Question about Frigidaire FSC23R5D Side by Side Refrigerator
Turning off high temp alarm - Frigidaire FSC23R5D Side by Side Refrigerator
  • Official Brand Answer
  • 4,342 Answers
Hello Lee, thank you for allowing me to assist you. When the refrigerator is beeping or buzzing, it may be a warning sign of a possible malfunction or an unsafe, interior temperature. To silence the buzzer, you can depress the ALARM OFF button. However, if you have already done this, try unplugging the unit or flipping the household circuit breaker for about ten minutes.
If the alarm continues, it could possibly be experiencing a communication problem with the temperature control/board or wiring failure. I would recommend connecting with a professional appliance tech for a clear-cut diagnosis.
Posted on Aug 02, 2013
Hurlcon MX 250 Pool/Spa heater. Why does it have an intermittent F2 alarm (high temp >45d)?
check the manual bypass inside if ok check the temp sensor also check gas pressure if too low will overheat and shut off
Dec 31, 2015 | Pool & Spa
My high temp alarm has been on all day
the warming up will be because the unit is not operational and the door hasn't been opened
call a service technician and check for a failed start/run capacitor for the compressor
the high temp alarm indicates that the food is in danger of spoiling
Sep 06, 2015 | Frigidaire White Frost Free Upright...
Westinghouse virtuoso freezer alarm will not turn off, why?
the alarm on virtuoso/ westinghouses are generally a high temp alarm
meanning the freezer has not reached its set point temp . it could be caused by many problems . i would suggest you get a tech to diagnose it properly .
Oct 03, 2014 | Westinghouse Refrigerators
My frigidaire gallery refrigerator model number DGUS2645LF3 is showing an error code "5b" and nothing inside works.
Hello;
My name is Peter. I am a retired field service refrigeration technician.
You are in the Sabbath Mode.
The Sabbath Mode is a feature that disables portions of the refrigerator and its controls in accordance with observance of the weekly Sabbath and religious holidays within the Orthodox Jewish community.
Sabbath Mode is turned ON and OFF by pressing and holding "?" on freezer temp and "?" on refrigerator temp for five seconds. The display shows "Sb" while in Sabbath mode.
In the Sabbath Mode, the High Temp alarm is active for health reasons. If a high temperature alarm is activated during this time, for example due to a door left ajar, the alarm will sound intermittently for about 10 minutes. The alarm will then silence on its own and a red high temperature icon will display. The high temp icon will continue to display, even if the door is closed, until the Sabbath mode is exited and the icon reset. The refrigerator will function normally once the door is closed, without any violation of the Sabbath/Holidays.
If this does not solve the problem you have a bad control board.
Sep 02, 2014 | Frigidaire Refrigerators
High temp alarm
Good Afternoon Friend,
I see that you have the High Temp alarm going off on your Frigidaire refrigerator. First, you will want to press the Alarm Off button to turn the alarm off. Next, you will want to press and hold the Factory Default button to put the temperatures at 0 degrees for the freezer and 37 degrees for the refrigerator. Wait 24 hours for the temperatures to stabilize. If you are still having trouble with the alarm going off, reset your appliance by either unplugging it or shutting the power off at your homes circuit breaker for 2-3 minutes. When power is restored, you will need to press the alarm off button. If the High temp alarm is still going off, I suggest contacting your local authorized technician. Hope this is helpful.
-Best Regards-
WP
May 15, 2014 | Frigidaire Refrigerators
High temp 20-29 F Frequent high temp alarms
check condensor fan if it has one. if not unit may have sprung a leak some where
Apr 10, 2010 | Freezers
The high temp light is on. What can I do to reset it? Everything seems frozen and fine in the frezzer
HIGH-TEMP ALARM SWITCH (SOME MODELS)
An audible
alarm will sound if the freezer temperature reaches
unsafe levels. The alarm operates on household electricity.If
the power
fails, the alarm will not perform.
An ON/OFF switch
allows the high temperature alarm to be
deactivated if desired. NOTE: You must open the
freezer door to
view the alarm switch. The
freezer is shipped with the switch in
the OFF position.
After the freezer has run longenough to
lower the temperature, you
may set the switch to the ON
position.
To activate the alarm, set the switch
to the ON position.
To deactivate the alarm, set the switch to the OFF position
i got this from the freezer manual from Kenmore hope this was helpful
Mar 28, 2010 | Kenmore Freezer 13.7 cu. ft. Upright...
I'm getting a P4 code & It doesn't blow hot air
P4 code outdoor compressor air exhaust temp too high/outdoor ambient temp too high/ compressor enclosure temp switch break off/module temp too high. Compressor is not running because it has an over temp alarm. Fix/repair thermocoupler
Nov 21, 2009 | AmcorAire UCHW-H18AF2 Split System Air...
Ok...next...
Good Day, egear00;
Try looking at this, since you sound like a TECH;
The Fan alarm is activated when the Fan does not run. This can happen in two different circumstances.
  1. When the Fan Fails due to a malfunction.
  2. When the Power is turned off. The FAN +12 regulators turn off and the fans quit.
(1) When the Fan Fails:
In this situation the fan alarm will be activated. Inside each fan is a hall element that keeps pin 1 of the connector pulled low when the fan rotates. If the fan stops, the pull up resistor connected back to the Fan 12+ pulls the alarm line high. This high is routed through two Diodes to the shutdown circuit of Q905, Q906. When the base of Q905 goes high, it's collector pulls the Power 1 (Power On) command line low which shuts off the relay driver Q903. The purpose of Q906 is to make the shutdown circuit appear like an SCR. If there's any pull up voltage being supplied, (in this case from the Power 1 line), the emitter to collector current of Q906 will keep Q905 in the On condition. This circuit will remain latched as long as the Power 1 line remain in the on condition.
An additional route for the Fan Alarm is out the PPS2 connector pin 9 to Q562. The Fan Alarm high will cause Q562 to turn on and pull the Fan Alarm pin 48 of the Microprocessor low. When pin 48 goes low, the Microprocessor will in turn activate the Temp LED and cause it to Blink. (See the Temp Alarm Circuit for more details).
(2) When the Power is turned off.
When the Power is turned off, the Fans do not run because the Fan +12V regulators I906 and I907 are turned off. This would generate a false Fan Alarm, so the Microprocessor outputs a High from pin 56 to Pin 7 of the PPS2 connector. This high turn on the Fan Alarm Enable transistor Q908. When Q908 is turned on, the collector is held low to prevent a Fan Alarm. This low keeps D916 and D918 cathodes held low.
click-to-view.gif Click to view Larger Image separately.
fan-alarm-protect-sm.jpg Good Luck, big IRISH.
Aug 20, 2008 | Hitachi 60V500 60" Rear Projection...
Frigidaire FSC23R5D Side by Side Refrigerator Logo
816 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
