Question about Epson Stylus Photo R320 InkJet Printer
My R320 has started leaving a ink stain at the bottom of the printed pages along with the stain there is slight damage to the bottom corners of the printed sheets.
  • Epson Master
  • 419 Answers
Highly likely that your waste ink pads are now overflowing, causing backflow into the resting/cleaning pad where your printhead normally sits when not in use.
If you haven\'t already you should probably consider an external waste ink kit like a Printer Potty or similar as this will deal with any future waste ink flow.
However, if the pads are already highly saturated you\'re going to need to also drain them as much as possible using a syringe and blunt needle to suck as much excess ink out of the printer base.
Access to the base will probably be easiest via the access hatch in the back.. I suspect you\'ll confirm a puddle of ink back there at the same time.
Removing the waste ink excess is no quick and easy solution, just suck what ink you can out, then leave the printer for a few hours before repeating. This will allow the pads to re-distribute the excess after your efforts and some of that will then become accessible from the hatch.
Ultimately it\'s a big old clean up job but one worth doing.
To clean the underside of the printhead get the printhead off it\'s resting base (turn on, wait till it move, then pull the power cord).
Then just wad up some kitchen/paper towel (or even toilet roll), soak it in distilled (if possible) water and then place it in the printheads path. Move the printhead gently back and forth a couple of times so the wad of soaked material can wipe any ink deposits off the printhead base.
Avoid the temptation to scour the underside of the printhead repeatedly as it\'ll damage it.
Initially you probably won\'t see much improvement but over time the remaining ink spills and soiling will fade out as it gets cleaned out through use.
Good luck.
Posted on Aug 02, 2013
  • 157 Answers
SOURCE: Printing Streaky
Most likely the printer has been sitting for along time not used or you have used cheap replacement ink. Epsons are notorious for clogging the jets with cheap ink. unfortunately replacing the ink cartridges will not help because the jets are seperate from them. If cleaning numerous times does not work your next best bet is to buy a cleaning ink cartridge for your model. otherwise youll need a new printhead or new printer. If your going to use cheap replacement cartridges stay away from epson.
Posted on Jun 16, 2009
  • 67 Answers
SOURCE: Epson R320 prints REALLY SLOW!
That printer is known for being slow. If you believed a salesperson, they may have not done research either. But the printer is known for acceptable output for a really good price. Heres a review:
http://www.compukiss.com/populartopics/photoprintinghtm/review409.htm
Posted on Apr 08, 2008
aicaxz
  • 511 Answers
SOURCE: Epson Stylus Photo R320 InkJet Printer
Some types of Epson printers, replacement ink tank can only be done when ink reach the zero level or chip level not Recognized. You do this by pressing the button on the printer ink, or by following the procedures in Epson satus monitor. If desired the replacement ink tanks when not in the condition mentioned above, it is clearly necessary to shift the carriage to the replacement position. Unfortunately, the carriage must be locked in parking position. This can be overcome by releasing the lock carriage, or turn on the printer; when the printer initialization (move) from the parking position, unplug the power cord. Then the carriage is no longer locked. Scroll to position the replacement carriage
Posted on Jan 09, 2012
zabolyx
  • 38 Answers
SOURCE: Epson CX7800 3 in one printer feeds mulltiple sheets.
This is usually caused by a dirty or dented feed roller.
The feed roller is the black wheel that has s flat side to it above the paper tray. Try using a Q-tip and some rubbing alcohol to clean it. Then give it another whirl.
As with the ink on the paper. This is usually caused by leaky printheads. Epson printers are notorious for having the printheads die on them, but usually from the ink drying out. Check and see if the bottom of the printhead can be reached and cleaned by Q-tip or cotton swab. Give it a good cleaning using rubbing alcohol. Don't go over board as the alcohol will dilute the ink.
Posted on Apr 01, 2009
SOURCE: Epson CX3810 started leaving blank streaks, now no ink on page
I went to Epson.com's technology on google - and as I followed their prompts, I learned that it was the printer heads and that you aren't supposed to tilt the machine. I have been moving it a lot, so undoubtedly tilted it. You can follow the prompts after a right click on the printer icon on the bottom left corner of the monitor and it cleans the printer head. This also solves a white streak problem if people are having white streaks where there's no pringint....They had lost of answers there too.
Posted on Dec 14, 2008
When printing text I get extra lines or dots of ink next to or under the printed text
It sounds like you have lint on the bottom of the print head. ttle fuzz balls will collect down there and they catch drops of ink and leave little lines as they go across the page. buy an Epson head cleaning kit on ebay. It will include a cleaning fluid and a special foam tipped cleaning wand. Do not use a q-tip.
Apr 11, 2014 | Epson Stylus Photo R320 InkJet Printer
It leaves a black 1/4
See Craig Gillette's answer from Feb21,2010. That's your problem too.
Jan 04, 2018 | Canon Pixma MP500 All-In-One InkJet...
My dcp165c printer print quality prints black & yellow colour. i clean print head through maintance 76 but problem cannot be solved
How is the printer printing black and yellow color? Is it a smudge?
When I print, the pages are smudged with ink. What should I do?
Description:
- If smudged stains appear at the top center of the printed page:
  • Make sure the paper is not too thick or curled.
    Also, verify that the appropriate paper is being used and that the paper type set in the machine matches the media used.
  • Make sure the paper is not curled when you print on the back side of the paper with the Print Odd Pages and Print Even Pages settings.
- If smudged stains appear at the right or left corner of the printed page:
- If smudged stains appear on the reverse side or at the bottom of the page:
NOTE: Illustrations shown below are from the representative product and may differ from your Brother machine.
  • Make sure the printer platen is not dirty with ink.
    How to clean the machine's printer platen
    1. Unplug the machine from the AC power outlet.
    2. Lift the scanner cover until it locks securely in the open position.
    3. Clean the machine's printer platen(1) and the area around it, wiping off any scattered ink with a soft, dry, lint-free cloth.
    4. Close the scanner cover.
  • Make sure you are using Genuine Brother Innobella™ Ink.
    > Brother Genuine Supplies information
  • Make sure you are using the paper support flap.
    To use the paper support flap, pull out the paper support (1) until it clicks and unfold the paper support flap(2).
Aug 03, 2010 | Brother Computers & Internet
Printing Streaky
Jun 16, 2009 | Epson Stylus Photo R320 InkJet Printer
Brother MFC 7820N Smudging Concern
  • Make sure the paper is not curled when you print on the back side of the paper with the Print Odd Pages and Print Even Pagessettings.
Sep 11, 2017 | Brother MFC-7820N All-In-One Laser Printer
Stain in dryer
This will work. Soak white towel or other white fabric in bleach water, then slightly wring them out, leaving very wet. Then put them in dryer, on low or fluff cycle. Run for 60 minutes or more. This should rub off all the ink in the dryer. You may have to repeat if you have alot of ink. I have done this a few times and it has always work, good luck.
Dan
Mar 30, 2009 | Kenmore Elite HE4 Electric Dryer
Dec 13, 2008 | Epson Stylus CX3810 All-In-One InkJet...
Epson Stylus r320 photo
Hello Ed,
I believe I can help. I happen to have the same printer. My printer was unused for about a month and I could not get the black to print. What happens with these ink jet printers is that the ink drys out and becomes clogged in the print head and other jets. The spray orifices are extremely tiny.
I have a unique method of handling these problems that "usually" works. Here's what you can try.....
1), Get a paper towel
2). Set the ink cartridge to the setting where you remove the ink cartridges and can slide the print assembly back and forth.
3). remove ALL the ink cartridges
4). Fold the paper towel into a rectangle that is 1 inch wide and about 4 inches long) it should be like a fat pillow.
5). saturate the paper towel with clean water.
6). Position the saturated paper towel underneath the print head so that it is pressing against the bottom side of the print head where the ink would spray out on the paper. (It is crucial to get the damp paper towel into contact with the print jet's lower discharge surface. Make especially sure you get it under the clogged (non functioning color position).
7). allow this to set overnight.
8). The next day, remove the paper towel. Whatever color was giving you trouble printing, you should see that color ink in the paper towel. This is because the dampness has loosened the dried up ink. You may also see other colors too.
9). Re-install your ink cartridges and try it again (you may have to do 1 clean cycle but often it isn't even necessary.
This has worked like a charm for me over and over again. No guarantee it will solve your particular problem but it's easy and worth a shot and has returned my R320 to perfect service after sitting for long periods. (You can also leave a moist paper towel under the heads when not in use to prevent clogging). But IMPORTANT...if you don't remove the ink cartridges, the paper towel may pull all the ink out..
Jolly Chollie
Dec 15, 2007 | Epson Stylus Photo R320 InkJet Printer
Automatic Allignment Problem
Your balck ink printhead is clogged with buit up ink. Manually clean it with cotton buds and proper cleaning solution, right doen where cartridge sits and the contact area the ink part of cartrigde contacts. Try printing now. Did you reset ink levels too?
Aug 27, 2007 | Lexmark P6250 All-In-One InkJet Photo...
Epson Stylus Photo R320 InkJet Printer Logo
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
