Question about Electrolux Washing Machines
E3 error in spin dry - Electrolux Washing Machines
  • Official Brand Answer
  • 4,342 Answers
Hello Jhunne, thank you for your post! I understand your unit is experiencing an issue with error code, E3 on your appliance. However, could the error code possibly be missing any characters? According from my research E3 is not a valid error code. Let's try resetting the unit by either unplugging it or flipping the household circuit breaker off. It is important to wait roughly ten minutes and then turn the unit back on. If resetting the power to the appliance does not correct the issue, I would recommend connecting with an expert repair tech to assist further.
Posted on Aug 01, 2013
2 Suggested Answers
  • 154 Answers
SOURCE: washing machine cannot dry spin.
Hi
Can you verify the make and modle of your washing machine. Is it a top loader or front loader.
Thanks
Ash
Posted on Sep 02, 2011
What does the E3 code mean on the 540 model and is there a fix?
Troubleshooting the "E3" error code in Maytag MAH6700 ...
fixitnow.com/.../troubleshooting-the-e3-error-code-in-maytag-mah6700-...
Feb 20, 2011 - These codes in your (made-by-Samsung) Maytag washer might pop up during the ... In fact, the E3 error code means that the Machine Control wants to make the motor spin but won't do it because it's getting a weird reading from the tachometer.... MAH6700 and MAH8700 models (they use the same motor).
I have a samsung frontload washing machine. A code E3 is ...
www.shopyourway.com > Denise LaGrasse > Questions
Mar 15, 2014 - My samsung front loader is not working. do not no what E3 means. ...code F26 mean on a Kenmore Elite model 110.4708 washing machine?
How To Fix 3E Error Code On A Samsung Washing Machine
www.appliancerepairlesson.com/.../how-to-fix-3e-error-code-on-a-samsu...
May 15, 2015 - Samsung uses the 3E error code to indicate a drive motor tach fault. ...If you're handy, you can fix your Samsung front load washing machine error code ....My samsung frontload washer shows e3 and the drum does not turn ...
Jan 06, 2016 | Washing Machines
Wont pump out comes up with E3 on display
CLOGGED WATER PUMP HINDERING DRAIN AND SPIN CYCLE
Jun 11, 2015 | Washing Machines
Error e3
Thank you for your post, friend!
I understand that your Electrolux washer is displaying an "E3" error code while it is spinning. However, it appears "E3" is an invalid error code. It is possible that the error code is missing characters? I suggest resetting your washer. You can do this by flipping the household circuit breaker for roughly ten minutes. If resetting the power does not correct the issue, and your washer continues to display "E3" I would recommend contacting a professional to come and properly diagnose your appliance. -Matt
Aug 11, 2014 | Electrolux Washing Machines
After main washing, stops and can't spin. Gives error E3.
The "E3" error indicates that a Samsung washer's motor is not running properly. The cycle can usually be restarted by pressing the "Start/Pause" button. However, if the error code appears again, you should contact an authorized service technician.
Sep 25, 2013 | Washing Machines
My haier washing machine with error code E3,what 's the problem?
Can you help me to fix my haire plz it not spin
Nov 11, 2011 | Washing Machines
Washing machine cannot dry spin. error code E3
Hi
Thanks
Ash
Sep 02, 2011 | Washing Machines
E3 error
“E3” code – Machine control is attempting to drive the motor but is not seeing any tach response. Visual Check shows motor is not moving. (Locked or Hall Sensor fault.)
Possible causes of ‘E3’ codes: 1. Spin drum stuck – Verify that the spinner moves freely to eliminate this cause. 2. Hall Sensor fails or is loose – When the Hall Sensor fails or becomes dislodged, the control doesn't recognize that the motor is spinning and shuts down. The result will likely be an “E3” code in the worst case, or “SUdS” if it is only getting a partial rpm reading. Check wire harness connector(s) to motor.
Hall Sensor – PCB that is located on the back of the motor that senses motor rpm. It is not a separate part, but rather an integral part of the motor.
Aug 20, 2009 | Maytag Neptune MAH5500B Front Load Washer
My NEC NFL855 E3 error
E3 error is discharging water problem. ie 1.the pump not working (under bra wire will stop it spinning) or 2. the discharge hose blocked or most likely 3. the pump inlet hose from the drum is blocked (with small article of cloth or coins or similar).
To Fix:
1. Open the pump filter and check if spinning during empty/spin cycle, make sure nothing jamming or twisted around impellor.
2. Check discharge hose is not crushed or kinked.
3. Lay machine on its side, access pump and remove inlet hose assembly and remove any blockage.
Jeremy
Jul 19, 2009 | Washing Machines
Washing Machines Logo
339 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
