Question about Field & Stream Eagle Talon Kayak
Where do you find replacement foot pads for Field and Stream Eagle Talon 12?
I have a 95 eagle talon tsi ran fine then shut it off and now cranks but won't start
smack starter with hammer while someone cranks if it works its your starter. Also make sure your battery has 12 volts.
Apr 02, 2015 | 1995 Eagle Talon
Wheels are locked on 1991 non turbo eagle talon
The brake pads have rusted to the rotors. Less likely, there is a brake caliper that is stuck due to rust.
Apr 22, 2014 | 1991 Eagle Talon
Why does my eagle talon esi keep cutting off when I take my foot off the gas?
Throttle Position Sensor could be acting up. You just replace it. No troubleshooting correctly by the novice.
Jun 02, 2011 | 1998 Eagle Talon
How do i get the brakes pads off a 1992 eagle talon? Usually you loosen the 2 bolts and pull it right off and replace the pads but there's only 1 bolt and i cannot get it off!
chrysler, dodge, jeep, eagle, all are kind of mutts when it comes to parts, including brakes. don't take offense; some of the best dogs out there are mutts. the point being your brakes could be a wide range of designs. look for retainer clips or pins or larger pins or "slider bars" that can be removed to access the pads. often such setups allow prying back the caliper pistons using a screwdriver while leveraging it against the pads or rotor, and removing the pads without even removing the caliper.
Oct 09, 2010 | 1992 Eagle Talon
Boost cut
Too lean on boost. Not enough fuel.
Oct 17, 2009 | 1995 Eagle Talon
93 eagle talon starting issues
did you check the body ground?
Aug 31, 2009 | 1995 Eagle Talon
I have a 95 eagle talon esi 2.0 i have replaced
Sounds like you have a timing or elctrical issues, try checking your voltage from your battery and alterantor, if it checks out fine move on to your timing. The timing is tricky but very critical with these cars
Jun 03, 2009 | 1995 Eagle Talon
92 eagle talon tsi hard to start
i think mostly its hard to start because its a 92 eagle talon.. might be time to put 'er down.. ;)
Jan 16, 2009 | 1992 Eagle Talon
Engine Light does't come car will not start
did you get the codes by doing the "key dance"(on,off,on,off,on) ?
if so, it almost always flashes a 12 and 55. here is what they mean.
12 - direct power input to the PCM has been disconnected within the last 50 key-on cycles
55 - End of error messages
Dec 13, 2008 | 1995 Eagle Talon
Field & Stream Eagle Talon Kayak Logo
101 people viewed this question
Top Field & Stream Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Field & Stream Boating Expert? Answer questions, earn points and help others
