Question about iRiver H10 MP3 Player
Irver h10 Hi for the last of weeks ive had a blank screen on my h10 it still played music but now when i try and turn it on i get a white screen for a couple of seconds and then it turns off ive heard that rejuvenating the batt might help can anyone tell me how this is done step by step as iam not technically minded cheers Peter
  • 8,596 Answers
Plug into computer -it will charge
Posted on Jun 26, 2008
SOURCE:
Files in Iriver H10 not appearing in music.
try this...
connect your h10 to the pc using the ums trick with the usb connection..
For 20 GB MTP Models
  • Make sure your H10 is turned off and disconnected from the computer.
  • Poke the "reset" button with a paperclip.
  • Turn on the hold switch (so that you don't accidentally turn the H10 on all the way).
  • Plug the H10 into your computer.
  • Turn on the H10 while holding the "O" button.
  • You will see the message "Emergency Connection" if you have done everything correctly. You can now let go of the "O" button.
download and run EASYh10 software (free playlist maker). It will scan the files in your music folder and build/save a playlist to your h10.
disconnect player and give it a try...
Mar 13, 2009 | iRiver H10 MP3 Player
My Zen plays music but has a blank screen?
This is what you call the WSOD or the White Screen Of Doom. Is it still under warranty? If yes, go and have it returned or RMAd. Or you can try to download the Recovery Tool found here
http://www.creative.com/products/mp3/MP3PlayerRecoveryTool/welcome.asp?
Oct 19, 2008 | Creative Labs Zen Digital Media Player
Screne is white
you ahve to get a toothpic and stick it in the reset hole.
mine went like that too but the screen was blue and now that i reset it, it works as good as new =]
but is wont delete anything.
Oct 16, 2008 | Creative Labs Zen Digital Media Player
My iPod nano 2gb silver is showing a blank white screen.i've had it for close to a year and it freezes sometimes but that fixes itself when i drain the battery and then sinc it. but this time it just went...
Go throught this page
http://www.fixya.com/support/r561901-ipod_problems_start_5_solutions
Your ipod might need to be repaired, the apple service assistant is on the bottom.
Might be a loose connection or other failing component I don't think there is no quick fix for this.
If the problem is solved dont forget to rate as fixya otherwise there is no need to rate it. As there is noting else we could do about it.
May 15, 2008 | Apple iPod nano
The screen is turning white when I change song
You could possibly try recovery mode?
or formatting it and starting over, see if that helps
easy way to format
1.Shutdown player
2.Hold Rec button
3.Turn player on
4.Plug your player into the PC
5.Go to My computer
6.Find a Icon named 16Mb Format
7.Open that and make a new text file
8.Name it sansa.fmt
9.unplug player and it will say Formatting.....
10.when its finished it will reset , or shut off, when its done turn it on and see if that helps
May 08, 2008 | SanDisk Sansa e260 MP3 Player
Iriver H10 saying system Files missing
Try doing a format via windows explorer. Right click on the drive and then format as fat32. Then unplug and open iriver plus. Reconnect. See if that works. Good luck!
Jun 29, 2007 | iRiver H10 MP3 Player
Screen freezing
instead of going to music go to browser and acces your music through their...i had the same problem and this worked out fine....i think its just a bug
Jun 02, 2007 | iRiver H10 MP3 Player
Shorted
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard
Apr 04, 2007 | iRiver H10 MP3 Player
Iriver H10 20Gb Jammed
Hi StevieB Try following.1/Prepare a handy tool (straightened paper clip) to insert into "reset" hole atop of H10 2/gently insert tool into reset hole and feel a click 3/ turn on H10 if this works great 4/if H10 continues to jam lock up then it may require reloading firmware sounds complicated but easy steps available chk iRiver support website
Mar 28, 2007 | iRiver H10 MP3 Player
iRiver H10 MP3 Player Logo
121 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Ekse
Peter Dragonetti
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
