Question about Microwave Ovens
I have a Craftsman belt sander model 207 22390.I need to know what size belt this takes. Does anyone know when it was manufactured? I purchased this at an auction.
We are looking for the equivalent to this microwave in a current model and need to know what size it is so that we can purchase another one that will fit. Thank you!
Look on internet with Your Model, Number & Make, you should find if it's still made , or you should find info from Company, that item is avil, or they advise you of nearist model to the size of your old one.
Mar 13, 2015 | In Microwave Ovens
My model CFP20 bowl for Black and Decker Short Cut Food Processor is cracked. Where can I get a replacement?
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, and a list of Dealers for spare parts, as required.
Just Google the manufacturer's name and follow the links. Make certain you are directed to the manufacturer's web site as some search engines direct you to other sites and they charge for the information that is normally free of charge.
I hope this helps.
Jan 05, 2011 | Microwave Ovens
Howw do I know the correct size in order to purchase the correc pars? for example how do I know the capaciy of my unit? does the max mark indicate the no. of quarts?
it should be in your units manual. if not you can go to the manufacturers website and look up information on it. if you tell me what model you have, i can help you more.
Dec 06, 2010 | Microwave Ovens
I have an electric fry pan purchased in 1977 (no kidding) manufactured by Nesco for The Hoover Company. The NESCO model is BC01 and the removable electric cord with temperature control on it, model jpr...
Take a look at the picture on this web link of the 3 power cords.
(scroll down just a little)
http://www.toastercentral.com/cords.htm
The pin spacing sizes are 1/2", 11/16", and 1 & 1/16ths inch.
Then you can go to this page:
http://electrical.hardwarestore.com/12-33-appliance-replacement-cords.aspx
scrolling down the same distance and look at the details of each cord.
Most large hardware stores have these cords if you know the Woods Industries number. Usually 0288, 0290, 0291, 0293 There are a few others but they are all in the same range from 0288 - 0293 (WOODS INDUSTRIES)
If you can not find it at a hardware any appliance parts center will also have them. Just remember the WOODS INDUSTRIES numbers.
Kelly
Sep 08, 2010 | Microwave Ovens
Not turning on has no power
If the model number is correct, there is a 125V, 20 AMP line fuse inside the microwave. Its usually mounted on a small input line filter board at the point where the power cord enters the back of the unit. You will need to UNPLUG the microwave oven and remove the exterior case to access. The case comes off in various ways depending on manufacture and model. I found this illustration at pcappliancerepair.com based on the model number you listed this question under:
http://pcappliancerepair.com/model-display.php
The line fuse is listed as item 47.
You can usually purchase a box of fuses at a hardware store for just a little more than what the manufacturer charges for a single fuse. 125V, 20AMP Slow Blow fuses are recommended.
If you have any questions, or need additional assistance troubleshooting, please post back and let me know. I hope you find this information helpful.
NOTE: Make sure you take any resistance readings with the microwave UNPLUGGED and the component under test isolated (removed) from the circuit.
Apr 27, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Where is the fuse located?
If the model number is correct, there is a small input line filter board with a 125V, 20 AMP line fuse inside the microwave. Its usually mounted on a small input line filter board at the point where the power cord enters the back of the unit. You will need to UNPLUG the microwave oven and remove the exterior case to access. The case comes off in various ways depending on manufacture and model. I found this illustration at pcappliancerepair.com based on the model number you listed this question under:
The line filter is listed as item 1420. The fuse will be mounted to this board.
You can purchase replacement fuses at any hardware store. You can usually purchase a box of fuses at a hardware store for just a little more than what the manufacturer charges for a single fuse. 125V, 20AMP Slow Blow fuses are recommended.
If you have any questions, or need assistance troubleshooting, please post back and let me know. I hope you find this information helpful.
Apr 24, 2010 | GE JES1290 Convection/Microwave Oven
Our carousel doesn't turn anymore. What can we
You probably have a broken belt. You can get a new one at http://www.repairclinic.com . They also have diagrams which show how to take your unit apart and replace the belt. Let me know if you need more help.
hardrocko
Thanks for using FixYa and for the generous rating.
Mar 11, 2010 | Maytag Microwave Ovens
I need a plate for my lg intellowave microwave oven where can i purchase this and how much
possibly ebay. But you need to know what size the plate is. I'm trying to figure that out myself - I can't find a model number only "intellowave" and one touch control
Aug 30, 2009 | LG Microwave Ovens
Surface and night light bulbs
If the model number you have this listed under is correct, the bulb you need is part #AP2029997, made by GE. You can also purchase these bulbs at any hardware store. They are the half sized small base, 40 watt bulbs. If you can't find 40 watt, make sure you use a lower wattage rating. If you have questions, or if the model number is incorrect, please let me know. I hope this helps you.
May 04, 2009 | GE JVM1650 1000 Watts Microwave Oven
Microwave turntable motor or belt?
I assume you don't have an illustrated parts list try and Google one up using make and model number etc. It is also a good guide on what needt to be removed and in what sequence.
As far as the novice part, the turntable is a basket case now what can you hurt, this is how we all learned, try to fix it if you cant then call someone who can, not a big deal.
Feb 28, 2009 | GE XL1800 1100 Watts Microwave Oven
Microwave Ovens Logo
24 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
