Question about DigiLife DDV-V3HD High Definition Camcorder
Where is the charging point on the camera - DigiLife DDV-V3HD High Definition Camcorder
Why won't the battery charge when I put it on the charger
Either because the charger is compromised by an internal component, or the charger cable is broken (usually near a strain relief), or the camera's internal charge circuit has a faulty component which includes the point where the charging connector is attached to the printed circuit board inside the camera.
Jul 11, 2015 | Cameras
I just bought a Digipower model TC-U450 and am trying to charge a Nikon EN-EL20. My battery has 4 contact points but there are only 2 prongs on the charger. How do I charge my battery with this charger?
The battery has 4 contact points, but there are only 2 that are charge points. The + (pos) and - (neg) are the ones you need to adjust the charger contact points to make connection with.
Dec 25, 2014 | Cameras
Battery charger issue
funny thing with batteries is that they can get a memory = sounds stupid yes = if a battery is recharged when it has half charge and then fully charged it remembers the point , one it gains memory it wont charge past the last point = or the battery life is over = or the charger is faulty.
Jun 12, 2014 | Samsung S1030 Digital Camera
Battery not charge samsung camera es55
now a wire inside the charger could be snaped at that point u should get a new one
May 06, 2013 | Samsung Cameras
My usb cable isnt chargeing my camera, how can it?
Hello Janie,
Please check the connecting points of camera and the USB cable. If all the connectors are good then USB cable is damaged. Purchase the new cable and charge your camera. Another possibility may battery is damaged. So please also check the camera battery.
Dec 26, 2011 | GE Cameras
My cammera will not charge! The orange light does not show up when charging ???
There are 3 possibilities to charge the battery of the camera:
1. Connecting the Olympus' USB cable to camera and computer.
2. Connecting the wall charger to the camera with Olympus' USB cable.
3. Using a specific separate wall charger for LI-50B batteries.
Be sure to connect the cable well and if the orange LED does not light when trying to charge the battery using above points 1 and 2, there might want to exchange the Olympus' USB cable first to check what's wrong. (Cable model: CB-USB6). Another point is to check if the battery is seated well in the camera.
Jun 05, 2011 | Olympus SP800UZ Digital Camera
The Sony battery that came with the camera no longer works
I had the same problem and tried cleaning the contact points with alcohol on cotton swabs and it didn't work so I tried using a clean pencil eraser and after cleaning both the battery contact points and the 3 contact points within the camera using a twisting motion, it works!
Jul 19, 2009 | Sony Cyber-shot DSC-W70 Digital Camera
My pentax digital camera is charged but when i switch it on it shuts down after a few seconds
How old is the Camera ?
Do you do a complete discharge prior to charging ?
Is it Li-ion...
1 - Battery may be sitting on an internal memory from 'charge point' - Try and discharge completely..
2 - Your battery has had its day, and will not retain power (mAh)
Aug 15, 2008 | Cameras
My Digilife DDV-1100
the camera's battery won't charge with the usb cable connected to the computer, only with the 110/240 v charger. Hope I can help
Jul 11, 2008 | DigiLife DDV-M1 Flash Media Camcorder
DigiLife DDV-V3HD High Definition Camcorder Logo
20 people viewed this question
Top DigiLife Video Cameras Experts
Tony Parsons
Tony Parsons
Are you a DigiLife Video Camera Expert? Answer questions, earn points and help others
