Question about Apple iPod Audio Players & Recorders
My ipod doe not have sound and a popup says generic volume cannot be stopped
  • Apple Master
  • 27,725 Answers
Follow these steps to reset an iPod Classic, or in fact any iPod with a Click Wheel.
Make sure the iPod Classic isn't simply paused or locked.
Check the screen for a lock symbol.
If you see a lock, unlock the Hold switch.
You should be back in business.
Put the iPod on a flat surface to stabilize it.
Slide the Hold switch on, then slide it off.
Hold down Select and Menu together for several seconds with two fingers.
Make sure your finger isn't touching the Click Wheel.
When the Apple logo appears, release Select and Menu.
If the iPod Classic doesn't reset, repeat the above step.
If that still doesn't get your iPod Classic to restart, plug the iPod into a power adapter or a computer and see if it starts up.
http://support.apple.com/kb/TS1382?viewlocale=en_US(URL)
Posted on Aug 04, 2013
Iphone not displaying sound volume controls
The phone does not show the volume level unless you are changing it. When you press a volume button on the side, a popup will show the current level.
Aug 17, 2015 | Apple iPhone 4S
Tip
How do I make my iTouch Louder
<p>He the volume of the iPod Touch can be affected in some way, the definition of musical sound check the volume limit set in the settings device preferences. The tool of sound check, which can also be found on iTunes, check your iTouch music and video library for the stabilization of the equalizer song for a constant level, the volume limit reduces the volume to grow beyond a set point, which helps the potential adverse effects of hearing loss caused by loud music. <br /> <p><br /> <p>1. Press the button to the left of the iPod Touch. The volume switch top left of the iPod Touch increases the sound volume, and gives a volume icon on the screen as it grows. Accident on the volume button for the iTouch, it seemed sound problems. Touch the "Music" icon to start playing the song, press the volume for music to grow. <br /> <p><br /> <p>2. Adjust the volume control settings. Tap Settings on the iPod screen Touch, Touch "Music" and tap "volume limit." Slide the tab to the right of way to reduce the volume bar to change the limit of the maximum. Press the Home button to save and Settings. <br /> <p><br /> <p>3. Sound Check off. Tap "Music" in the Settings window and slide the guide Sound Check to the left to the sound check feature off. A Sound check song keeps playing very hard at the same level. While the function prevents sudden jumps in volume, can also lead to a series of songs to play very soft, depending on the quality of the music. <br /> <p><br /> <p>4. Adjust the volume to your headphones. Press the "+" button on your Apple headphones, the volume of a music or video playback to increase. If a song or video does not play, the volume control adjusts the volume on the iTouch. <br />
on Aug 05, 2011 | Computers & Internet
I have no sound on my ipod and apopup say generic volume running
Damaged hardware is responsible for the most obvious iPod sound problems.
In such cases, Apple may be able to help you fix the problem, depending on the status of your warranty.
All iPods have a one-year warranty according to Apple's website.
Software problems can also affect your audio.
For example, downloading a non-certified Apple application can stop your sound from working correctly.
Returning your iPod to its original factory settings fixes many of these software glitches.
Plug in a different set of headphones and test the sound.
If that set works, your old headphones were the cause of your audio problems.
If your iPod still doesn't work, proceed.
Remove an application on your iPod Touch if you installed it right before your sound stopped working.
Hold your finger over the top left corner of the application.
It will shake.
Touch the "X." Touch the "Home" button.
Restore your iPod to fix other potential software problems.
Open iTunes. Plug the iPod into your computer with a USB cord.
Click on your iPod on the left-hand menu.
The iPod will be listed under the name you assigned it when you first set it up.
Click the "Restore" button on the menu.
Leave the iPod alone while it restores.
It may take several minutes.
Test the sound once the restore is complete.
The iPod syncs after restoration.
Once the sync is complete, the process is over.
Contact the Apple Technical Support line at 1-800-275-2273 if your audio still doesn't work.
Have your iPod with you.
Aug 01, 2013 | Apple iPod Audio Players & Recorders
Generic volume
Damaged hardware is responsible for the most obvious iPod sound problems. In such cases, Apple may be able to help you fix the problem, depending on the status of your warranty.
It will shake.
Open iTunes.
Leave the iPod alone while it restores. It may take several minutes.
7th generation ipod nano has no sound
Hi Katherine
Try this solution to your problem...
Turn on Ipod, on the left hand side there is a volume
control switch. While you are on a song, hold the top of the
volume control switch to increase the volume.
If that does not work then go to "Settings". then
"music" and make sure your "Volume Limit" is
set to "Off", if it is not then touch "Volume Limit" and set it
to "Off"
Please do not forget to rate me
Bud
Oct 29, 2012 | Apple iPod classic 7th Generation
Works great , but Ipod dock only will give about half volume
All Ipod docks bypass the audio processor, so your volume and equalizer presets on the ipod will not work. Use the volume knob on the home theater unit itself.
Dec 20, 2009 | Audio Players & Recorders
Bose Sound Dock remote control - only volume works
My remote worked perfectly until I changed the battery. The original battery was CL 2032 and I replaced it with DL 2032. After replacing the battery, only the volume control works. The off button will only fade the sound while the button is depressed. Release the button, and the volume returns to the original level and the unit remains On.
None of the other buttons work.
If you've found a solution, please post it here.
Oct 03, 2009 | Bose SoundDock® (Black) Docking Station...
2nd gen touch (model mb528ll)internal speaker stopped after OS upgrade to v3.1.1. Headphones plugged in work fine, butwhen they are removed silence reigns. How do I get back the internal speaker after the...
My guess is it's a faulty upgrade, unless you aren't adjusting the volume after you take the headphones out (when you take headphones out, music stops, and the volume changes).
Try restoring it. If it still isn't working after that, try re-downloading the os 3.1.1 update. It could just be a corrupted file, and it does sound like it.
Sep 28, 2009 | Apple iPod touch
Volume does not go all the way down
there is no real problem its just that it dosent mute
Jul 12, 2009 | Apple iPod classic MP3 Player
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
