
Posted on Aug 01, 2013
How do i get the cap off of my weed wacker 26cc model #ut32655
what cap would this be . gas perhaps you over tightened it and need to use channel locks a bit
Sep 15, 2015 | Garden
Where can i get a part for a ps200
http://www.tmsequip.com/part/wacker-neuson-part/wacker-neuson-part-0152391-impeller-ps2-400-500-psa2-500/
Sep 26, 2014 | Wacker 2" PS2400 Submersible Pump...
Wacker plate won't reverse
what is a wacker plate i wonder ,is this a point on the vehicle you hit with a big hammer if it doesnt start i wonder ?
Aug 18, 2012 | Cars & Trucks
Homelite trimmer, gas, string - y is the string wrapping itself around the head of the trimmer?
The line on my new 26cc Homelite would also feed out by itself. That started me thinking the line was wound backwards. I wrapped the line in the opposite direction as was shown on the bump feed reel and now the dang thing works although the bump feed needs to be "bumped" pretty hard to work. Is it possible that the reel was manufactured with the (string direction) arrows pointing the wrong direction? The new 26cc unit is also underpowered compared to my older 25cc trimmer.
Jul 20, 2010 | Homelite Factory Reconditioned 26cc...
Hard start tb475ss troy built weed wacker when i close the cold start lever it starts but its 75 degrees out its like the primer ball is inop but i see fuel moving through the lines when priming did not...
These 4 cycle trimmers need to be primed 10x before a cold start. The bulb will feel *firmer* on the last two or three depressions and you'll know that the carb is primed.
Full choke and and full throttle on first tug should see it hit once with a puff of smoke. Second start attempt should be in choke position two (half choke) and with full pressure on the throttle. Should rev to life on start attempt. Let the engine IDLE for 30 seconds, moving the choke to off at the end of the waiting period. Let engine idle to warm another full minute with no choke, then set to work!
May 02, 2010 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
To keep my Makita weed wacker running I have to close the choke about 3/4. I see no mixture adjustment on the carb and everything appears clean.
An IPL for a 26cc line trimmer can be found here:
BCM2610 Line Trimmer
http://www.makita.ca/data/upload/tools/BCM2610.pdf
The carburetor is pictured but not where it mounted on the engine or how you gain access.
It sounds like it is very lean. Have you cleaned the air filter? Checked for leaky fuel hoses? A loose carb or damaged boot may also be the cause. There is a reason it is running lean. HTH
Lou
Continued operation in a lean condition may cause it to cease.
Oct 02, 2009 | Makita DCS51018 18" 45cc Chain Saw 2 Cycle
Weed wacker
check the fuek lines for hole and leaks, check the fuel filter and clean if necessary. remove the carbuerator and inspect the gasket; it should be soft and flexible, if it seems hard or brittle replace it. clean the carb with carb cleaner sray (available at any local auto parts store) and compressed air. make sure you get inside the small fuel rail holes. if that doesn't work have the carb repaired at a service center or replaced.
Oct 31, 2008 | Garden
Homelite Mighty Lite Lawn Trimmer  Logo
50 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
